Thread Tools Search this Thread Rating: Thread Rating: 179 votes, 4.99 average. Display Modes
Old 03-06-2010, 02:51 PM   #381
stapler12345
My Ride: Mineral White F30
did anyone initiate a lawsuit for this design defect yet?
Originally Posted by Penguin Koolaid View Post
I've never heard of a woman wanting more than she actually deserved. Never.
stapler12345 is offline   Reply With Quote
Old 03-06-2010, 03:02 PM   #382
kroh
My Ride: 2001ish 325i
Send a message via ICQ to kroh Send a message via AIM to kroh
Oh, relax.
  • Dinan
    • Intake
    • Exhaust
    • Stage II flash
    • Strut brace
  • Bavarian Autosport ignition
  • Z3 short shift kit
  • Turner Motorsport
    • Subframe reinforcement
    • Front & rear swaybars
    • Rear CA bushing limiters
  • ZHP/Bilstein suspension
  • MTech II kit/OEM facelift
  • Ski hatch Solo-Baric sub
kroh is offline   Reply With Quote
Old 03-06-2010, 03:05 PM   #383
stapler12345
Originally Posted by kroh View Post
Oh, relax.
http://www.bimmerfest.com/wiki/index...ook_out_for.3F
"Some owners had success asking BMW NA to cover all or a portion of the cost for this design defect even when the vehicle was out of warranty."
Old 03-06-2010, 03:12 PM   #384
Rickna
My Ride: '01 330xi - '09 IS-F
Oh, relax.
Yeah, really...
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 03-07-2010, 02:44 PM   #385
malina
My Ride: stock ZHP
Changed both front window regulators using this DIY guide Thanks a lot! It's so good when things just work properly.
malina is offline   Reply With Quote
Old 03-15-2010, 06:10 PM   #386
tfoxsf
My Ride: 2003 325i
So I reached my wits end with my driver side door. The inner hex bolt (holding window glass) was completely stripped. I bought all those stripped bolt removing kits -- no luck. I then went to BMW and asked if they would be able to remove it -- they said yes, for $500 and a new regulator. I then took some of the techs advise and drilled a hole in the center and tried punching in an alan key and a torx bit -- no luck. Then I tried to cut a slot in it and use a large flat head screwdriver -- I actually twisted the metal on the head with no luck in removing the bolt. Thoroughly defeated, I went and did the repair on the passenger side with no issues.
Upon using the zip-tie method on the passenger side, I discovered that you don't need to remove the window bolts at all. My window was still semi-functional, so I just raised and lowered the window to give me access to the sliding bracket. It was incredibly simple to access and complete. Job finished.
An interesting fact I noticed was that the stripped bolt went into a nut that was also removable (held in red clip inside window glass). If I ever needed to remove the window clip, I think I can just drill out the entire bolt and not worry about the threads on the nut. I then could just buy a new hex bolt and floating nut to insert into the red clip. Just thought that tid-bit might be useful to those who have been demoralized by this design flaw.
tfoxsf is offline   Reply With Quote
Old 03-15-2010, 06:18 PM   #387
Rickna
I'm used to finding frozen nuts/bolts on exhausts and suspensions-but on the window regulator? Well there's a 1st time for just about anything. Must have been moisture over the years. Do you live close to the bay? Must be the salt in the air.
2001 BMW 330xi
2009 Lexus IS-F
Old 03-15-2010, 11:22 PM   #388
York
My Ride: 01 330Ci
... -- I actually twisted the metal on the head with no luck in removing the bolt.
Sorry if this is a dumb question, but you did turn the hex screw clockwise to loosen it since it's reverse thread - right? Mine came off pretty easy.
330Ci
York is offline   Reply With Quote
Old 03-16-2010, 04:16 AM   #389
kroh
Uhm, no it isn't.
  • Dinan
    • Intake
    • Exhaust
    • Stage II flash
    • Strut brace
  • Turner Motorsport
Old 03-16-2010, 09:57 AM   #390
York
My Ride: 01 330Ci
Uhm, no it isn't.
Oops! Are we talking about the same screw/bolt? This was the that goes through the window mount at the rear and the same in the front just clamps the window? It's the ones that hold the window to the regulator? I believe mind were reverse thread. I read in other threads that you had to be careful or you'd strip it? Probably talking about the wrong one - sorry about that!
330Ci
Old 03-16-2010, 10:14 AM   #391
J P LeCoure
My Ride: '01 325i sedan
I fixed both of my front regulators using the zip tie method. Tested them both and they worked like new. Once I got them back together I went to put down the passenger side window and it was effed. Turned around and went back home to find that the clip on the front of the regulator had broken off and torn the cable right off of the track. I then had to go buy one at the stealership. Now they both work perfectly and hope fully I dont have to worry about them for a little while. This is a nice write up.
J P LeCoure is offline   Reply With Quote
Old 03-16-2010, 09:18 PM   #392
kroh
Yes.
Don't sweat it. These bolts are totally normal. Left-hand threads are typically only required when there's rotational force that might cause them to work free (e.g., a viscous clutch). I know mine weren't, and my Bentley manual makes no mention of it. The reason these bolts are likely to strip is because of their low-profile head (so it clears the rest of the regulator).
  • Dinan
    • Intake
    • Exhaust
    • Stage II flash
    • Strut brace
  • Turner Motorsport
Old 03-20-2010, 04:45 PM   #393
malina
My Ride: stock ZHP
A small piece of advice: buy OEM window regulator.
I tried some cheaper replica but had to go back OEM root in the end as this piece of cr@p failed on the second day after installation. I installed 3 OEM window regulators before, there was no installation error.
Besides, Tischer BMW has these @ discounted price.
Old 03-20-2010, 04:53 PM   #394
Rickna
I got one from FCP Groton, it failed after about 4 months. They replaced it via overnight shipping with a return shipping label. So far all is good. That's great customer service.
2001 BMW 330xi
2009 Lexus IS-F
Old 03-21-2010, 01:56 AM   #395
missamo80
My Ride: 2001 325i
Anyone have any tips for how to lower the driver's side window to access the bolts that hold it onto the regulator? Mine has died in the up position and I can't figure out how to get the window down so I can losen those bolts.
missamo80 is offline   Reply With Quote
Old 03-21-2010, 05:23 PM   #396
tfoxsf
My Ride: 2003 325i
Regulate
I'm pretty sure that if you remove the motor (remove the three torx bolts), you can manually push the window up and down with your hands. You should then be able to slide it down enough to reach the bolts.
Old 03-21-2010, 05:27 PM   #397
NicB.
My Ride: 2000 BMW 328i
^^true, just be careful to slide it evenly or it will get out of its groove, then you'll have to mess with fitting it back in.
NicB. is offline   Reply With Quote
Old 03-22-2010, 01:11 AM   #398
missamo80
My Ride: 2001 325i
I must be weak, because I've tried this several times and the window won't budge at all, even though the motor is removed
Neil
Old 03-24-2010, 04:58 PM   #399
tcimpidis
My Ride: 328I w/18" Sport Pkg
Way late now but
I have the diagnostic software and interface and can reset the Airbag (and other) lights for anyone who may need it on most OBDII BMWs up through 2006. I live in Granada Hills, CA.
Also, I have now used three of the FCP Groton regulators and not had any problems with any of them. Two are now more than four years old... In two of the three cases, the clip was not the problem and the regulator had to be replaced. In the third, I decided to replace it proactively anyway since I already had it on hand.
Tom
tcimpidis is offline   Reply With Quote
Old 03-24-2010, 05:47 PM   #400
Rickna
Tom
FCP Groton is a good outfit to deal with.
2001 BMW 330xi
2009 Lexus IS-F
