Thread Tools Search this Thread Rating: Thread Rating: 179 votes, 4.99 average. Display Modes
Old 02-27-2014, 09:50 AM   #661
diosak
My Ride: BMW E46 316i
So i have this problem:
front driver's side window works fine, goes up and down with no issue. However, when it's almost bottomed, it sounds like it falls...like it smashes down the end of the regulator.
Could it be some kind of window-stop inside the door?
How could i possibly fix that?
diosak is offline   Reply With Quote
Old 02-27-2014, 10:08 AM   #662
APKhaos
My Ride: 99 328i
The window glass is attached to the regulator by two brackets, one each side of the glass. There's a single 8mm bolt on each bracket that secures the regulator runner to the glass bracket.
- Its possible that one of those bracket bolts has fallen out.
The regulator runners run on cables. Its possible that one or both of the runners have disengaged from the crimped sleeve on the cable that drives them. That's what happened to mine.
Open it up and take a quick look. If its just a bolt you'll probably find it rolling around the bottom of the door. A magnet is your friend. If its a regulator, buy the Uro for $60 or so. Good DIY here for the R&R.
APKhaos is offline   Reply With Quote
Old 04-01-2014, 12:25 PM   #663
MarcDJB
My Ride: BMW 320d Estate E46
Thank you Elbee, re fixing front window regulator
Just like to say I was going to order a window regulator, and was going to fix it myself. The I came across your post (think it was yours!) saying you used a 'pull tie'... well this gave me an idea, I didn't have of those ties, and found some metal picture hanging wire, and wrapped that around it and tightened it around the regulator clip and the cable with the metal lodging part, and bob's ya uncle, it worked! And still does, I thought I was going to save myself about 120, but instead saved myself about 150-160 ! Job's a good'n!!
MarcDJB is offline   Reply With Quote
Old 04-10-2014, 01:00 AM   #664
shortfork
My Ride: 2003 325xi
Great Thread
New here, hopefully not digging up an old thread. Bought my GF's '03 325xi last fall, have been with the car (and the GF) since she got it in '06, I've driven it on ice and, needless to say, I love this car!
Back on topic, I just completed this repair today, really REALLY cool that this forum directed me exactly to what was needed. My only cost.. a couple of very minor metal edge cuts on my hands.. no band aid necessary! And four zip ties.
Only thing I'd add to all this is, keep in mind during reassembly, the alignment of the "nut clips" is pretty important. I had one of the clips for the airbag break in half, only learning this when I found it in the bottom of the door. Two others were very hard to keep aligned. I used masking tape with complete success.
Kudos to BMW for leaving enough room in the door to stick an arm up and compensate for broken, misaligned clip nuts!
Thanks to this forum, just saved me a handful of bux and blood!
shortfork is offline   Reply With Quote
Old 08-13-2014, 11:39 AM   #665
nallman
My Ride: 2004 330xi
Awesome Write-Up
I just did my passenger rear window regulator, just wanted to post one hiccup I incurred. When you are installing the window regulator (be it new or old), be sure to only hand tighten the nuts that attach it to the door. I made the mistake of using a ratchet (I know, I'm an oaf) and I busted one of the grommets, leaving my regulator unattached at the bottom anchor point.
TL;DR, hand tighten the window regulator nuts to avoid breaking them.
nallman is offline   Reply With Quote
Old 09-06-2014, 04:25 PM   #666
Tate325xi
My Ride: 325xi 5MT
Just finished this. The only piece of advice that I have is don't loosen the screws holding the window to the regulator too much. If one falls out (which happened to me) they are a bitch to get back in. Other than that, not a hard DIY at all if you have the tools OP mentioned.
-Tate
Originally Posted by 217Bimmer View Post
sometimes i'm into it and my one hand gets tired, i try switching, but then it's like someone with lou gehrig's trying to peel a carrot.
Tate325xi is offline   Reply With Quote
Old 09-12-2014, 05:21 PM   #667
nallman
My Ride: 2004 330xi
A few tips...
So I followed this DIY and it was relatively straightforward, only two things I would mention:
1. If you are planning on using duct tape to hold your window up, be mindful that the residue can be hard to get off. I avoided this by holding the window.
2. Don't hold the window while trying to put a new regulator in with one hand... get another person. It took me two hours, and I regret my decision to go it alone.
All said and done, my new window regulator works great. Awesome write-up, props to tommie/elbee.
Old 09-25-2014, 04:17 PM   #668
18rabbit
My Ride: '02 330it
Yeah this was mad easy. Totally fixed my drivers window. Coming from 4 e36's, the e46 has better designs across the board.
18rabbit is offline   Reply With Quote
Old 09-26-2014, 10:37 PM   #669
knsaber
My Ride: 2005 330xi
Thanks for this write up, I used it a year ago when fixing my regulator with the ziptie fix, but it wasn't very secure and the window would slow down again or make a loud crack sound sometimes. I finally decided to buy the cheap plastic clips from Amazon (http://www.amazon.com/RegulatorFix-W...regulator+clip). Installed it tonight and so far so good!
knsaber is offline   Reply With Quote
Old 11-07-2014, 09:14 PM   #670
Icee
My Ride: 330xit, m50b25 boat
wrong post
Icee is offline   Reply With Quote
Old 11-28-2014, 12:16 AM   #671
typeflex
My Ride: e46
In for this zip tie fix once I have some time to rip this door apart.
typeflex is offline   Reply With Quote
Old 12-08-2014, 05:44 PM   #672
Deuce5
My Ride: 2004 325xi
Brackets move without window but not with it
Hello, I recently did a driver side front window regulator replacement and within 2 days the regulator was shot already. Rolled down but not up. So I got yet another new regulator off of eBay and removed the old one. I plugged in the regulator to be sure it worked before I attached it to the window and it did, but once I attached the window to the mounting brackets I encountered the same problem. Window rolls down fine but when I try to roll it up the motor stalls out and stops. I don't want to go any further for a fear of destroying another regulator. Please help.
Deuce5 is offline   Reply With Quote
Old 12-08-2014, 05:56 PM   #673
Riverbmr3
My Ride: MB E350 & BMW 325i
just fix your old regulator by zip tie method, mine works great.
Riverbmr3 is offline   Reply With Quote
Old 12-09-2014, 11:38 AM   #674
Deuce5
My Ride: 2004 325xi
"Zip tie method" won't work here. The regulator is damaged beyond repair
Old 12-10-2014, 07:34 AM   #675
TotheMountains!
My Ride: 2001 330xi
Deuce5 -- I recommend that you clean the rubber seals of the tracks thoroughly and then lubricate them. I have used isopropyl alcohol and I've used fingernail polish remover for the cleaning, with lots of paper towels and Q-tips, and clean everything as far as you can reach until the swabs come out clean. I have used light synthetic, plastic- and rubber-safe grease for the lubrication, and you want it to be a thin, even coat. But I think next time I do this task I might just use ArmorAll.
Report back . . . I'll bet you've got a mess in there.
TotheMountains! is offline   Reply With Quote
Old 12-16-2014, 11:48 AM   #676
Deuce5
My Ride: 2004 325xi
Tothemountains! Thank you for your reply. I've had to temporarily suspend my operation because I broke the clip on the door handle cable due to a fit of rage, but I will definitely try cleaning and lubing the track of the new regulator. I was able to get the regulator to work but it's very slow and seems something still isn't right, so I'll try that and report back. Thanks again!
Old 12-17-2014, 07:49 AM   #677
TotheMountains!
My Ride: 2001 330xi
Gah! I hate when that happens. Even if it's not rage, just the wrong idea that comes with impatience and frustration -- and then, ping! Busted.
I came across the sheet again that came with one of the regulators I bought from BavAuto. It is all about cleaning and lubing the guides, seals, tracks . . . if you can see that it moves or holds parts that move in operating the window, clean it and lube it.
Old 12-19-2014, 02:12 PM   #678
Deuce5
My Ride: 2004 325xi
Do you think spraying some wd40 or pb blaster would work? I already have the new regulator installed and it was such a pain in the ass taking it in and out, the 8mm bolts holding the window to the brackets are rounded off, and I live in northern mn and don't have s garage so I do everything outside, so if I could I would rather finish without removing the regulator again...
Old 12-24-2014, 09:53 AM   #679
TotheMountains!
My Ride: 2001 330xi
Well, the WD-40 will help because of the silicone lubricant in it; I think PB Blaster, as a stuck-fastener solvent, is too thin to stay behind as a coating and also probably not safe for long-term exposure on vinyl and rubber (unless it says so on the can.)
What about a spray can of white lithium grease with a nozzle that lets you reach into small spaces and direct the flow. Five or six bucks and it's perfect for all of the hinges and latches all around the body and will last years.
Old 01-17-2015, 10:26 AM   #680
Deuce5
My Ride: 2004 325xi
Tothemountains! I wanted to give the new regulator a bit of time before I reported back, but thanks to your solution of greasing the moving parts on the regulator, the installation seems to have been a successful one. I was a bit skeptical after burning through 3 regulators in as many weeks, but the white lithium grease seems to be working. Thanks for the help!
