Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 03-24-2006, 05:55 PM   #1
mach330
My Ride: E90 AW ///M3
HT: Rotel 1056 OSD Menu
ok..so i finally got my ht system, but i'm having trouble with the receiver osd menu. i can't for the life figure out how to get to the menu. everytime i switch to menu, my screen goes blank. i'm currently using two component input and one component. output. any ideas? i read the manual and it said that i have to have progressive on the menu, but i can't even go to the menu to change it. i've tried to hook it up to one of the composite video output, but i still can't see it. anyone else have experience with rotel 1056? i'm checking out the avsforum guys as well as the htguide forums. no luck so far.
Rated /// M
mach330 is offline   Reply With Quote
Old 03-25-2006, 03:22 PM   #2
dmoeller17
My Ride: 350Z
Send a message via AIM to dmoeller17
hmmm, my B&K ref 50 will only output on the composite or svideo, but if you have tried that already. see if there is a "hard reset" or reboot in the manual, there is one for my preamp and its fixed things before
also call the mfg, they should help. heck you can call B&K and talk to the engineers and they will help you.
from chaos comes clarity
dmoeller17 is offline   Reply With Quote
Old 03-27-2006, 03:40 AM   #3
baller99
My Ride: My whip
Few receivers/preamps will have OSD that pass through component outs. I would recommend just getting any spare composite cable you have lying around and use that.
baller99 is offline   Reply With Quote
Old 03-27-2006, 10:46 AM   #4
mach330
got it...i hooked it up to my component where it can display 480i/480p. i think the menu can't display higher than 480i. thanks guys...
Rated /// M
