Thread Tools Search this Thread Rating: Thread Rating: 19 votes, 5.00 average. Display Modes
Old 07-11-2010, 11:26 AM   #61
fj1200
My Ride: 2004 BMW 320i
Great Info
Great informations
fj1200 is offline   Reply With Quote
Old 07-11-2010, 11:36 AM   #62
fj1200
Thanks jared
Great informations
Old 07-11-2010, 11:45 AM   #63
fj1200
Hi Jared,
I just joined the Forum last month. Few members sent me the link for your threads, You did an amazing job , Thank you for doing that.
I tried to send you pirvate message but i couldn't , even no e-mail.
Thanks Jared
Old 07-11-2010, 11:54 AM   #64
nads12345
Account Under Review
My Ride: 03 325xiA
i have a foglight switch in great shape if anyone wants to do this...pm me
nads12345 is offline   Reply With Quote
Old 07-15-2010, 10:38 AM   #65
fj1200
Hello,
I have a 2004 bmw 320, would it be the same wiring or different one?
Thank you
Old 12-21-2010, 01:21 PM   #66
Radecki
My Ride: 2001 325i Sedan
Sick
Sent from my Droid using Bimmer App
Radecki is offline   Reply With Quote
Old 02-28-2011, 07:25 PM   #67
rguti153
My Ride: 2004 zhp / 2000 323i
Only if the links work I would understand it better need better info on the harness that connects to the relay
rguti153 is offline   Reply With Quote
Old 05-29-2012, 03:23 AM   #68
scorpion_gsv
My Ride: BMW E46 2001 Sedan
Nice DIY,
Please explain the Step 5, and if you can post diagram it will be very good. thanks.
i think that i have problem in the fog light switch , how can i test it ?
scorpion_gsv is offline   Reply With Quote
Old 12-22-2012, 01:30 AM   #69
Rezist09
My Ride: 325i sedan
Gonna do this soon
Rezist09 is offline   Reply With Quote
Old 12-27-2012, 01:49 AM   #70
Rezist09
My Ride: 325i sedan
How to wire it with just a toggle switch? What fuse / amp
Old 12-27-2012, 04:58 PM   #71
Redline
Redline's Avatar
My Ride: ///M3 Vert
What about xenon headlights? I have two from an m3 that fit in my mtech II bumper...
k.
///M
Old 12-27-2012, 05:58 PM   #72
Rezist09
My Ride: 325i sedan
How did u hold the fog lights whT brakets??
Old 03-04-2013, 09:09 AM   #73
Redline
Redline's Avatar
My Ride: ///M3 Vert
I'm stuck on finding where to put the jumper wire for the grounds.
The only grounds I see are 4-5 brown wires in a single comb connector, but no slot to put the jumper wire into to ground the headlights...wish there were more detailed pics on exactly where you are supposed to hook up the ground.
Instructions are very vague from BMW on where to jumper it, sh!ts pissing me off.
k.
///M
Old 03-04-2013, 02:33 PM   #74
Redline
Redline's Avatar
My Ride: ///M3 Vert
k.
///M
Old 03-05-2013, 09:16 AM   #75
Redline
Redline's Avatar
My Ride: ///M3 Vert
Anyone?
k.
///M
Old 03-06-2013, 11:09 PM   #76
Redline
Redline's Avatar
My Ride: ///M3 Vert
Took matters into my own hands as nobody was of help and the DIY has poor picture reference.
If your car is like mine you might find out in the joint connector box above the fuse box there is no available pins on the comb connector full of grounds (all brown wires) mine had 5 brown wires. Two bigger outer wires and three small ones in the middle.
You want to do a wire tap (I used a parallel 14 gauge wire crimp) and tap into the bigger out wires (with one, I used the right one)
I made a y connector with two male connectors on the end to connect into the ground wires on the harness from the wire I tapped into. Checked it with multimeter and it has voltage so it works. Also hear the solenoid click as well.
Ill take some pics and post them.
k.
///M
Old 03-17-2013, 01:33 PM   #77
rguti153
Sweet thankd
Old 02-02-2014, 03:04 AM   #78
Rezist09
My Ride: 325i sedan
bump
Old 02-22-2014, 08:27 PM   #79
FirstBimmer18
My Ride: 1999 BMW 323i
A few questions... some may seem dumb.. First, why are some of the materials you listed "Free"? Second, will the fog lights turn on if you only have the parking lights on or do you have to have the headlights on as well? Also, you said your bumper was being painted and thats why it wasn't in the pics.. so you are saying that all of this can be done WITHOUT removing the bumper? Thanks!
FirstBimmer18 is offline   Reply With Quote
Old 05-21-2014, 11:04 AM   #80
jyankee9
My Ride: bmw 323i
Does anyone know where I can buy the harness and how would I install it with harness and relau
jyankee9 is offline   Reply With Quote
