Thread Tools Search this Thread Rating: Thread Rating: 12 votes, 4.92 average. Display Modes
Old 03-22-2006, 01:28 PM   #21
951Tom
My Ride: 2001 BMW 330ci
Definitely don't jack on the silver oval piece on a 330 coupe. That's just a aluminum cross brace that isn't designed to take the full weight of the car's front end. It just gives the chassis some more rigidity.
Tom
'01 330ci
951Tom is offline   Reply With Quote
Old 03-22-2006, 01:28 PM   #22
951Tom
Tom
'01 330ci
Old 03-23-2006, 12:23 AM   #23
dirsh
Hawaii 3.0
dirsh's Avatar
My Ride: sanbyaku sanjuu
I've thought about using ramps for the front and then jacking up the rear and using jackstands. Do you guys think this is safe?
Hello dirsh it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
dirsh is offline   Reply With Quote
Old 03-23-2006, 12:30 AM   #24
vaio76109
My Ride: Race Cars
The engine subframe is above it though.
vaio76109 is offline   Reply With Quote
Old 03-23-2006, 12:34 AM   #25
vaio76109
My Ride: Race Cars
I dunno how safe it is, but I've done it before
Old 03-23-2006, 01:19 AM   #26
Keem
My Ride: MB e320/Pink Jeep
Why wouldn't it be safe? I'd get under a car with ramps before I would get under one with jackstands any day. Most ramps are rated up to like 10,000 pounds.
//Custom SSR GT3 Syle Wheels//12" FI SSD//CarPC//
//Tein Coilovers//5% Tint//Aluminum ACS Pedals//
//2 JBL Amplifiers//CDT Components//ZHP//
Keem is offline   Reply With Quote
Old 03-23-2006, 01:46 AM   #27
dirsh
Hawaii 3.0
dirsh's Avatar
because the front end, which is on ramps, could still roll
Old 03-23-2006, 08:45 AM   #28
Lugnut2683
My Ride: Lotus Elise
Send a message via AIM to Lugnut2683
r0x, great writeup! I guess BMW assumes that people nowadays don't work on their own cars, I've had a hell of a time trying to jack my car up as well. I was helping my buddy work on his Lotus Elise, and it's the same story there, because the whole underbody is an aluminum diffuser. So unless you take apart the entire underside of the car, you can only really jack the car up at the 4 "jack-points" like on our Bimmers.
Another reason why I'm excited about getting a lift.
- Justin
DIY Garage Build (Updated November 18, 2009):
http://forum.e46fanatics.com/showthread.php?t=297607
Lugnut2683 is offline   Reply With Quote
Old 03-23-2006, 02:43 PM   #29
buddy325i
My Ride: 2002 325i
To prevent the car rolling, I ended up buying a ramp for the front and I think they are great. When I only have the fronts up on a ramp, I put my car in R, emergency brake on, and use wheel chokes. When I want the whole car up, I put my front under ramps, and use the subframe (U-shape) to lift up the car and place two jacks on the rear rubber sides.
buddy325i is offline   Reply With Quote
Old 03-23-2006, 02:53 PM   #30
LoveMyBMW
My Ride: 2004 330i sedan
Wink
I, too, used front ramps, one hydraulic jack, and 4 jack stands. Here's a good DIY on jacking up an M3 (I just used the same techniques on my 330)
http://m3.madrussian.net/diy_jacking.shtml
LoveMyBMW is offline   Reply With Quote
Old 03-27-2006, 01:37 AM   #31
dirsh
Hawaii 3.0
dirsh's Avatar
OK so if I use ramps for the front and put the rear on stands how do I get the front onto jackstands? I don't think I have a jackpad like that m3 right?
Old 03-27-2006, 12:25 PM   #32
buddy325i
My Ride: 2002 325i
Dirsh, if you are planning on using ramps for the front, why would you need to place the jackstands for the front? Unless you are working with wheels, there's no need to place jackstands in the front with ramps.
Old 03-27-2006, 06:04 PM   #33
dirsh
Hawaii 3.0
dirsh's Avatar
If I need to do brakes or suspension work
Old 03-27-2006, 06:24 PM   #34
vaio76109
My Ride: Race Cars
Then just jack up the front, no need for ramps.
Old 09-08-2006, 01:07 AM   #35
Erick Sermon
My Ride: 2000 323Ci
i'm glad i found this - i had no idea i could jack from the rail. I ended up denting my skidplate.
As for the 2 jacks - not needed - its faster and way cheaper to just put a piece of wood in front of each front wheel. Drive up on to the wood then place your jack underneath. Make sure the wood stays in place when you're bringing the car down otherwise you can't get it out from under the car.
Thankfully I found this post - i had no idea how it gets done on coupes. M3s have it perfectly set up.
Erick Sermon is offline   Reply With Quote
Old 09-08-2006, 06:50 AM   #36
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Yeah...sticky this. I just bought a racing jack from Harbor Freight Tools on sale for $60. I would have gotten 2 if I would have seen this earlier
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 09-08-2006, 09:06 AM   #37
Asterisk*
Banned User
My Ride: gives me blue balls
Send a message via MSN to Asterisk*
Mad props to r0x!
Asterisk* is offline   Reply With Quote
Old 09-14-2006, 08:22 PM   #38
951Tom
If you jack directly on that oval on the aluminum subframe, you'll crush it until it compresses against the main crossmember...only then will you begin to lift the car.
Tom
'01 330ci
Old 09-22-2006, 09:55 PM   #39
bigjae1976
bigjae1976's Avatar
I just jacked my car up and I can say that this DIY is right on the money. I used a $60 low profile jack from Harbor Freight tools. Worked great. Only took 10 minutes to put my car on stands.
Old 09-23-2006, 07:25 AM   #40
Adenosinebambam
Adenosinebambam's Avatar
My Ride: My Ride
Great write up! I always used this method and have had to probs. My car is too low for ramps.. I just push em across my driveway..
All of my FS items may be listed on other forums as well. Thanks.
~Tom
Adenosinebambam is offline   Reply With Quote
