Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 03-08-2006, 07:19 PM   #1
brew
My Ride: F150 X5 MR2
What's the point of the center channel?
So I'm kind of an audio nut. Mostly 2 channel stuff - with a big vinyl collection and fancy homebuilt speakers and a dedicated 2 channel stereo room, etc.
I also have a 5.1 surround system in our tv room.
Our bedroom tv system is just 2 channel (but with pretty nice speakers).
One thing I've noticed is that the center channel in the 5.1 system is completely unnecessary. A centralized image can be created with the front left and right speakers alone. On my dedicated 2 channel system it reproduces a very believable 3 dimensional image of instruments located at any point between the speakers and beyond the speaker plane. On many recordings there are also sounds coming from outside the speakers and from behind me (accomplished using phasing tricks like on Dark Side of the Moon)
On my 2 channel video rig in the bedroom I don't miss the center channel at all - all of the voices are perfectly located on the screen . . in fact it's slightly better than a center channel because you don't have voices coming from above or below the screen.
So my question is this - what's the point of having a center channel of audio and a center channel speaker anyway? How is 5.1 any better than 4.1?
brew is offline   Reply With Quote
Old 03-08-2006, 08:11 PM   #2
blownE30M3
My Ride: 2004 JB M3
Send a message via AIM to blownE30M3
Area effect. Motion trailing. And voices mainly come from a the center channel in a properly setup surround 5.1 system. A center channel is not neccesary when listening to music audio, but is crucial for viewing movies.
Home Automation and A/V Programming
http://www.xsdesignstudios.com
blownE30M3 is offline   Reply With Quote
Old 03-08-2006, 08:14 PM   #3
JBimmer01
My Ride: 335i
More is better?
I think for movies the center is mostly for voice, and the 2 front sides are for other frontal sound.
JBimmer01 is offline   Reply With Quote
Old 03-08-2006, 08:22 PM   #4
brew
I'm not quite sure what you said. But after thinking about it I'm guessing that a well defined centralized image cannot be created (i) when the L and R front speakers are poorly positioned, or (ii) when the viewer is sitting outside the ideal viewing area. Someone sitting way to one side, for example, would not hear a centralized image - they would hear dialogue come from the closer speaker and think "WTF?".
In if this is the case then I think it's fair to say that the central channel is unnecessary if the viewers sit between the two speakers and the speakers are properly positioned. In that case, the viewer will hear a pinpoint image as good as, or better, than can be created by the center channel. For a 5.1 signal, the center channel info can just be fed through the L and R front speakers.
Old 03-08-2006, 10:25 PM   #5
blownE30M3
My Ride: 2004 JB M3
Indeed. Out of place and not tuned can be hazardous to sound imagind and reflection. But then that depends on the speaker type as well. The center channel is very neccesary as it is the focal point of all direct audio. Try this. Try hooking all your speakers up including the center, play a movie, listen for a bit and unplug the center. See what happens.
Old 03-09-2006, 01:38 AM   #6
sycE46
My Ride: 323ci
I see your point. Some of my friends had badly positioned center channels (due to the aesthetics of placing the center channel). In those cases.. .the surround system sounded much better when you turn it off. that way the 2 main speakers take care of the vocals. Also in systems where the center is too small, and the main speakers are bigger. It sounds better just using the main speakers instead of the center.
My guess the center is probably for imaging for viewers that aren't completely centered. If you're not in the sweet spot between the 2 fronts, your imaging isn't going to as good.
sycE46 is offline   Reply With Quote
Old 03-09-2006, 03:26 PM   #7
James330I
Imported Redneck
My Ride: BMW baby 330i 5spd
Send a message via AIM to James330I
but wouldn't a movie mixed for 5.1 lose some of its dynamics when you combine L/C/R and remove the Center. Sound editors put 80% of sound information on the center channel. Channel seperation would be awful if you took it away and tried to intergrate Ctr info on your L and R speakers
(i.e. when a plane passes by and you can hear and feel it coming from extreme left, across the screen and then out the right speaker...I would say channel seperation would be important for effects like that)
2001 Dinan 330I 5spd (gone..what an awesome car)
2013 335i 6spd M-sport
2013 Infiniti M37S
James330I is offline   Reply With Quote
Old 03-09-2006, 03:54 PM   #8
brew
I don't think so. 2 speakers can create that effect perfectly.
Old 03-09-2006, 04:08 PM   #9
blownE30M3
My Ride: 2004 JB M3
Maybe this requires an explanation of what Surround sound is.
I'll find ya'll a link in a minute here but heres a summary. Surround sound isnt a matter of levels on certain speakers. It is infact software which is hardwired into receivers. Hence the reason you have different modes with different receivers. It decodes the digital source feed and places it according to the software. So James you are correct. A film, filmed in Dolby Digital 7.1-9.1 (they never film in 5.1) would sound best in those appropriate settings.
When you change modes to a stereo output. Either your 7 channel, 2 channel, what have you, you negate the software installed for surround sound decoding and place the load on all the speakers. There is no decoding done by the receiver, it is purely spitting out the level.
Does this make sense? Like I said I will try to find a clearer explanation.
Old 03-09-2006, 07:57 PM   #10
djsway
My Ride: 2004white 325ci baby
Good question, but really if you could duplicate center imaging with two side speakers then alot of companies that are making 5.1 and up speakers/ receivers would be out of business huh?
2004 325ci
Spt pck,
Moonroof,
so far...
-edit- BMW front license plate!
-edit- E60 M5 engine transplant
djsway is offline   Reply With Quote
Old 03-10-2006, 12:19 AM   #11
trippinbillies4
trippinbillies4's Avatar
My Ride: '02 Mini, '13 FR-S
Nope. Bose would be out of business if they didn't market well. Same thing with 5.1. Rear surrounds arguably provide something the fronts can't, but a center can be "phantom" if the 2 fronts are staged correctly.
__________________________________________________
'02 Mini Cooper #40HS, '13 Scion FR-S #40CS, '12 Ducati SF848
trippinbillies4 is offline   Reply With Quote
Old 03-10-2006, 11:20 AM   #12
E46M3Rod
My Ride: 2001 Jet Black M3
You don't miss the center channel....because YOU are sitting in the "middle/center". If somebody is not....this is where you notice it is missing and doesn't quite sound right. Hope this helps.
E46M3Rod is offline   Reply With Quote
Old 03-10-2006, 11:25 AM   #13
blownE30M3
My Ride: 2004 JB M3
Is anyone even fukin reading what I type?
Old 03-10-2006, 04:08 PM   #14
brew
If you just unplug it then it would sound bad because you have all that center channel information going nowhere. If that center channel information is added to the L and R front speakers (attenuated by 3dB so the L+R combined level for this information is the same) and you sit in the sweet spot then it will sound the exact same.
I just realized why the center channel is important: With music you have no visual image that you need to sync the sound up to. If you're sitting off center, you'll hear the central image biased towards the closer speaker, but you'll still enjoy the music just fine. But if you have a visual image that the sound is supposed to sync to - and the audio image is off to the side of the screen, then it will cause a disconnect in your brain and it will sound just plain wrong. The center channel locks the center audio image to the screen no matter where you sit so you avoid this problem entirely. Makes sense now.
Old 03-10-2006, 05:25 PM   #15
baller99
My Ride: My whip
In my opinion the center channel is one of the most important additions to home theater other than the dvd, historically.
baller99 is offline   Reply With Quote
Old 03-10-2006, 05:30 PM   #16
djsway
Cute sig!
2004 325ci
Spt pck,
Moonroof,
so far...
Old 03-10-2006, 05:56 PM   #17
blownE30M3
My Ride: 2004 JB M3
Originally Posted by djsway
Cute sig!
Yours is better.
Old 03-10-2006, 05:56 PM   #18
baller99
My Ride: My whip
dd 7.1-9.1? never heard of it.
Old 03-10-2006, 06:07 PM   #19
blownE30M3
My Ride: 2004 JB M3
You will shortly.
Old 03-10-2006, 06:08 PM   #20
baller99
My Ride: My whip
You will shortly.
No go ahead now.. you say all films are filmed in 7.1-9.1?
