Health & Fitness
Discuss any topics related to heath and fitness here. |
#1 |
created a routine, pls check it out
Mainly aiming at upper body mass, but still want to keep legs / back in proportion. I have a good diet, high protein, 4+ meals, ON supplement, etc..
*Crunches every workout day Day 1 / Group 1 Chest Flat Bench Incline Bench Chest Cross-Over’s Incline Chest Cross-Over’s Butterflies (Last – Peak) Day 3 / Group 2 Biceps and Triceps Cable Press Downs - Tris Standing Barbell Curls - Bis Overhead French Press – Tris Pull-ups Dips (Last – Peak) - Tris Concentrated Curls (Last – Peak) – Bis Day 5 / Group 3 Legs / Back Reverse Crunches (Hyperextensions) Leg Press Reverse Butterfly Squats Calf Raises (Standing or Machine) One Arm Dumbbell Rows (On Bench) I am looking for mass while maintaining proportion. I plan on doing 8-10 reps to max. Am I hitting every muscle I need to be hitting? Any advice would be great, thx! I also play soccer and tennis, so my legs get a good workout (i think) and I get some cardio, but I am really looking for mass, not a cut look.
*****(_]/___________\[_) ****** /()O= bmw =O()\ ******|=o_________o=| ******|_|===--====|_| |
#2 |
legs and back all on same day is alot man. your legs and back are the biggest muscles on your body. i would add at least another day and seperate teh legs and back.
what you can also do is do biceps the days you do chest and then do triceps the day you do back.. but where is your shoulder workout?
#3 |
That's a bad routine imo. You're overtraining your arms since your tri's get worked on your chest day, and your bi's get worked on your back day. And where is your shoulder workout? If you want a 3 day split, try something like
chest/tris back/bis legs/shoulders
- Rich - Flickr - Stage 3+ TiAL B5 S4
"A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster." - Jeremy Clarkson euro.techniks ![]() EPL | TiAL | SDR | APR | Stratmosphere | 034 | ASP | SPEC | Fidanza | STaSIS | H-Sport | AWE | H&R | StopTech | BBS |
#4 |
Imported Redneck
if you split the leg into its own routine, here is what I do and it has given me excellent results
squats reverse bb lunges step-ups or jump squats calf raise finish off with hamstring curls/leg extension supersets I've found most other leg exercises to be useless for athletic performance and so far, this group of exercises have given me the most gain - both in the gym and on the court
#5 |
What happened to shoulders & traps? I'd break that routine up into 4 days if you can make it to the gym an extra day per week.
#6 | |
#7 |
You have an excellent work out in terms of muscle seperation. It is always a good idea to seperate your chest day from the rest of your work outs because that is a big muscle. I also like how you combined bi's and tri's...both are small muscles that accentuate the forearm when combined in the same work out. Legs and back can definitely be combined as back work outs, although back is a big muscle, are usually the least straining on the body in terms of fatigue. The only thing you need to do is add a shoulder day.
This is my routine: Day 1. Arms Day 2. Chest Day 3. Back Day 4. Shoulders Day 5. Legs Day 6. rest Day 7. rest You should also throw in a 15 minute ab routine after every work out.....abs, calfs, traps, and forearms are the only muscles that can be worked out on a daily basis. |
#8 |
The reason why it's good to seperate tri's and chest is because you can't get a good work out on both in the same day. If you go back and forth, your putting too much pressure on tri's and you won't get a good chest workout. IF you do tri's before chest, same thing. IF you do tri's after chest, then you are not giving your body the recovery it needs immediately following a chest routine.
The same reason goes for combining bi's and back. People think that because back work outs affect your bi's as well, you might as well combine them, but you actually get better results by seperating them....for that same exact reason. When you hit your bi's lightly on back days and work them out on a different day, they're almost getting twice the work out without the added strain....and you always have to remember to take your rest days (for joint healing purposes). |
#9 | |
#10 | |
