Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Old 03-14-2006, 09:35 PM   #41
Lay2Low
My Ride: Psshht Widebody; M3
Send a message via AIM to Lay2Low
So that can pretty much go anywhere that will always get oil, like the drain plug for instance?
Turbocharging has already racked my brain!
Lay2Low is offline   Reply With Quote
Old 03-14-2006, 09:43 PM   #42
Solid
Solid's Avatar
My Ride: `07 335i Sedan
Send a message via ICQ to Solid Send a message via AIM to Solid Send a message via MSN to Solid Send a message via Yahoo to Solid
no, it needs to be pressurized oil. There's an area you can hook right into near the oil filter.
Solid is offline   Reply With Quote
Old 03-14-2006, 09:45 PM   #43
Lay2Low
haha, awesome, thanks for the help. Do you happen to have any pics of this point? Any more descriptive description? Thanks so much
Old 03-14-2006, 10:01 PM   #44
Solid
Solid's Avatar
not really, i'm not even sure if that's the only place you can do it, it seems a little far from where the turbo would be.
Old 03-15-2006, 02:15 AM   #45
Oshin02
My Ride: turbo E46/M3/MCoupe
Send a message via AIM to Oshin02
are u askin for the oil return or feed now?<==lost ...lol
I am, CARBON MAN.....
Oshin02 is offline   Reply With Quote
Old 03-15-2006, 03:11 PM   #46
Lay2Low
I know, this whole thing has made me lost so many times! This time, I was asking about the optimum place for the FEED line!
Old 03-15-2006, 03:14 PM   #47
Solid
Solid's Avatar
http://www.realoem.com/bmw/showparts...01&hg=11&fg=30
Old 03-15-2006, 06:07 PM   #48
zolti@technik
Past Site Sponsor
My Ride: R1
best location is by the oil pressure sending unit
zolti@technik is offline   Reply With Quote
Old 03-15-2006, 10:03 PM   #49
Lay2Low
That looks perfect. Where can I purchase one of those adapters, or is that one OE? What is the size of that? Specifics on it? Best way to tap it?
Old 03-16-2006, 02:47 AM   #50
Oshin02
where is this specificly?
Old 03-16-2006, 05:29 PM   #51
plunderbunny
My Ride: 99 Cavalier
Originally Posted by Solid
The feed is pressurized so it should be ok.
so what you are saying is that oil is under pressure as it enters the bearing in the turbo/sc, but on exiting is no longer under pressure? wouldn't the pressure from the feed line pressurize the return and push the oil into the pan?
plunderbunny is offline   Reply With Quote
Old 03-16-2006, 11:21 PM   #52
Lay2Low
Specific location and hardware needed? Please!
Old 03-18-2006, 08:52 PM   #53
Lay2Low
bump
Old 03-18-2006, 10:10 PM   #54
BimmerDude18
My Ride: 1998 528i
No offense, but are you building a turbo kit and can't figure out how to plumb an oil feed line like that? I certainly hope you are getting some outside help on this. Not saying I could do that, but I wouldn't take a turbo kit on by myself either.
You should find a local shop, an import shop might be better (hondas, toyotas, nissans, etc) since there are more turbos run on those cars, and see if they can help you with the hardware side of this. From the DA turbo page you need a bango bolt that is pretty long, and two of those connectors for it.
-Tyler
1998 528i 5-speed Work in progress
1988 Toyota Pickup (4WD 5-speed) daily
2007 San Marino Blue 350z 6-speed sold
1996 328i 5-speed sold
www.e46nonM.com - www.precision-sport.com - www.flyingwindowtinters.com - www.techniquetuning.com
BimmerDude18 is offline   Reply With Quote
Old 03-18-2006, 10:24 PM   #55
Lay2Low
Hey none taken. I have my kit fully done and wanted to know as much about the install process, even though I will most likely NOT be doing it myself. I like to know what is going on with my car, if I am hands on or not. I just want to make sure that I know where everythig goes, and how it works.
My kit has been tried and tested by a very reputable member on the boards, so I am fully confident in it!
Old 03-18-2006, 10:39 PM   #56
BimmerDude18
My Ride: 1998 528i
Oh ok, completely gotcha there. Even if I take my stuff to a mechanic I try to learn what hes doing so I can watch it to, I just had this bad feeling that it was a DIY (I've watched friends waste thousands this way) and you were going to end up in a bad situation if something went wrong.
GL with it all, its pretty well over my head
-Tyler
Old 03-18-2006, 10:40 PM   #57
Lay2Low
Old 03-19-2006, 04:55 AM   #58
Oshin02
you did not put the kit together yourself?
Old 03-19-2006, 12:03 PM   #59
Lay2Low
Nope, it was from a fellow fanatic
Old 03-19-2006, 05:51 PM   #60
plunderbunny
well, best of luck with the turbo anyway.
