Old 10-16-2002, 03:34 PM   #21
kktran
My Ride: 01/325I 5 SPDS
Ref xenon
I got mine from Bekkers and they are regular xenon which is a bit brighter than bi-xenon, the new one seems a little soft compare the regular xenon.
XENON,DINAN STRUT,OEM LEATHER SPORT SEATS,M WHEEL,ON BOARD COMPUTER,M68 RIMS
kktran is offline   Reply With Quote
Old 10-16-2002, 04:29 PM   #22
ByeByeM
My Ride: 335i
Re: Ref xenon
From what someone at SUVLights.com told me, there were a lot of complaints (I assume from other drivers, not BMW owners) that xenon lights were too bright. So as of 02, the xenon was made a little dimmer.
I did finally make the decision to go with a set of single xenons - one for the color and two casue it was a lot cheaper! So who wants to buy an 02 coupe bi-xenon with titanium insert??
ByeByeM is offline   Reply With Quote
Old 10-16-2002, 04:50 PM   #23
kktran
Ref xenon
Are you getting a brand new set ?
Old 02-18-2013, 05:42 PM   #24
ups_1974
My Ride: 330CI
confusec as hell!!
Originally Posted by xmltok View Post
was there a motor on the projector that controls the metal cover over the lense?
Hello,
I have a 2001 330Ci with Xenon. I am not sure if it is bi-xenon or just xenon? I have the smaller lens 2.5" with no line in the middle. There is a metal flap in front of the projector (bulb) that seem be there to block half of the light. Can someone please help me identify and where I can get the right lens? Because the one I have is pretty foggy and had very poor light output.
ups_1974 is offline   Reply With Quote
Old 02-18-2013, 06:02 PM   #25
jiggz
My Ride: E90 M3|E70 X5 50i
^^^ holy thread bump!
2001 = xenon
bi-xenon was not introduced until 2002
jiggz is offline   Reply With Quote
Old 02-18-2013, 06:06 PM   #26
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Left is AL 3", right is Bosch 2.5"
Old 02-18-2013, 06:07 PM   #27
Solidjake
Zero. Leaks.
Solidjake's Avatar
Originally Posted by ups_1974 View Post
Hello,
When you push the turn signal stalk forward does the low beam light direct light upwards?
Old 02-18-2013, 06:10 PM   #28
Solidjake
Zero. Leaks.
Solidjake's Avatar
Old 02-20-2013, 09:05 AM   #29
ups_1974
My Ride: 330CI
2001 = xenon
Hi "jiggz"
Thanks for the information. You are [almost] correct
As it turns out they started using bi-xenon in 2001 - if your car production date is 9/2001 or later. Mine is 6/2001 so I am using "single" xenon. Problem now is that, no one (even Retrofit Resource) seems to carry the lens for "single xenon". So I am out of luck
One more piece of information, non bi-xenons have a metal flap in front of the xenon bulb that is fixed (ie. it does not go up and down), as oppose to the the ones in bi-xenon where the flap is not fixed and there is a motor that controls its.
Bad news is, I had ordered new ballasts, lens cover and projector lenses in preparation for a overhaul of my headlight. Since the projector lens does not fit, I will nee to buy the whole headlight assembly and therefore have not use for any of these parts.
Good (or not so bad) news is that I found a pair of new OEM headlight assembly for $1000. I have not recieved the part yet but they said it comes with ballast and ignitor too. I really hope that is the case.
Old 02-25-2013, 10:57 PM   #30
ups_1974
My Ride: 330CI
So i finally got the set of headlights. Assembly includes pretty much EVERYTHING needed, seems like, including the ballast, ignitor, xenon and halogen bulb, the bracket toward the bottom on which the headlight assembly sits ( place where the headlight washer/spray nozzle goes in. So it looks like plug and play. It is the same as original AL brand. For around $550 each ($1069 for both) does not seem too bad!!!
