Old 03-07-2006, 11:35 PM   #1
Lay2Low
My Ride: Psshht Widebody; M3
Send a message via AIM to Lay2Low
Tapping Oil Pan?
This coming weekend I am going to need to tap my oil pan for a feed and return line for a special, umm, *project* that I have going on. What is the best method to tap the pan? Is it necessary to remove the oilpan, or can I just go straight through? Is it very hard to get up in there to make the taps?
Thanks in advance
Lay2Low is offline   Reply With Quote
Old 03-08-2006, 12:31 AM   #2
rmepilot
My Ride: Supercharged Tacoma
Send a message via AIM to rmepilot
If you're going to "tap" into your oil pan, you definately want to remove it. This way you can guarantee that there will be no shavings that get into your oil system. Also, you will be able to place the taps exactly where you want them. Good luck!
Rob
rmepilot is offline   Reply With Quote
Old 03-08-2006, 12:36 AM   #3
ewok
My Ride: Stg.3 323
Tapping is very easy and you wont have any problems getting in there with a tap. Your main concern is the required drilling of the pan. Its a tight fit with an electric drill cause you need to be able to drill "straight" and not in an angle, so your *special project's* flange can sit perfectly flush against the pan. I was told to use a 90 degree attachment for this very reason. Trust me, I was very concearned about this as well, just take your time. It sounds scary at first but one you've started its really not a big deal at all. Good luck.
TECHNIK Stg.3 SC /// TECHNIK FI CAMS /// TECHNIK HEADERS
Needs a Rear Bumper & Hood!
ewok is offline   Reply With Quote
Old 03-08-2006, 01:44 AM   #4
Lay2Low
ewok- Did you do this? Did you remove the oil pan? I know that removing it will be the safest thing, but not necessarily the easiest thing to do.
Anymore info would be great
Old 03-08-2006, 01:09 PM   #5
ewok
My Ride: Stg.3 323
I left the oil pan in place. Just be sure not to drive the drill in the full length of the bit, cause there are gears right behind that area. And remember to change your oil before start up.
Old 03-08-2006, 03:33 PM   #6
Lay2Low
Sounds pretty good. Can you send me or post some pics of your oil pan tapped? Any speical tools or tips I should know too?
Old 03-08-2006, 03:38 PM   #7
BimmerDude18
My Ride: 1998 528i
Not sure what the oil pan is made of but if its something magnetic might want to run a magnet on a stick around the area after you drill to try to collect some of the shavings up, maybe even flush it with some fresh oil. Just speaking from assumptions here though, I haven't ever done this type of thing.
-Tyler
1998 528i 5-speed Work in progress
1988 Toyota Pickup (4WD 5-speed) daily
2007 San Marino Blue 350z 6-speed sold
1996 328i 5-speed sold
www.e46nonM.com - www.precision-sport.com - www.flyingwindowtinters.com - www.techniquetuning.com
BimmerDude18 is offline   Reply With Quote
Old 03-08-2006, 05:33 PM   #8
HighBoostin330
My Ride: 2002 Stock 330Ci
Drill with MAJOR caution. Oil pump could be damaged if you go too far. Otherwise, listen to the recommendations and have fun with your project!
HighBoostin330 is offline   Reply With Quote
Old 03-08-2006, 11:06 PM   #9
Elefant
Banned
My Ride: and hes hairy too
i strongly suggest removing the pan and then drilling, otherwise you might risk oil shavings picked up by your oil pump. and you will get alot more piece of mind when driving the thing hard.
Elefant is offline   Reply With Quote
Old 03-09-2006, 01:08 AM   #10
Lay2Low
Any recomendation/input on this product: http://www.turnermotorsport.com/html..._ID=TEN9910200
I think I will have my hands full this weekend.
Old 03-09-2006, 01:31 AM   #11
ewok
My Ride: Stg.3 323
thats nice!
Good luck!
Old 03-09-2006, 01:32 AM   #12
Lay2Low
How does it work though lol?
Old 03-09-2006, 01:57 AM   #13
ewok
My Ride: Stg.3 323
hahaha.... I thinks it's more for an oil cooler set up. Not for a oil return line.
Old 03-09-2006, 04:09 AM   #14
Oshin02
My Ride: turbo E46/M3/MCoupe
Send a message via AIM to Oshin02
Is this for a turbo return line? If so, here is the loction........someone else has a project under it's way
I am, CARBON MAN.....
Oshin02 is offline   Reply With Quote
Old 03-09-2006, 04:53 PM   #15
Lay2Low
Oshino- thanks for the diagram. Can you send me the link to where you got it and email all the specs on making the taps like this? I need to have a feed and return line. Thanks for the help and I think I would like to go this route as long as there are more details!
Old 03-09-2006, 05:46 PM   #16
makr
My Ride: a lot
Fill the flutes of the tap with heavy grease, like wheel grease. The chips will be trapped in the grease instead of falling in the pan. You may want to do it with the drill also.
makr is offline   Reply With Quote
Old 03-09-2006, 10:50 PM   #17
Oshin02
NO ...... drop the oil pan. there is no need to risk damaging the oil pump.
Old 03-09-2006, 10:57 PM   #18
Oshin02
I scanned the diagram off of a bmw tec's manual which I've managed to dig up. It seems like your walking on the same road that I am--- two heads are better then one.......about all the information provided, I have it pretty much covered........"Boost comming soon", thats what I shall leave it at
Old 03-10-2006, 12:08 AM   #19
Lay2Low
So Oshin, how are you actually going to make the tap for your oil feed and return? Return does not seem to be as much of a problem as the feed line.
I was thinking of more ways to do it and kinda piecing together everyones suggestions, and this is the newest idea I had:
For the Feed line, I was thinking of taking out the oil drain and replacing it with the appropriate fittings. This way, I know that the tap has the structrual integrity, and will be seeing a lot of oil, so less chance of a dry suck.
For the return line, I was thinking of just tapping something like the dipstick where it has no real bearing on the oil pan, but the oil will still be returning.
This seems like it may work, but any input on this? It seems like the safest and easiest routh.
Old 03-10-2006, 07:01 PM   #20
joema
My Ride: 2003 330i SP 5-speed
...I was thinking of taking out the oil drain and replacing it with the appropriate fittings...
That's a good point. Why don't supercharger kit mfgs (Technik, etc) that require tapping the oil pan do this instead?
Drilling and tapping the oil pan seems very iffy. Drill/tap into the pan, let the metal shavings fly and hope for the best? You could drop the oil pan (although the installation instructions don't specify that). But how many installers drop the oil pan?
I don't think ESS requires tapping the oil pan. However don't know what they do instead.
joema is offline   Reply With Quote
