Old 03-30-2006, 03:48 PM   #1
pdydy
My Ride: 02
brake fluid~
Is it recommended to change the stock brake fluid for the track?
I heard that the bmw brake fluids are dot4. would that be enough?
pdydy is offline   Reply With Quote
Old 03-30-2006, 03:59 PM   #2
jun14scr
booo for body roll.
My Ride: 2009 335i.
in addition to changing brake fluid to fluid with highler boiling points, overtime as the braking system is subject to condensation, etc. water can get into the brake fluid which changes the overall properties of the fluid.
i change brake fluid atleast 2x a year and would definitely recommend swapping the stock fluid for something a little better, be it super blue, or even valvoline syn availible at local autostores.
jun14scr is offline   Reply With Quote
Old 03-30-2006, 10:10 PM   #3
Greg@UniqueDesign
Past Site Sponsor
My Ride: 330Ci
Yes I would change it. It's a regular maintenance item that most people forget. I would recommend ATE Super Blue/TYP 200 or Motul 600. You will need roughly 1.5 liters.
Greg@UniqueDesign is offline   Reply With Quote
Old 03-31-2006, 08:26 AM   #4
Asmodeus
My Ride: 328i
I second Motul RBF600.
328i - TiAg / Black with PP - HK - 35% Tint - TiAG Headlight Trim - RSM - Gauge Rings - Clears - GruppeM - Silvervision - Koni Adjustables - UUC T.M.E., Clutch Stop, DSSR, Pulleys, Swaybars, LTW - EPS Pump - SS Brake & Clutch Line - MTech II Front - Angel Eyes - M3 Lip Spoiler - Z211, K104 - M6 Wheels -
TLC/BMW Instructor
Asmodeus is offline   Reply With Quote
Old 04-03-2006, 11:53 PM   #5
mrshelley
My Ride: 2004 330i
ATE Super Blue is a great fluid. I even use it in our GT M3's. Our old 330's even ran 1400deg front rotor temps (at 3 Rivers) and the fluid never gave out. All it did was ignite after the piston was ground into the rotor (after the race). Up until that point, the pedal was just fine.
Old 04-04-2006, 12:02 PM   #6
Mr Paddle.Shift
Mr Paddle.Shift's Avatar
My Ride: B3 epsilon
Is this your first time at the track? I think it's good to just keep it as is for your first or second time. So at least you know what it means to experience spongy brakes. That's my approach and it helps me to understand the car and my driving skills a lot more. I have seen pple upgrade everything for the first track and til today they have no idea what brake fading is.
Technik Engineering ASA Stage 1.
Supercharged E46 M54B25.
2011 NASA TTC So Cal Champion!
Track blog.
Technik Engineering oil cap o-ring maintenance kit available.
Mr Paddle.Shift is offline   Reply With Quote
Old 04-04-2006, 02:21 PM   #7
leej323
leej323's Avatar
My Ride: '00 323i
Very good point.
leej323 is offline   Reply With Quote
Old 04-05-2006, 04:10 AM   #8
pdydy
My Ride: 02
yea~ it's my first time.
well, is there anyway that i can test the fading of the brakes?
cuz a friend was telling me that the fluid is essential to last the whole day.
Old 04-05-2006, 11:14 AM   #9
leej323
leej323's Avatar
My Ride: '00 323i
Your buddy is misinformed. I did my first DE on stock everything. I came out fine. You won't be pushing your car to its limit the first time out. Most of your time will be dedicated to just getting a feel for your car on the track. After that you'll want to pay attention to racing lines and braking zones.
I wouldn't recommend testing for brake fade on the street. It's best reserved for a DE or an AutoX where there's less risk of hitting an innocent minivan carrying kids (and you won't get in trouble for reckless driving either). You'll know when it's brake fade when you have your foot on the middle pedal and you have significantly decreased stopping power. Think along the lines of "OMG that corner is approaching and I don't think I can slow down enough!"
Old 04-05-2006, 01:00 PM   #10
pdydy
My Ride: 02
I was considering of buying some brake pads, is that recommended?
Old 04-05-2006, 05:05 PM   #11
rnitti
My Ride: 2005 BMW 325I
If this is your first time, unless your brakes need the maintance, I would leave them alone. Make sure that the pads and rotors are in good shape and that you brake fluid is full. Make sure all of you fluids are full and check you tire pressure to make sure they are in MFG specs.
For your first time, focus on getting around the course smoothly. Learn your turn-in and braking points. Learn to be smooth on the brakes and throttle. Take a little time and learn to steer with the throttle and brake. Learn the dynamics of understeer and oversteer.
I wouldn't run multiple events on OEM fluid, but one or two won't hurt. Who knows, you may not like it, and the upgraded pads and fluid will be money lost.
If you enjoy it and plan on doing it a lot, upgrade your pads and fluid. Remember, you're also going to go through tires and rotors faster, so keep an eye on them, too.
Generally speaking, what's good for the track and auto crossing usually make for really poor street/daily driving characteristics.
Remember more than anything, safety first! Have fun.
Just like an Idiot Savant only minus the Savant part.
rnitti is offline   Reply With Quote
Old 04-10-2006, 12:15 PM   #12
JCz04Bimmer
JCz04Bimmer's Avatar
My Ride: 2004 330Ci & 06 Z4MC
Send a message via AIM to JCz04Bimmer
Motul RBF600. Best stuff out there. I just got 3 bottle for free at the SEMA show in Philly.
It's your first time so you likely won't be pushing the car hard enough to experience brake fade but upgrading to a better fluid and doing a proper bleed can never be a bad thing either on the track or on the street. Brake fluid isn't like most "track mods" since its certainly a good thing to upgrade even for street driving. Its not like you're putting on track pads that have a certain operating temp that, on the street, won't function safely. Know whata mean?
JCz04Bimmer is offline   Reply With Quote
Old 04-10-2006, 12:18 PM   #13
vaio76109
My Ride: Race Cars
I wouldn't go that far, but it's better than ATE TYP 200/Super Blue.
vaio76109 is offline   Reply With Quote
Old 04-10-2006, 12:52 PM   #14
JCz04Bimmer
Ok, best stuff out there that can still be considered a readily available consumer production. Not a pure-bred race fluid.
Old 04-13-2006, 09:55 AM   #15
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
I <3 my super blue
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 04-17-2006, 08:35 PM   #16
pdydy
My Ride: 02
Alrite, i gotta say that stock brakes and dealership brake fluid are pretty descent for the track.
I had no brake fading at all.
How different is it with the hp plus brake pads?
Old 04-17-2006, 08:35 PM   #17
pdydy
My Ride: 02
Old 04-17-2006, 10:32 PM   #18
leej323
leej323's Avatar
My Ride: '00 323i
Motul RBF600 is good, but absorbs water faster than ATE SuperBlue. This means more frequent flushes. I like SuperBlue.
