Old 08-03-2015, 09:44 AM   #1
bigpimpinge46
Rear end bushing tool diy
I had to remove my rear carriage bushing and found out you can use 2" & 2-1/2 coupler found in the electrical dept. At home depot. Grade 5 threaded rod , some nuts and some bar stock or part of a harmonic puller. Cost me under 20 bucksII'll add pic later
bigpimpinge46 is offline   Reply With Quote
Old 08-03-2015, 02:51 PM   #2
bigpimpinge46
Pics
Old 08-03-2015, 02:52 PM   #3
bigpimpinge46
Pics2
Old 08-03-2015, 09:23 PM   #4
markusmarkus
My Ride: 2001 330Ci
So you were able to remove that bushing without cutting anything and without dropping the differential? Hats off to you!
Old 08-04-2015, 12:37 AM   #5
JasonSmithed
My Ride: 00 323i
Nice. I'll be doing it this way. One of these days.
JasonSmithed is offline   Reply With Quote
Old 08-04-2015, 01:13 PM   #6
markusmarkus
My Ride: 2001 330Ci
Could you please provide a list of parts? That would be great.
Old 08-04-2015, 01:57 PM   #7
SilberVogel
My Ride: 2002 330Ci Conv.
^ Agreed. Would also like to see if a similar setup is possible for the smaller front two. Makes sense to do all three while you’re under there.
I just did this a couple months ago and rented the Koch tools from drummr8 (plug for a friendly forum member: http://forum.e46fanatics.com/showthread.php?t=1064659). Whether you rent the tools or make your own, though, having something like this is immensely easier than other methods.
DIYs help you save money with repairs; let www.bmwpnpc.com help you save money with the parts.
SilberVogel is offline   Reply With Quote
Old 08-06-2015, 03:31 PM   #8
Kye7
My Ride: BMW 2003 330xi
I would love to see a DIY on this!! Or at least some more details and pictures of all the stuff and how you did it
Kye7 is offline   Reply With Quote
Old 08-06-2015, 03:43 PM   #9
SilberVogel
DIYs for the differential bushings should cover everything you need. Just replace the Koch tool with the one OP pieced together. Here are some links: http://forum.e46fanatics.com/showpos...1&postcount=71.
