Go Back   E46Fanatics > Other BMW Models > General BMW Model Discussion
All non E46 BMW model questions in here. Look below for E36, E90 and F30 specific forum. For additional model specific forums check out bimmerfest.com!
Old 02-20-2006, 06:51 PM   #1
BMWintoxication
Taiwan/Vancouver/Shanghai
My Ride: Jet Black02' 325ci
Send a message via AIM to BMWintoxication Send a message via MSN to BMWintoxication
BMW goes BiTurbo!!!!! ...
from:http://www.worldcarfans.com/news.cfm...ght-six-engine
The force is with BMW as a new biturbo petrol engine blows in at the Geneva Motos Show
* 225 kW/302 hp and 400 Nm for hugely-powerful all-aluminum 3.0-litre six
* High-precision direct petrol injection cuts fuel use by 10 percent
* Turbo lag banished by intelligent biturbo technology
BMW is not re-writing the laws of physics, just the laws of forced-induction. Turbo lag has been vaporised, fuel consumption slashed and torque ramped to the max, as BMW unveils yet another benchmark-setting power unit.
Backing up its global success with the innovative 507 bhp V10 powerplant for the M5 and M6 super cars (2005 Engine of the Year), and the VALVETRONIC magnesium-aluminum straight-six engines introduced in 2005, BMW is set to tear the wraps off a production-ready biturbo version of its acclaimed petrol-powered six-cylinder. Retaining the familiar 3.0-litre capacity, the new all-aluminum engine boasts a pair of turbochargers, each feeding a trio of cylinders.
When combined with the efficiency and flexibility of acclaimed BMW VALVETRONIC and double-VANOS technology, the new engine is able to produce an immense 225 kW of power and 400 Nm of torque. It is armed with a Table Mountain-like torque profile that defies the term curve. Peak torque of 400 Nm is delivered between 1,500 rpm and 5,800 rpm and the engine boasts a 7,000 rpm red line.
The biturbo six-cylinder has the same power and more torque than the muscular 4.0-litre V8 engine fitted to the 740i. The new engine further entrenches BMW as the manufacturer of the world's most intelligent, advanced and dynamic engines for the enthusiast driver. However, in keeping with BMW philosophy, the substantially enhanced performance does not come at a substantial cost to the environment. Fuel consumption, previously a bug-bear of high-performance turbo-charged engines, has been radically reduced thanks to high-precision direct petrol injection, used for the first time on a BMW six-cylinder motor. The V12 powered BMW 760i/Li features direct petrol injection for its 6.0-litre engine.
A further traditional turbo-engine wrinkle has been ironed out by BMW engineers: turbo lag. In the new engine, this has been completely removed, thanks to low inertia turbochargers. The driver need only brush the accelerator pedal to receive an immediate surge of power and performance, as the engine delivers an electrifying response. While turbocharger technology is almost as old as the internal combustion engine itself, in combination with cutting-edge high-precision direct petrol injection technology BMW engineers were able to write a new and exciting chapter in the history of forced-induction.
The foundation for all this power and torque is drawn from the exemplary characteristics of the magnesium-aluminum 3.0-litre engine which is rated at 195 kW/265 hp (as fitted to the BMW 130i and Z4 Roadster). This in itself is quite outstanding for a normally aspirated engine. Compared with the proven 3.0-litre normally aspirated magnesium-aluminium engine, the all-aluminium engine featuring new biturbo technology increases overall output by approximately 15 percent. Peak torque shoots up by an even more impressive 30 percent. The resulting 225 kW/302 hp and 400 Nm of torque deliver outstanding thrust and driving power all the way across the rev range.
The only way to achieve such an increase in power and performance with a normally-aspirated engine would be to significantly increase engine size, which would also mean a corresponding increase in weight and the negative effects on the car's overall balance. The BMW combination of turbocharger technology with high-precision petrol injection is a particularly efficient way to meet even greater demands in terms of output and torque. And for comparison, the new straight-six biturbo weighs about 70 kg less than an approximately equally powerful eight-cylinder normally-aspirated engine displacing 4.0 litres. That is about the same weight as a moderately sized passenger.
Direct petrol injection also offers a significant fuel consumption saving of about 10 percent compared with a similarly powerful turbocharged engine that uses regular fuel injection. Turbines made of high heat-resistant special steel can withstand temperatures of up to 1,050 ***176;C and therefore do not need the cooling effect of extra air flow. Particularly under full load, this means a significant decrease in fuel consumption.
High-precision fuel injection allows an even more exact dosage of fuel as well as a higher compression ratio - ideal conditions for increasing engine efficiency and significantly reducing fuel consumption. All this is made possible by the central position of the piezo-injector between the valves. Fitted in this position, the innovative injector opening to the outside is able to distribute fuel in a conical burst ensuring particularly smooth distribution of fuel within the combustion chamber.
Apart from its low weight and class-leading fuel economy, the new biturbo engine is able to offer yet another unique BMW feature. This is supreme smoothness and refinement, precisely the virtue which has made BMW straight-six power units the benchmark for refined drive technology, acknowledged the world over. Indeed, the natural perfection of the straight-six layout gives the engine perfect balance in terms of free mass forces, avoiding vibrations even at high engine speeds.
A further important point is that this turbocharged version of BMW's six-cylinder comes with the same hollow, extra-light camshafts as on the normally-aspirated engine, as well as an electrically driven coolant pump operating only as required. Developing this new straight-six with biturbo technology, BMW is opening
up a new chapter in the long history of the turbocharged engine, which dates back to 1905 and the work of Swiss engineer Alfred B***252;chi.
Initially turbo-charged engines were restricted to marine and aircraft engines. It was only much later that the technology migrated to cars. BMW began its association with turbocharged road cars with the now famous 1973 BMW 2002 Turbo road car. But BMW regularly sets important milestones in engine development.
During the late 1960s, BMW was the first manufacturer to use turbocharged engines in touring car racing.
And in 1983 a BMW Brabham driven by Brazilian racing driver Nelson Piquet became the first turbocharged F1 car to win the Formula 1 World Championship. Even back then, BMW's engine specialists were able to extract far more than 1,000 horsepower from an engine displacing just 1.5 litres.
Now BMW is ready to open a new chapter in turbo-charged petrol-engined road cars and reset the bench-mark for dynamic driving with forced-induction. Over and above the drivetrain conceived and built for supreme dynamics, this technology provides the starting point for a lean-burn direct injection concept and thus serves to successfully optimise fuel consumption also in other performance classes.
In this way BMW is once again proving its competence in engine construction, developing modern drive concepts and at the same time enhancing that sheer driving pleasure of BMW to an even higher standard. BMW will announce at a later date which of its vehicles will receive this new engine.
... think they'll have a bolt on kit?.. haha
Orz
BMWintoxication is offline   Reply With Quote
Old 02-20-2006, 06:53 PM   #2
IISoulSeekerII
My Ride: 2001 330CI
Send a message via AIM to IISoulSeekerII
Yep. See the "It's official thread..."
IISoulSeekerII is offline   Reply With Quote
Old 02-20-2006, 07:00 PM   #3
BMWintoxication
Orz
Old 02-20-2006, 07:22 PM   #4
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
sweet
-Brendan
Old 02-20-2006, 08:43 PM   #5
2003330i
My Ride: SC'330izhp,09 335i,
nice
2003330i is offline   Reply With Quote
Old 02-20-2006, 08:49 PM   #6
///M Speed
My Ride: is in the driveway
now thats what im talking about
///M Speed is offline   Reply With Quote
Old 02-20-2006, 09:00 PM   #7
tomalexm
My Ride: 328Ci
Send a message via AIM to tomalexm
295 lb ft
tomalexm is offline   Reply With Quote
Old 02-20-2006, 09:04 PM   #8
BMWintoxication
best of all.. no turbo lag!...
i'd like to hear any reason not getting a turbo if the lag is eliminated.
Orz
Old 02-20-2006, 09:08 PM   #9
BMWintoxication
Originally Posted by simsima325
sweet
??? since when are you a moderator?? haha
yah, i've seen the REPOST sign a lot, too. can ppl stop posting that sign? :p
Orz
Old 02-20-2006, 09:16 PM   #10
bimmerCi
My Ride: bmw
anybody else having trouble finding this thread? i searched a couple times and can't seem to find it. a link would be nice.
bimmerCi is offline   Reply With Quote
Old 02-20-2006, 09:27 PM   #11
///MLM
My Ride: TiAg 323i
Cliff Notes please....
just kidding...saw it a couple days ago. Yes, it is a but some threads get lost in the second and third pages so for all those who haven't seen it...ENJOY!!!
Car: 1999 323i Titanium Silver
Exterior:///M Lip Spoiler|OEM Clears with Solaris Diamond Invisibulbs|Body Colored Kidneys
Interior:///M Alumminum Pedals|Matte Chrome Trim|Silver Gauge Rings w/ Red Needles|Interior LEDs
///MLM is offline   Reply With Quote
Old 02-20-2006, 09:34 PM   #12
Wagon Man
Ultimate Wagon
My Ride: 00 iT (SOLD)
Give Wagon Man a "TT-T" please !!! then I don't need to buy an SKx
Wagon Man is offline   Reply With Quote
Old 02-20-2006, 09:47 PM   #13
happybmw
Are you happy
happybmw's Avatar
My Ride: 03' 325 XI
absolutely bueatiful
happybmw is offline   Reply With Quote
Old 02-20-2006, 09:49 PM   #14
happybmw
Are you happy
happybmw's Avatar
My Ride: 03' 325 XI
thanks for the article and pics
Old 02-20-2006, 09:53 PM   #15
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
baby turbos, how cute
Old 02-21-2006, 12:01 AM   #16
BMWintoxication
so...it's rumored that it will be Euro-exclusive..
and.. North America will get the N/A 3.5 engine...
http://www.leftlanenews.com/2006/02/...-turbo-engine/
Orz
Old 02-21-2006, 06:38 AM   #17
Mystic Sport
My Ride: ///M3
I hope you guys in the US get the 335i, I am on the waiting list in the UK for one and then will hopefully get a company called DMS to remap the engine to around 340-345bhp
Mystic Sport is offline   Reply With Quote
Old 02-21-2006, 06:43 AM   #18
redronin
My Ride: 330ci
there will of course be NA purists who scoff at the idea...
redronin is offline   Reply With Quote
Old 02-21-2006, 08:35 AM   #19
simsima325
simsima325's Avatar
You are OG enough to remember the days when this forum had moderation! Time for a new generation I guess
Someone made the good point in the other thread that BMW is not new to turbochargers, and has been using them in diesel cars overseas for many many years.
-Brendan
Old 02-21-2006, 08:44 AM   #20
redronin
My Ride: 330ci
plus the 2002 turbo and the 740 turbo were neither diesal correct?
