Thread Tools Search this Thread Rating: Thread Rating: 12 votes, 4.92 average. Display Modes
Old 10-09-2010, 11:10 AM   #81
i heart haters
My Ride: E46 M3 (Sold)
Originally Posted by tony325ci_51 View Post
The problem: Standard ramps are too steep for low cars.
The solution: Make some pre-ramps from a solid length of wood 7cm square (or 3" x 3"). Each is 17" long.
The wooden pre-ramps can then be moved out of the way if you wish to use the front OEM jacking point for a jack or stands.
Remember to put the pre-ramps back in place before backing off, and back down slowly to avoid the suspension compressing when you hit the pre-ramps.
I won't post exact dimensions as your ramps may be different (my blue ramps are from Halfords), you would have to measure to fit but you get the idea.
This is awesome! I have been trying to figure out how I am going to get a jack under my car after I install my new suspension, looks like I will need to make a few "mini" ramps.
i heart haters is offline   Reply With Quote
Old 10-30-2010, 12:50 PM   #82
Born Again
Born Again's Avatar
Location: Tis quite a statement. Where do you live - where do we all live? in our minds? our souls? our bodies?
My Ride: She aint much 330ci
hmm - dont have 2 jacks but great write up
4 jack stands and 1 jack - that sounds like a porn
best mod to date : OEM grocery bag holder
Originally Posted by Zell View Post
E46Fanatics - the Honda community of gun owners. Keep staying classy, I'm sure you all are going to be excellent examples of how to keep gun rights from being infringed. :facepalm:
Born Again is offline   Reply With Quote
Old 07-10-2011, 07:13 PM   #83
Budda9
My Ride: 2011 VW Golf
I learned the hard way yesterday that you cant jack up one side at a time of the front and put it on stands easily; I had the front right on a stand@ the jackpad, and was slowly jacking up the left, when i heard an odd "scrunch" sound, the car didn't seem to move, but i went around and checked the passenger side to find the stand up into the side skirt It had slid about 1-2" off the pad.
2.75" x 1" hole punched right through, thankfully it didnt seem to bend the body shell behind it any.
I jacked it back up by the pad and extracted the stand, then decided to do my brakes one corner at a time with the stand under the closest pad!
My 2003 sedan has the oval shape and it looks to be pretty crushed already, so next time i do the oil i will jack from there.
I did make myself some nice 2"x12" mini ramps to gain clearance for the low profile jack to hit the area in red others have referred to, next time i will try jacking from the oval and putting the stands under the framerails.
2003 - Orient Blue 325i : Orion Lite AEs - Otherwise stock
Budda9 is offline   Reply With Quote
Old 10-18-2012, 07:09 PM   #84
Hafex
My Ride: E46 330D & E30 325i
here's a stand me and my friend use
Hafex is offline   Reply With Quote
Old 10-18-2012, 08:14 PM   #85
straight_beamin
My Ride: 2000 bmw 323i
What a death trap
straight_beamin is offline   Reply With Quote
Old 10-18-2012, 08:42 PM   #86
Hafex
yeah it really is a bit nerve racking being under the car like that
Old 10-24-2012, 05:26 PM   #87
Zell
Zell's Avatar
My Ride: so turbo wow
So: Green area is bad, yes or no? E46Mango says very bad, and from what I have heard he is an engineer, and I trust engineers when it comes to structures.
People who regularly jack there, chime in please.
Old 10-24-2012, 05:29 PM   #88
Alex323Ci
My Ride: M3 & 323Ci (sold)
Exclamation
this is one of the most frightening things i have seen on this site. please Please PLEASE no one do this every again
Old 11-11-2012, 05:52 PM   #89
STREETFIGHTER50
My Ride: '04 Sil-Gry ZHP 6-Sp
Wow! Thats wiggity!!
STREETFIGHTER50 is offline   Reply With Quote
Old 03-10-2013, 08:30 AM   #90
miaM7
My Ride: 04 325i Sp
Hi r0x, is there a chance when lifting from the rear, that the car slides either forward or backwards on the two front jack stands ? the rear jack would have to move when lifting the rear so as such the car doesnt move, right?
Originally Posted by r0x View Post
Now lift the car up high enough to get your jackstands under the rear rubber jack points.
Lower the car onto the jackstands, and you're done. Enjoy, be safe, and happy modding.
And uh, this is why using just one jack is bad, lifting from either side:
Note the dents in my side-skirt where the jackstand dug into the bodywork. Nice, right? Try to avoid that. Use two jacks.
miaM7 is offline   Reply With Quote
Old 04-01-2013, 01:41 PM   #91
jason330cic
My Ride: 2001 330cic
Most jack stands don't fit right on the rubber jack pads. It's best to use flat top jack stands with pad adapters on top.
Jason330cic
jason330cic is offline   Reply With Quote
Old 04-01-2013, 10:00 PM   #92
evanescent03
My Ride: e46 M3, carbon black
i think i'm going to try a set of these but without jack pad adapters. i use my jack which has a flat top without adapters. yes, jack points gouge the rubber pad slightly but i'd rather have fewer pieces to the puzzle, personally. i'm really not sure why no one has designed replacement plastic jack points that are solid/rounded plastic/rubber that would fit into the groove of typical jack stands??? it's annoying to have to spend $200+ on jackstands to prevent crushing the jack points.
all i want to do is have my car on jack stands to make changing brakes/wheels/brake fluid easier. is that SOOOO much to ask?? haha. ridiculous!
anyway, thanks for reminding me about these flat top stands. i've been looking for one with a solid top that i could cut down and stick up inside the jack point which isn't a bad option either, but i don't really like cutting down jacks stands either. then they're useless on any other car, too.
another guy made these adapters that fit OVER a jackstand and INTO a jack point. pretty nice actually.
http://www.e90post.com/forums/showth...=652459&page=2
(post #26)
matt
evanescent03 is offline   Reply With Quote
Old 05-26-2013, 06:48 PM   #93
sentry
My Ride: Land Rover LR3
ROFLMAO!
sentry is offline   Reply With Quote
Old 08-10-2014, 10:40 PM   #94
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
I know this is an old thread, but thought I would offer what I do.
When I am just working on one corner, like for a tire, brakes, suspension, etc., I have a cheap scissor jack from Harbor Freight Tools that I slip under the frame rail near the jack point and raise the car up using that. I put a piece of wood or rubber between the jack and frame rail for protection. The scissor jack is really short and can reach way under the car.
Once it is jacked up I put a jack stand under the normal plastic jack point with a couple short pieces of old radiator hose slid onto each tongue of the jack stand for protection. Then I lower the car onto the stand. I keep the scissor jack in place with enough force, maybe 100 lbs or so, as a backup for the jack stand and for stability in case I need to yank on the suspension.
Old 09-09-2014, 07:52 AM   #95
DEADF15H
My Ride: 2001 325i Auto
I don't even want to think about what vertical compression those 55 gallon drums are rated at, certainty not enough to hold up a 330i. Not to mention everything else that's wrong with this picture. Surprised there weren't some concrete blocks thrown in for effect.
Please do not get under this car, that's just scary.
DEADF15H is offline   Reply With Quote
Old 05-25-2015, 06:21 PM   #96
nallman
My Ride: 2004 330xi
I have a smaller jack (2 1/2 ton) and it's damn near impossible to reach under the car and push on the lever if the jack is all the way under the subframe near the rear diff. Does anyone have advice on how to extend the jack handle or create more leverage? I can take pictures if it helps.
And before you say "just add a long pipe", it won't work because the jack handle angles up toward the bottom of the trunk as is. Adding a pipe doesn't give the jack enough range of motion to actually lift anything.
nallman is offline   Reply With Quote
Old 05-25-2015, 09:55 PM   #97
330iPilot
My Ride: Titanium Silver 330i
I just lift the rear end a bit myself, that gives me enough room to start and as the jack pushes the car higher you get more range of motion..
330iPilot is offline   Reply With Quote
Old 05-26-2015, 07:14 AM   #98
DEADF15H
Drive up on 2 X 6s.
The problem with our stock low suspension, is a "low profile" jack is the easiest way to access.
Old 05-28-2015, 05:22 PM   #99
taylor192
My Ride: 2003.5 M3
I always place the jack stands in the pads like this. Never had a problem on my previous Mercedes or on the BMW.
Old 07-03-2015, 09:38 AM   #100
Elbuho
My Ride: 2002 330ci
Thanks r0x!
I have been searching everywhere to figure out the best way to jack my 330ci. r0x's pics are perfect...along with the entertainment from hafex.
Elbuho is offline   Reply With Quote
