Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 02-17-2006, 05:56 PM   #1
J3F
My Ride: .
playstation can destroy a rear projection tv?
i sthis true? i have a 54" samsung that i think is rear projection. ive heard mixed reviews about the ps2 damaging it.
I have pissed on 6 buses in my life. If I was drunk in your city I would do it there to!
J3F is offline   Reply With Quote
Old 02-17-2006, 06:05 PM   #2
baller99
My Ride: My whip
Destroy? No. Burn in a picture with static images? yes
baller99 is offline   Reply With Quote
Old 02-17-2006, 06:08 PM   #3
PYRITE
My Ride: 1965 Ford Mustang
Dude, you wont burn in a picture with a Rear Projection DLP or LCD TV.
PYRITE IS SOLD!!
Welcome "KRYPTONITE"...
PYRITE is offline   Reply With Quote
Old 02-17-2006, 06:10 PM   #4
jetblackchew
My Ride: 03 ///M3 Cab
jetblackchew is offline   Reply With Quote
Old 02-17-2006, 06:10 PM   #5
baller99
My Ride: My whip
1) Notice he said "rear projection", and nothing about dlp or lcd rp.
2) You CAN burn in images into a lcd or dlp rear projection set. The processing chips themselves do not change the fact that the screen can burn in on those sets.
Old 02-17-2006, 06:19 PM   #6
blownE30M3
My Ride: 2004 JB M3
Send a message via AIM to blownE30M3
Uhhhhh. The way they work it is not physically possible for them to burn the screen. They are merely a reflection of light off a mirror or processor.
There is no direct contact with the screen.
Home Automation and A/V Programming
http://www.xsdesignstudios.com
blownE30M3 is offline   Reply With Quote
Old 02-17-2006, 06:21 PM   #7
baller99
My Ride: My whip
You are correct. Still, how did dlp and lcd come into this discussion?
Old 02-17-2006, 06:25 PM   #8
blownE30M3
My Ride: 2004 JB M3
I was thinkin the same damn thing. Seems like whenever we talk about certain kinds of tv's, all of em end up in the mix.
Old 02-18-2006, 05:37 PM   #9
zbeam3
My Ride: VQ35
How about crt tubes? Can burn in occur?
zbeam3 is offline   Reply With Quote
Old 02-18-2006, 05:46 PM   #10
baller99
My Ride: My whip
Direct view crt can't burn in. Rear projection crt can.
Old 02-18-2006, 05:57 PM   #11
slow323ci
E46-free since 10-13-06
My Ride: 335i coupe
Direct view CRT can most definitely burn in.
Geez, dude, you ought to quit while you're ahead
Probably because when a person asks such a vague question you have to throw everything into the mix while you guess which question is actually being asked
slow323ci is offline   Reply With Quote
Old 02-18-2006, 06:23 PM   #12
baller99
My Ride: My whip
I have never heard of a direct view television burning in. It is "theoretically" possible, but in practice it is close to impossible.
All of you guys have families that have owned multiple direct view crts over the years along with your relatives and friends. When have you ever heard of one burning in or when have you heard a salesman try to dissuade your choice in a direct view tv because of possible burn in? Projection and plasma tvs on the other hand...
Old 02-18-2006, 07:27 PM   #13
slow323ci
My Ride: 335i coupe
I've seen literally hundreds of burned in CRT computer monitors, which are the same as TV CRTs
A CRT-based rear projection TV is no different than a direct view CRT display. Other than each CRT displays only one color in a projection set. But I don't see that is any different than a direct view CRT.
No one that I know personally has a burned-in set of any kind, so the logical conclusion from that is that no kind of TV is susceptible to burn in.
Although if I was going to have CNN or ESPN or whatever on all day every day or if I had kids that would be playing video games for hours on end I would get a DLP set just to be safe. Since they are the only ones that are 100% certain to not have image persistance problems.
Old 02-18-2006, 08:07 PM   #14
baller99
My Ride: My whip
A crt computer monitor is much more likely to suffer burn in because it displays static images much more than a television. Again..have you ever heard of a direct view television burning in? The "logical" conclusion one can reach is that the likelihood of this happening, considering all the experience we have with crts, is that the likelihood of it happening is so small that it isn't worth even mentioning.
Old 02-18-2006, 08:17 PM   #15
jetblackchew
All the TVs when I worked at CNN had the logo burned into the CRTs. Burn-in at home? Unlikely, unless you fall asleep with the tv with an image and no motion. But you are both right, It can definately happen on CRTs, but unlikely if you're careful. New generation TVs whether RP LCD, RP DLP, LCD, Plasma, etc have built in 'screen savers' that will kick in after a certain timeframe depending on how you configure it.
Old 02-18-2006, 08:27 PM   #16
slow323ci
My Ride: 335i coupe
Yes.
But you are changing your story - first you plainly said a direct view CRT can not burn in. When in fact it most certainly can.
But I wouldn't worry about it.
Old 02-18-2006, 08:51 PM   #17
djmatty
Banned
djmatty's Avatar
My Ride: Black '99 328i Sedan
Send a message via AIM to djmatty
J3F: just fvcking Google it, you'll never get a final answer out of these guys.
djmatty is offline   Reply With Quote
Old 03-07-2006, 01:53 AM   #18
AussieBMW
My Ride: 2003 318i Sport
LCD rear projection can burn in, because the LCD panels themselves used in the projection process can burn. Unlikely though.
In 96 hours, Jack Bauer has killed 93 people and saved the world 4 times. What the fcuk have you done with your life?
AussieBMW is offline   Reply With Quote
Old 03-16-2006, 12:26 PM   #19
TX330ci
TX Dinan 3
My Ride: women
actually on ESPN HD if you watch closely, the bars shift position to avoid burn in
Dzoccu nun ti appreni, nun dir né mali né beni
TX330ci is offline   Reply With Quote
Old 03-16-2006, 01:25 PM   #20
brew
My Ride: F150 X5 MR2
About 15 years ago my uncle's CRT had permanent images from Mario Brother's burned into the screen.
brew is offline   Reply With Quote
