Thread Tools Search this Thread Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Old 02-18-2006, 10:14 AM   #1
zombie78
My Ride: has two turbos
Send a message via AIM to zombie78
Car won't start after air bag deployment.
So last night in a moment of pure retardation I swerved to miss hgiting a dog running across the road, car hit a curb, jerks the wheel from me, and then I hit a concrete retaining wall. Air bag went off, and now car won't start. Is there anything I can do to get the car to start again? It is drivable, from what I can see.
zombie78 is offline   Reply With Quote
Old 02-18-2006, 10:36 AM   #2
pbotz2000
My Ride: 2002 330ci
the battery terminal blew. u will have to sort of bang the terminal back together with a large screw driver and hammer to start the car.
pm me i will give u better directions
pbotz2000 is offline   Reply With Quote
Old 02-18-2006, 11:01 AM   #3
driftinsequence
My Ride: waiting to be modded
Send a message via AIM to driftinsequence
driftinsequence is offline   Reply With Quote
Old 02-18-2006, 11:05 AM   #4
BMW330xi01
My Ride: 98 Skyline
its a saftey feature BMW installed if the airbag goes off the emergency flashers go on and it kills power from the battery so sparks wont ignight fuel.
NO LONGER INSTALLING IN CONNECTICUT. I AM LOCATED IN JAPAN NOW
LUIS ESCOBAR
L.EscobarJr@yahoo.com
INSTALL PHOTOS
BMW330xi01 is offline   Reply With Quote
Old 02-18-2006, 11:24 AM   #5
Alan
Alan's Avatar
My Ride: 2006 M3
Think of it as a safety fuse at the battery terminal. You can jump it from the fused (blown) link cable side.
Alan is offline   Reply With Quote
Old 02-18-2006, 11:31 AM   #6
pahasbimmer
My Ride: 05 M3 - SG/IR, 6MT
Yep, it's your battery terminal. You will need to replace it (pain in the a$$, but can be done). Dealer sells a repair kit for around $300 (includes about 2 feet of power terminal cable, sensors, and connectors).
I've done it on my car so let me know if you have any questions....
pahasbimmer is offline   Reply With Quote
Old 02-18-2006, 11:35 AM   #7
gjvilleg
My Ride: 2001 325Ci
Thats right, whenever you deploy any of your airbags your cars powers shuts off, this is just a safety issue I guess because of fires or something worst. All you gotta do is re-start the computer by removing the positive terminal for like 5 minutes, check your fuses see if they are all ok and plug back in the terminal, i suggest you do this for the negative as well. You should be ok unless there is something mechanical thats not letting it start. I hope this helps. i could be missing something but thats the overall idea. Good luck , BTW which airbag did you blow?
gjvilleg is offline   Reply With Quote
Old 02-18-2006, 02:42 PM   #8
pahasbimmer
let me clarify, it's your positive battery terminal
http://www.realoem.com/bmw/showparts...03&hg=61&fg=10
Old 02-18-2006, 06:13 PM   #9
zombie78
That is nuts! There is no way in hell they can justify selling a cable for over 400.00!
Old 02-22-2006, 11:55 AM   #10
pahasbimmer
Well it's not only a cable, its got that mechanism that blows it out, but yeah, I agree $400 is WAY WAY too much....
Old 02-19-2009, 08:56 PM   #11
topback
My Ride: vert
I KNOW ITS AN OLD THREAD
so just by resetting the computer i should be good to go? unplug terminals and leave it for like 5 minutes, then return, connect and voila? thanks
topback is offline   Reply With Quote
