Car Care & Detailing
Get detailing answers and tips here |
#1 |
compound vs polish
Can any one explain to me what the difference is. I have tried googling the topic and they seem to be pretty much the same. If I am looking to have surface scratches/swirls removed which process should i pursue.
![]() 2007 GTI 4 Door (MKV)- Current 2010 Acura TSX (cu2) - Retired 1987 BMW 325i (e30) Vert - Burned Down 2002 330i (e46) - Retired ZPP - ZCW - ZSP - Nav - Bi-Xenon/85122+ - Mtech - 18" CSL - FSD's - 4300k Fogs- Sig courtesy of fskarboe |
#2 |
Have you tried CLAYING it first with a non-aggresive clay bar? Depending on your color and how bad the swirls are. Clay normally takes out most swirls and even scratches. It has to be done a certain way though b/c you could mess your paint job up if done improperly.
#3 |
Past Site Sponsor
Compounds and polishes are similar. They usually differ by the amount of abrasives they contain (usually aluminum oxide ) . The larger the particle size and the larger the quantity the more aggressive the solution is. Think of compound as liquid sandpaper. Just like sandpaper, compound comes in a multitude of grits. Some compounds like Menzernas Power Gloss are aggressive at first and then begin to break down in size becoming more and more fine, turning into a polish. Compounds are the most aggressive. polishes are used to removed compounding marks and glazes are used to feed and fill minute blemishes (on some occasions, glazes do contain super fine abrasives).
My personal choice of paint care would be as follows: Menzerna Power Gloss with a medium cut foam pad Menzerna Intensive Polish with a light cut foam pad Menzerna Final Finish with a ultra light foam finishing pad Seal with FMJ followed by P21S Carnauba Wax The steps listed above are assuming the paint problems are pretty bad. Always start with the lighter of the steps. For example, I would start with the Final Finish on a panel. First work it in, wipe the panel down and inspect it. If the mperfections are still present move up to the Intensive Polish. If the Intensive Polish is unsuccessful, move to to the Power Gloss. I hope this help a little. If you have any question, don't hesitate to ask. Brett @ OCD |
#4 | |
Great explanation Brett on the question at hand.
![]() Wash & Dry Products, Clay Bars, Polishes, Sealants, and Waxes 10offe46 - Discount Code for 10% Off for e46fanatics members Detail University - Detailing Enthusiast Discussion Forum |
