Rating:
Display Modes |
#21 | |||
Glad everything worked out!! Last edited by elbee; 05-19-2006 at 12:22 PM. |
#22 |
D**n it! Did the same thing
Connected the battery to test the window while the airbag was unplugged. now getting the airbag light!
f***k. Why couldn't I have read ALL the posts before doing this... |
#23 |
My Ride: 325xi
Is a little "click" noise when you roll the window down, a sign of a future broken window regulator?
#24 |
My front pass. side window sounds like the glass is grinding a little? Regulator?
#25 | |
#26 | |
#27 |
awesome write up, been waiting for one these diy. Going to give this a try. Thank you Elbee
#28 |
Thank You!
Great DIY instructions. It took me about 2.5 hours to do the passenger window, (as I was being cautious) but 1.5 hours of it was trying to remount the window as I was had the clip on the wrong side of the regulator. Once I figured that part out...the rest was cake.
Now that I know what I'm doing...I don't think the drivers side window will take me more than 30 minutes in/out. Great easy DIY. Don't pay the dealer to do this...ANYONE can do it. ...I just saved $500 bucks! |
#29 |
This was very easy. i just repaired my passenger window regulator with the zip tie method. took me about 1 hour 30 minutes. no more creaks from the window. i will most likely have to do the driver window too. i wonder why bmw has not corrected this malfunction. it is definately a problem i see many having. these regulators are built cheap with plastic parts that deteriorate. thanks this saved me alot of repair cost!
#30 |
Nice guide! I fixed the driver and front passenger door regulator problems this past weekend. Easy!
When you do it, pay a good amount of attention to reattaching the vapor barrier back properly, especially the bottom part. After a dealer replaced a window regulator on my car a few years ago while it was still on warranty, the vapor barrier was poorly reattached as I just discovered. After really heavy rains once in a while I used to have water on the car floor.. This problem is a history now too. |
#31 |
Carpet destroyed?
I've been dealing with regulator issue lately. Scared, but I'm going to fix this one instead paying my mechanic. Both rear doors are leaking, too. I'm so pissed. Well, the floor well on the rear passenger side has gotten soaked on three occasions. I'm ordering new vapor barriers for both, but I'm concerned about this carpet being ruined. I'm concerned about mold under there even though I've done my best to get it dry. What would you guys do? Any idea how much it'd cost me to replace the carpet? I'd appreciate any thoughts. Thanks!
Matt |
#32 |
Hello guys, my driver's side from window (1999 328i) hardly goes down a couple of inches and then it does not go up by itself. I was told it could be the window regulator or the motor. I am planning to try to fix this my self. Could anyone tell me how I know if it is the regulator or the motor that is causing the problem? Thanks!
#33 |
It's the regulator. If it was the motor you would have no movement at all.
#34 |
I accidentally stripped the bolt holding the window to the regulator...got any advice from those who have previously done this? I'm totally stuck with my door all taken apart and my window halfway down lol...
-Chevalier Mal Fet-
#35 |
Don't worry. Get a new bolt from a BMW dealership. It should cost less than 50 cents. Then you should drive the car to your local BMW indy shop and ask them to loosen it for you. Before you go you don't need to put the whole door back together. Just drive the car with the door the way it is. But it is very important that you don't drive off with the airbag hanging. Make sure you bolt the airbag back on the door. Also before you drive off, put a towel in the well below the window. The window shouldn't fall, but just in case it does it will fall onto something soft. Depending how bad it was stripped they shouldn't have a problem getting it off for you. It should take them 2 seconds and they probably won't even charge you for it. They usually have better tools than the average home mechanic. If they can't get it off then ask them for suggestions on what you can do. I think Sears might sell a special tool to get off stripped bolts. If they do manage to loosen it you will need to drive home very carefully. You should keep one hand on the bottom of the window. If you have a thick enough towel in the well you should be ok. The window probably won't move but you need to be extra careful just in case it does. If you don't feel comfortable driving with the bracket loose like that you can have them put in the new bolt but make sure they don't tighten it too much so that you have the same problem when you get home.
These things happen. Last edited by elbee; 07-17-2006 at 09:21 AM. |
#36 |
Imported Redneck
awesome right up..my right rear regulator finally broke.
after studying the DIY, it took me less then 10 mins to get to the regulator. Unfortunately the cables are all tangeld up so I have to get a new one
#37 | |
My Ride: 09 Altima Cpe
Mark |
#38 | |
Imported Redneck
$80 online but I figured it's worth the extra $20 for having it right away
#39 | |
#40 |
Great writeup! My driver REAR regulator just died on my way back to work from lunch just today. Can I use pretty much the same technique on that one?
