Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 03-14-2006, 09:09 AM   #1
GBX330ci
My Ride: 2011 Cayenne 6sp
Send a message via AIM to GBX330ci
Just hooked up using HDMI.....
So, i finally bought an HDMI cable to replace the component that came with my cable box. I have a SA8300HD. I noticed that thru hdmi i have the option of different displays - 1080i, 720i, 420p and 420i. They can all be active or only one can. When all are active, i notice that regular tv displays in 420i, but when i only have 1080i active, then that's how it will display. How should this be set-up? Should I only have 1080i active?
Also, i can't decide if regular (non-HD) TV looked better with the component cable or with my new HDMI cable. Does regular TV usually look better on a particular cable.
By the way, i have a Panasonic HD Plasma and bought monster HDMI400 Cable. Any help or insight into this would be appreciated. TIA!
GBX330ci is offline   Reply With Quote
Old 03-14-2006, 01:17 PM   #2
James330I
Imported Redneck
My Ride: BMW baby 330i 5spd
Send a message via AIM to James330I
You won't see much difference with regular cable TV over HDMI. The source signal is garbage so you'll still see garbage. Garbage in, garbage out.
Depending on your TV set, you may or may not even get an improvement of your HDTV over HDMI/DVI then with component - but hey, if your TV has HDMI, you might as well use it.
Also, return the monster cable HDMI. $10/20 HDMI/DVI cables perform exactly the same. Digital is digital - you either have 100% of it or 0%..a higher grade sleeve plastic or extra titanium-copper insulated housings really don't do anything under normal operating environments
2001 Dinan 330I 5spd (gone..what an awesome car)
2013 335i 6spd M-sport
2013 Infiniti M37S
James330I is offline   Reply With Quote
Old 03-14-2006, 01:42 PM   #3
soheilm3
bored.
My Ride: definitly not an m3
Send a message via AIM to soheilm3
i to have the sa8300hd and still am unsure as to what settings to keep things lol! i do have 720p up for my tv's native res, but for stand channels it utilizes 420p if i remember correctly. with hdmi vs component i noticed the diff on the hd channels, it was very apparent when noticing things like the channel logos and what not.
cheers
--soheil
Women are:
Taken
Smart
Beautiful
(pick 2 of the three only)
soheilm3 is offline   Reply With Quote
Old 03-17-2006, 10:49 AM   #4
MFarrZHP
My Ride: Has 6 speeds
Thanks, you just answered the question I was going to ask. I just got my TV last night, and I was going to pick up an HDMI cable, mainly b/c it will replace the bulkier component cables.
Where is the best place to go for cheap cables? Radio shack? I dont want to buy online, b/c I'm too impatient to set it up.
MFarrZHP is offline   Reply With Quote
Old 03-17-2006, 11:46 AM   #5
FloridaE46
FloridaE46's Avatar
My Ride: *****
Pretty much online only or phone order....
or you can buy something like the samsung hd upconverter dvd player... that comes with an hdmi cable u can use for the cable box then just hook up the player with componet....
** Removed annoying animated image - Tim330i **
**Thats's Racist**
FloridaE46 is offline   Reply With Quote
Old 03-17-2006, 12:08 PM   #6
zbeam3
My Ride: VQ35
http://cablewholesale.com/
zbeam3 is offline   Reply With Quote
Old 03-17-2006, 08:50 PM   #7
Surkol M
My Ride: 07 tC
Send a message via AIM to Surkol M
+1 for cablewholesale.com A cable I ordered was out of stock so they gave me the higher end version for the same price.
Surkol M is offline   Reply With Quote
