Old 02-16-2006, 09:39 PM   #1
HIGHcard
My Ride: honda civic
Exclamation All 4 Halos Do Not Work. Help.
hi, when i washed my car and turned the key to the second position all 4 of my halos just werent working...is there anyone who has any idea what the problem may be? i swapped fuses with my friend who has the same dde kit as me and when i turned it to the second ignition all 4 dde's turned on for a lil bit and then turned off permanently again...any help would be highly appreciated! thanks in advance! -HIGHcard
HIGHcard is offline   Reply With Quote
Old 02-16-2006, 10:24 PM   #2
wesborl898
My Ride: Acura RSX-S/Ducati
Send a message via AIM to wesborl898
maybe your fuse holder is faulty
wesborl898 is offline   Reply With Quote
Old 02-21-2006, 10:21 AM   #3
2001BMW330xi
My Ride: Jeep
Send a message via AIM to 2001BMW330xi
something may have gotten wet?
-Ratnesh
2001BMW330xi is offline   Reply With Quote
Old 02-21-2006, 10:24 AM   #4
Tutankhamon
My Ride: 2017 M2
Send a message via ICQ to Tutankhamon Send a message via AIM to Tutankhamon Send a message via MSN to Tutankhamon
ballasts don't like water, check to see if there is any moisture around them.
Tutankhamon is offline   Reply With Quote
Old 02-21-2006, 10:45 AM   #5
RidinBimmerz
RidinBimmerz's Avatar
My Ride: Porsche 997 S
same thing happened to me. turned out the ring just happened to be faulty
997S X-51 Pack, PCCB, Full Cocoa leather and MUCH more
RidinBimmerz is offline   Reply With Quote
Old 02-21-2006, 10:48 AM   #6
kpeng
Banned User
My Ride: E46 330 and E30 325
Before you jump to anymore conclusions, I would check to see if the fuse is in the fuseholder all the way. If it's not, it can cause the angel eyes to go out.
-Ken
kpeng is offline   Reply With Quote
Old 02-21-2006, 01:52 PM   #7
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
If all 4 went out there is something funky with your connections. Check the fuse, ground, power taps, and most importantly make sure you did not get the ballasts wet.
Old 02-21-2006, 02:59 PM   #8
driftinsequence
My Ride: waiting to be modded
Send a message via AIM to driftinsequence
chances r, you got water inside your ballast since those are the mounted on the sides of the car where after washing the car, you could get water in there.
that is why i wrapp mine in several layers of electrical tape!!!!
driftinsequence is offline   Reply With Quote
