Old 10-15-2002, 05:19 PM   #1
ByeByeM
My Ride: 335i
What's the difference between these xenon housings?
I just bought this set of xenons but they are mismatched. As you can see in the pic, one is off a coupe and the other from a sedan. One has a slightly larger projector lens and a line in it, ther other is smaller w/o a line. My questions are:
1. is the coupe headlight (production date 10/01) from a 2002 car with bi-xenon, and is that why is has a different lens? Or is it a late 2001 with single xenon? I hooked up both the low and high beam harnesses to the housing and when I used the brights (in both the "flash" and "on" position the halogen H7 beam was illuminated, not the xenon).
2. Does the projector lens make a difference in color? I'd like the two lenses to match so I want to order another one - but I'm not sure if I should look for the large lens with a line or the smaller one.
I hope someone has some input, I appreciate any help! Thanks.
ByeByeM is offline   Reply With Quote
Old 10-15-2002, 05:33 PM   #2
Agamemnon
My Ride: M3
Send a message via AIM to Agamemnon
The left one the bigger one is BI-Xenon meaning the line there is acutally I think a peice of glass or something anyway. What it does is it lets you use both Low and hI beams with the Xenon while the other smaller xenon is just a low beam xenon. The bigger one probably has Auto leveling as well.
Agamemnon is offline   Reply With Quote
Old 10-15-2002, 05:45 PM   #3
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
All Xenons have autoleveling...
Old 10-15-2002, 05:51 PM   #4
Agamemnon
My Ride: M3
You sure about all xenons? I think the earlier ones don't and the newer ones have Auto leveling. The older ones have leveling but it's manual leveling that you have to turn a knob or something.
Old 10-15-2002, 05:51 PM   #5
ByeByeM
My Ride: 335i
Yes, but since I don't have leveling module...
I don't have a harness for it. So then the one with the line through the center is bi-xenon, right? I've heard some people saying the bi-xenon doesn't have as good of color output, so should I order another housing for a single xenon car? I'm just trying to figure out which one will look better if either. Thanks.
Old 10-15-2002, 05:56 PM   #6
E46
dubbin'
My Ride: 325XiT (retired)
Send a message via MSN to E46
all 3series xenons have auto leveling.. even the first batch of the e46 sedans back in 99 had auto leveling.
the line means its Bi-Xenon meaning you have both Highbeam and Lowbeam capabilities with the xenons
click on sig for more pics.
www.europrojektz.com - northwest
E46 is offline   Reply With Quote
Old 10-15-2002, 06:19 PM   #7
ByeByeM
My Ride: 335i
So...
Anyone want to comment on whether I should try to get another single xenon or bi-xenon light? I've searched the archives and seen a lot of people saying that their bi-xenons are too yellow (someone mentioned it's because of the Osram bulbs being used instead of Phillips). Both the lights I got ('01 and '02) are Osram.
As far as having xenon high beams it doesn't matter b/c my car won't do it anyway since the computer isn't set up for xenon highs. So I'm just looking for the better color output. Should I just buy whichever lens I can find and then get 6000Ks??
Old 10-15-2002, 06:21 PM   #8
xmltok
My Ride: 2014 Carrera 4S
Send a message via AIM to xmltok
check your pm byebyem
xmltok is offline   Reply With Quote
Old 10-15-2002, 10:15 PM   #9
ByeByeM
My Ride: 335i
Side by side comp. of bi-xenon and single xenon
Ok I don't know if anyone else has done this yet, but here is a TRUE side by side comparison between the two lights - both of them on the car. Well not exactly - they're just sitting on the top which is why they are angled a little weird. But you can still see the color difference which is noticable. The bi-xenon is slightly more yellow but seems to have a little more output.
So I still don't know which one projector lens to replace. Get a single xenon and have more blue or a bi-xenon and get 6000K bulbs...
Old 10-15-2002, 10:16 PM   #10
ByeByeM
My Ride: 335i
And here's one comparing the 4300K kit from Phoenix Microlite to the stock xenons.
Old 10-15-2002, 10:25 PM   #11
KurriMasta
My Ride: 2002 325i
IM me on AIM: wizimoto. and ill tell you how to wire your non xenon car to work with bi-xenon. i would know, i just did this!!!
:tongue:
the california sun
KurriMasta is offline   Reply With Quote
Old 10-15-2002, 10:38 PM   #12
KurriMasta
My Ride: 2002 325i
^^ by that i mean, i can tell you how to get your bi-xenon part to work....(your high beam through your bi xenon)
the california sun
Old 10-16-2002, 12:30 AM   #13
Cuore_alfa
alfisti & bimmer fan
My Ride: 01 Toyota Corolla CE
Send a message via MSN to Cuore_alfa
it is possible to get just the iner lenses?
can someoe post the OEM part #
thanks
8C Competizione
Cuore_alfa is offline   Reply With Quote
Old 10-16-2002, 01:17 AM   #14
ByeByeM
My Ride: 335i
you can find the lenses on ebay for like $200 - not really worth it when you can just get full housings for $300-400. there's no part number for it from the stealer cause it's not available without a full headlight.
Old 10-16-2002, 01:27 AM   #15
presario
My Ride: 330ci
Don't mean to hijack the thread but those two pics are hella funny!!! It reminds me of planarians!!! - you know, those retard cross-eyed looking flatworms we all cut up in science class years ago
I'm not talking about your beautiful car byebyem. Just the way the lights are positioned
Sig by Jojo//Celsius One
presario is offline   Reply With Quote
Old 10-16-2002, 02:37 AM   #16
xmltok
Old 10-16-2002, 06:12 AM   #17
OPTIMO
My Ride: Car
Are you guys sure that the line signifies bi-xenon? I got some xenons from a wreck about 4-5 months ago and put them in my car:
http://www.dspots.com/bmw/jason/
You can clearly see the line but I didn't think they were bi-xenon. If so, then I really got a steal at <$450 although if you click the DIY you can see the work that went into them.
I was under the impression these were regular xenons, so if these really are Bi-Xenons, could someone tell me how to use this functionality? I always wondered what that line was for.
I sent you a PM KurriMasta.
OPTIMO is offline   Reply With Quote
Old 10-16-2002, 12:17 PM   #18
xmltok
was there a motor on the projector that controls the metal cover over the lense?
Old 10-16-2002, 12:25 PM   #19
OPTIMO
My Ride: Car
There's a metal cover over the lens? Maybe I'm missing something. It appears to be just a lens, without anything over it. The slit (horizontal line) you see if inside the projector lens itself.
Old 10-16-2002, 03:25 PM   #20
gazfatha323i
E46 Spartan
My Ride: 04 CB/IR M3
Send a message via AIM to gazfatha323i
I have a solution for you...check your e-mail.
I can get you the other coupe bi-xenon real cheap.
gazfatha323i is offline   Reply With Quote
