Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 04-10-2006, 07:50 PM   #1
rana
My Ride: 04' 320i, 03' 745Li
Can I use a car sub as a home theater sub?
Hi guys,
My secondary Home Theater sub blew out...its actually been a while...
I have a 12" Infinity car sub sitting around collecting dust...Im wondering, can I use that as my home theater sub?
The only thing is, the actual HT sub I had, had a lot of knobs and stuff at the back to control sound output....and I think it had a built in amp as well....
Hmm...will my reciever be able to power the Infinity sub on its own?
rana is offline   Reply With Quote
Old 04-11-2006, 01:27 AM   #2
sycE46
My Ride: 323ci
Most likely, no...
Most receivers can only drive 6-8 ohm speakers. Chances are... your infinity sub is either wired for 4 or 2 ohm.
Originally Posted by rana
Hi guys,
sycE46 is offline   Reply With Quote
Old 04-11-2006, 01:41 AM   #3
Three30i
My Ride: 2001 330i
http://forum.e46fanatics.com/showthr...t=home+theater
This might help you
*Sig courtesy of ArjunGFX*
Three30i is offline   Reply With Quote
Old 04-11-2006, 11:30 AM   #4
brew
My Ride: Sequoia X5 MR2 G20
Yes you can use a car sub. You'll need a separate amp. Here is a link to some good cheap plate amps for subs: http://www.partsexpress.com/webpage....up_ID=505&SO=2
Most of those should have no problem with a 4 ohm sub. If you have dual 2, 3 or 4 ohm voicecoils, make sure to wire them in series.
brew is offline   Reply With Quote
Old 04-12-2006, 01:46 AM   #5
rana
Exactly what I needed!
Thanks brew
Old 04-12-2006, 01:46 AM   #6
rana
Originally Posted by Three30i
that was helpful. Thanks man
