Thread Tools Search this Thread Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
Old 03-28-2006, 09:49 PM   #1
Ausfahrt
Groccery Getter
My Ride: Touring/550
Send a message via AIM to Ausfahrt
DIY: Replacing Door Hinge/Door Brake
If you had your car for a while things start to wear down. The Door Brake is one of them after so many opening and closing your door the hinge will eventually break. Each door has a Door Brake. If you have four doors then you have four and if you have a two door then guess what you have only two. The way to know that your Door Brake is worn/broken is when you open your door it will close itself and not lock in place. My front passenger door did the exact thing. It would shut when I opened it and would not stay in place. Ensure your window is all the way up. This is a very easy DIY. Once the Door Brake is on you will notice the door being like factory new.
Step One
Go to RealOEM and find your part # or go to the dealership. Or you can get with a buddy like i did with ADA and order butt loads of parts and save money on shipping.
Step Two
Remove the door panel using your T20 torx screw driver. Here's a DIY
http://www.e46fanatics.com/how-tos/i...sedan_trim.php
http://www.e46fanatics.com/how-tos/i...coupe_trim.php
Step Three
Pull Back foam off of door. Again ensure your door window is all the way up.
Step Four
Use your 8mm socket to remove the Torx Bolt that's on the car. Remove the two Torx Bolt that is holding the Door Brake on the door.
Step Five
Remove the Door Brake and remove the front door brake gasket.
Step Seventh
Install new Door Brake by following instructions in reverse order. Dont forget to ad thread lock on the torx bolts when reinstalling.
Step Eight
Put everything back together and admire your work.
ID:	172896   Click image for larger version
ID:	172897   Click image for larger version
ID:	172898   Click image for larger version
Ausfahrt is offline   Reply With Quote
Old 03-28-2006, 09:57 PM   #2
Ausfahrt
Groccery Getter
Second batch of pictures
ID:	172901   Click image for larger version
ID:	172902   Click image for larger version
ID:	172903   Click image for larger version
Old 03-28-2006, 09:59 PM   #3
Ausfahrt
Groccery Getter
Third batch of pics
ID:	172906   Click image for larger version
ID:	172907   Click image for larger version
Old 03-28-2006, 10:09 PM   #4
CtrlAltDel
www.piratecove.org
My Ride: 2007 335i Coupe
Send a message via ICQ to CtrlAltDel Send a message via AIM to CtrlAltDel
nice write up!!!
Yeah I havent updated my sig yet with my 335, kill me.
CtrlAltDel is offline   Reply With Quote
Old 03-28-2006, 11:14 PM   #5
ADA
Banned
My Ride: 323ci
Hey Alex. I should get some credit for ordering those OEM parts for you!!!!!!!
ADA is offline   Reply With Quote
Old 03-29-2006, 09:55 AM   #6
Ivegotissues666
My Ride: 88' BMW E30 SETA
Send a message via AIM to Ivegotissues666
Excellent DIY! DIY's Rule!
Ivegotissues666 is offline   Reply With Quote
Old 03-30-2006, 06:59 AM   #7
Yellowmann
Rolling on Dubs. Got Boost?
My Ride: AA SC Y2K 323i
Send a message via AIM to Yellowmann
Looks good bro... I hope I don't have to change that.... I have done lots of DIY and the window regulator change, so this is a piece of cake
Once A Yellowmann, Always A Yellowmann ...One Who Is Wise - Always Learn From Other People's Mistakes ...One Who Thinks That They Can Never Be Successful - Will Never Be Successful ...First You Don't Succeed - Try, Try Again ...
Yellowmann is offline   Reply With Quote
Old 04-24-2006, 03:24 PM   #8
FrenchBoy
My Ride: '09 E90 M3
Great job documenting this DIY. I changed the door brake on the driver's side of my 325Ci - I was getting a couple of "cluncks" every time I opened the door - and now it works like a charm.
However, I had a bit of difficulty placing the new door brake inside the door due to the fact that lower sheetmetal opening - as shown in the attached photo on the sedan - in the coupe is a lot further from the door hinge. It required a lot of contorsions and swearing. I eventually resorted to using a piece of wire and fishing for the door brake thru the door brake hole while trying to push the door brake body thru the various metal brackets in the door. Painful...
BTW, I got the door brake super cheap thru Pelican Parts. They rock.
FrenchBoy is offline   Reply With Quote
Old 12-29-2007, 02:35 PM   #9
Pete2007
My Ride: BMW 3 Series Coupe
I'm having the same problem whilst opening my passenger side door, one question would I have to purchase a brake gasket along with the new door brake?
Pete2007 is offline   Reply With Quote
Old 12-30-2007, 01:53 PM   #10
Hrvat
My Ride: 02 Imola Red M3
I changed my driver's side door brake this past summer. It was piece of cake!
Thanks for the writeup thou!
PM ME FOR FREE SAMPLES
Originally Posted by roronoah View Post
so 2004 bmw's dont come with a diff?
Hrvat is offline   Reply With Quote
Old 12-30-2007, 09:06 PM   #11
Ausfahrt
Groccery Getter
No you can use your old brake gasket.
Old 06-18-2008, 11:28 PM   #12
rpiano78
My Ride: 2011 Regal Turbo
Just wanted to say thanks for the DIY (I also took the opportunity to add BSW stage 1 since i had my door apart)
rpiano78 is offline   Reply With Quote
Old 10-18-2010, 10:34 AM   #13
raptorman5174
My Ride: 330i ZHP
I just did this job this past weekend and it wasn't nearly as hard as I thought. Thanks for the DIY it helped out great!
18 VMR CSL's
Koni
Eibach Sport Spring's
UUC Power Pullies
Sprint Booster
CCV Delete
3:38 rear diff
raptorman5174 is offline   Reply With Quote
Old 05-13-2013, 04:05 PM   #14
Jayp07
My Ride: E46 3.18i, E30 3.20i
Fantastic just what I was looking for! Great write up will do mine this weekend it's such a pain when it closes on me. Dealer price is 25 + vat.
Jayp07 is offline   Reply With Quote
Old 02-24-2015, 03:18 PM   #15
Bimmer4Lyfe
Location: 129 West 81st St. 5A, New York, New York 10024
My Ride: 02 325i
Minimal cost- ($45)
Minimal time- (30min)
Huge result! Thanks for posting
Bimmer4Lyfe is offline   Reply With Quote
Old 08-17-2015, 08:39 PM   #16
ssupa68
My Ride: 323it
After reading this thread about how simple this repair was, I went outside and fixed the driver's side rear door in less than 30 minutes. Thanks Ausfahrt
ssupa68 is offline   Reply With Quote
