Old 10-12-2002, 03:06 AM   #1
larkie
My Ride: 328i
Send a message via ICQ to larkie
Carpet removal to hide my tuner box...
how to remove the carpet on my caR??
i have a sedan...
also the door trim so i can run the wires..
larkie is offline   Reply With Quote
Old 10-12-2002, 03:19 AM   #2
Full Time Hit Man
Banned
My Ride: E46
Send a message via AIM to Full Time Hit Man
Which carpet are you looking for?
Door trim? You mean the door sill? It just pops out.
Full Time Hit Man is offline   Reply With Quote
Old 10-12-2002, 03:35 AM   #3
larkie
My Ride: 328i
Re: Carpet removal to hide my tuner box...
i have a sedan...
i need to know how to remove the door trim and also how to remove the carpet at passenger side, cause my LCD tuner box is hiding inside, and i need to connect my new amps to it..
Old 10-12-2002, 03:39 AM   #4
Full Time Hit Man
Banned
My Ride: E46
Sorry maybe a little late at night. I'm getting confused.
If you want to hide the tuner under your passenger side seat's carpet, the seats have to be come out, and there is a release screw there.
Door trim. I don't know what's that. Door sill, just pop out. Seat belt cover, just slide it out.
Hope this helps.
Old 10-12-2002, 03:41 AM   #5
larkie
My Ride: 328i
yeah door sills i meant,
I remember last time they install my alpine iva-c800 they don't need to remove my passenger seat, and they can access under the floor of my passenger side to hide the turner box..
i'm think i'm just little bit tired haha..
Old 10-12-2002, 03:45 AM   #6
Full Time Hit Man
Banned
My Ride: E46
Hum... maybe the seat doesn't have to come out, it the seat is in the highest position and you can reach your hand in. That's what I think.
Old 10-12-2002, 03:46 AM   #7
larkie
My Ride: 328i
i c ic..
thanx in advance...
I'm gonna try it out tomorrow ..
hope my DIY install of my amps works..
Old 10-12-2002, 05:21 AM   #8
E46
dubbin'
My Ride: 325XiT (retired)
Send a message via MSN to E46
run the wires under the plastic part beside the door sills. on the other side of the rubber seal.. they pull out.. kinda tricky tho
it'll lead you to the rear... then pull the back seats out and run the wires through there to the trunk
hope that helps
taking out the carpet requires you to pull out all your seats and all that other stuff.. its real messy
click on sig for more pics.
www.europrojektz.com - northwest
E46 is offline   Reply With Quote
Old 10-12-2002, 12:10 PM   #9
Mr.Stream
My Ride: '07 BMW Z4C 3,0SI
Send a message via AIM to Mr.Stream Send a message via MSN to Mr.Stream
Just remember that if you turn on the ignition when you have the seat out, the airbaglight will come on. Then you have to go down to the dealer to get rid of it. If you remove the seat and put it back in you will be fine.
Stig Johansson
Norway
Hellrot '07 BMW Z4 Coupe 3,0SI
Sparkling Graphite '06 BMW 318i Touring
Mr.Stream is offline   Reply With Quote
