Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 3.00 average. Display Modes
Old 04-12-2002, 04:00 PM   #1
PCDawg
REQ'D: Tanning Lotion
My Ride: '01 330ci Convertibl
ACS pedal install Question...
I've installed my ACS pedals yesterday nite
Man.. i installed the brake pedal first, and it was a pain in the ass but finally got them on :smile:
I did the gas pedal last and it was easy.
As i cleaned everything up and admired my work, i notice the gas pedal was a bit crooked. Its not too bad, but its off like several mm upwards. i felt stupid!!!
I was wondering if i should removed it and re-drilled the holes, would the bolts and nuts hold the pedal just as tight since the holes would be very close to each other?? Or should I just leave it.....i have pics, but they are on my home computer.
PCDawg is offline   Reply With Quote
Old 04-12-2002, 04:09 PM   #2
s4play
Banned
My Ride: ML320, 02 M3, 01 S2K
Send a message via AIM to s4play Send a message via Yahoo to s4play
Should be fine....because when you clamp
it down, the new nuts will still grab the plastic at the new point. You may want to use a very thin washer behind the nut to prevent it from pulling through the hole.
I messed mine up a bit too so I just carefully enlarged the hole in the direction I wanted the pedal to go. The screws hold fine as long as the nut doens't fall through the hole.
If you need thin washers, go to a local R/C hobby shop since they specialize and small hardware for those types of cars.
rick
s4play is offline   Reply With Quote
Old 04-12-2002, 04:27 PM   #3
PCDawg
Thanks,
I'll just drill some holes to reshift it down a bit
I was just afraid that the pedal will slide up and down a bit if it wont hold still properly
Old 04-12-2002, 06:51 PM   #4
pfloyd57
Dale Earnhardt's Double
My Ride: 2001 330 Cic
I usually try to warn everyone to preposition them 1st with 2 sided tape.
Then to use a center punch to start the holes. I love my ACS pedals. With the Rockport shoes I wear the grip on the pedals is much more pronounced.
I think I'm going to replace my M dead pedal with the ACS to get the full effect.
pfloyd57 is offline   Reply With Quote
Old 04-12-2002, 07:02 PM   #5
Keeferno
Mod Junkie
My Ride: 2002 325xi
Yep, the definatly are nice. I have UUC ones and love them
Keeferno is offline   Reply With Quote
Old 04-12-2002, 07:05 PM   #6
Mr.Stream
My Ride: '07 BMW Z4C 3,0SI
Send a message via AIM to Mr.Stream Send a message via MSN to Mr.Stream
Cool Love mine too.
Stig Johansson
Norway
Hellrot '07 BMW Z4 Coupe 3,0SI
Sparkling Graphite '06 BMW 318i Touring
Mr.Stream is offline   Reply With Quote
