Old 02-27-2006, 11:55 PM   #1
pwalsh53
My Ride: E46
Send a message via AIM to pwalsh53
ABS during track / autox events
Hey guys. Now, I've always turned off my ASC (DSC) for autocross events, but one time I tried pulling the ABS fuse because I noticed the ABS kicked in too conservatively and I was losing braking power. I am about to start tracking my car and probably going back to autocrossing (it's been a year, gettin rusty...), I was wondering what people's experiences with this have been?
When I did it the one time at autocross it seemed I could modulate the brakes fairly easily even when they were on the verge of locking up, and I felt like I had more pedal travel because the ABS wasn't kicking in so soon. I may just need to learn to be smoother with the brakes...
Anyway, has anyone else done events with their ABS disconnected?
Thanks!
Patrick
pwalsh53 is offline   Reply With Quote
Old 02-28-2006, 01:37 AM   #2
vaio76109
My Ride: Race Cars
I didnt know you could disconnect the ABS. With that said I'd leave it on regardless.
vaio76109 is offline   Reply With Quote
Old 02-28-2006, 01:49 AM   #3
leej323
leej323's Avatar
My Ride: '00 323i
I thought pre-2002 models all could disable ABS with one push of DSC.
My ABS hasn't been intrusive at all and I've run both track and autoX before with DSC off. Maybe it's more sensitive depending on each car?
leej323 is offline   Reply With Quote
Old 02-28-2006, 01:58 AM   #4
vaio76109
My Ride: Race Cars
Pushing/holding down the DSC button will NOT turn off the ABS.
Old 02-28-2006, 09:11 AM   #5
jmsanders78
My Ride: 328i, Z4
Right.
jmsanders78 is offline   Reply With Quote
Old 02-28-2006, 10:39 AM   #6
pwalsh53
My Ride: E46
ABS and ASC (DSC) run on one fuse. If you remove it, they both go away.
The ABS has always been uber-sensitive on my car, like going off when I slow down over VERY minor bumps. Maybe BMW corrected it on the later cars. I already learned that my air bag sensors were WAY over sensitive when the right side airbags deployed when I hit a pothole. They fixed it later on in the model years I think.
Patrick
Old 02-28-2006, 11:26 AM   #7
leej323
leej323's Avatar
My Ride: '00 323i
ah ok, thanks for the clarification.
Yeah, like I said before, mine hasn't been too intrusive. I'm not sure if you can tweak the sensitivity of it or not through the dealer.
Old 02-28-2006, 07:13 PM   #8
Asmodeus
My Ride: 328i
I have the same car as you and I don't find ABS to be a problem at all. The local track where I go is brake intensive.
Are you maybe jumping on the brakes too quickly?
328i - TiAg / Black with PP - HK - 35% Tint - TiAG Headlight Trim - RSM - Gauge Rings - Clears - GruppeM - Silvervision - Koni Adjustables - UUC T.M.E., Clutch Stop, DSSR, Pulleys, Swaybars, LTW - EPS Pump - SS Brake & Clutch Line - MTech II Front - Angel Eyes - M3 Lip Spoiler - Z211, K104 - M6 Wheels -
TLC/BMW Instructor
Asmodeus is offline   Reply With Quote
Old 02-28-2006, 09:44 PM   #9
pwalsh53
My Ride: E46
Well I havent tracked my car yet. And autocross is alot more about transitions and heavy braking frequently. I might have just hit them too hard but it seemed the ABS came on too soon..
I guess I'll see once I take it to VIR :-D
Patrick
Old 02-28-2006, 09:45 PM   #10
pwalsh53
My Ride: E46
Well I haven't taken it to a track yet. I've done many autocrosses and sometimes I've found the ABS too intrusive. But these are two very different types of driving..
I guess I'll know once I drive at VIR :-D
Patrick
Old 02-28-2006, 11:00 PM   #11
IDLOOK2
My Ride: 00' 328Ci
Send a message via AIM to IDLOOK2
It sounds like you are using your brakes too abruptly. Once you go to VIR (have fun, btw!), you should be taught to accelerate/decelerate smoothly. I would say leave the fuse in at VIR. This being your first DE, don't worry about how fast you can stop. If you feel comfortable threshold braking (you acting as the ABS), I don't see a problem. If in an emergency, you WILL stop faster locking up the wheels w/o ABS but run the high risk of putting a flat spot on your tires.
What kind of pads are you using?
Mark - 00' 328Ci
IDLOOK2 is offline   Reply With Quote
Old 03-01-2006, 09:41 AM   #12
02SilverM3
My Ride: 02 m3 and 05 x3
Leave your DSC on for the first day at VIR. If you value you car. Leave it on the second day. If you value you life.
02SilverM3 is offline   Reply With Quote
Old 03-01-2006, 10:03 AM   #13
IDLOOK2
My Ride: 00' 328Ci
pwalsh53,
I strongly disagree with 02SilverM3, but drive how you feel most comfortable. DSC is a great feature for drivers that don't know the basic physics of car control. You mentioned you auto-x so you should have a good idea how your car acts, handles, and feels near your driving llimit. Being a beginner, you will not be encouraged to drive as fast as you can. You will progressively get faster getting pointers from your instructor with things you are doing right and wrong.
Mark - 00' 328Ci
Old 03-01-2006, 05:23 PM   #14
bmwtec
My Ride: e46 m3
Get some better tires.
ABS needs to sense wheel/tire slipage to become active.
You very well may be to agressive with your middle pedal, but a stickier tire will hold the road better and allow you to use the brakes more agressively.
I would never reccomend pulling that fuse.
bmwtec is offline   Reply With Quote
Old 03-01-2006, 07:33 PM   #15
pwalsh53
My Ride: E46
I was racing on Victoracer R-compound tires. I don't think the tires were the problem. I pulled the fuse for an autocross with good results, but I will probably see how it handles at the track before I make any decisions.
I am not leaving ASC on, I won't have any fun that way. Besides, it's not DSC like all you fancy 2000-on people. ASC is pure throttle modulation. It has nothing to do with yaw control or individual brakes being applied or any of that. It's essentially useless on my car. Especially considering I have a limited-slip differential, which makes the car much easier to control in a slide.
Patrick
Old 03-01-2006, 08:11 PM   #16
vaio76109
My Ride: Race Cars
Which LSD do you have?
Old 03-01-2006, 08:35 PM   #17
323iT
My Ride: AG 323i
Send a message via AIM to 323iT
I autox and never really had problems with abs. then again I'm not going very fast around the track :/
323iT is offline   Reply With Quote
Old 03-01-2006, 09:28 PM   #18
pwalsh53
My Ride: E46
Bimmerworld / Performance Gearing 3.15
Old 03-01-2006, 10:45 PM   #19
HighBoostin330
My Ride: 2002 Stock 330Ci
Jim Blanton at Performance Gearing builds the best LSDs!!! Great guy to deal with too.
HighBoostin330 is offline   Reply With Quote
