Old 04-14-2006, 06:08 PM   #1
nevin
My Ride: 08 AA m3
CALLING OCD Brett
I'm not sure if you are familiar with the roundells that go on BMs but there are two prongs on the roundell that go into two holes so they are held in place.
I bought different roundells and they didn't fit in good enough (i thought they were going to fly off when driving). Soooo I SUPER GLUED them in. god that was dumb.
Whats the best way to get'em out???
I suck at speling!
Originally Posted by Bim Growl View Post
Get out of the pool. It's adult swim time, and you are in way over your head...
nevin is offline   Reply With Quote
Old 04-14-2006, 07:49 PM   #2
deafboy
My Ride: 2000 323Ci
Heat it up....soap and water, floss.
Or if you can get super glue remover in there....
It'll take a lot of work and patience...
have at it.
deafboy is offline   Reply With Quote
Old 04-15-2006, 03:05 AM   #3
Lil. Lucas
My Ride: E30 M3
Why is super glue removal Brett's expertise
Lil. Lucas is offline   Reply With Quote
Old 04-15-2006, 04:53 AM   #4
deafboy
My Ride: 2000 323Ci
He's good at getting out of sticky situations
Old 04-15-2006, 08:49 AM   #5
BMW330xi01
My Ride: 98 Skyline
yet another reason i love silicon glue. strong enough to hold but caqn be taken off with a lil rub of the fingers.
NO LONGER INSTALLING IN CONNECTICUT. I AM LOCATED IN JAPAN NOW
LUIS ESCOBAR
L.EscobarJr@yahoo.com
INSTALL PHOTOS
BMW330xi01 is offline   Reply With Quote
Old 04-15-2006, 08:54 AM   #6
OCDGarage
Past Site Sponsor
OCDGarage's Avatar
My Ride: Cabrio M3, Carbon
I hate to say it but Acetone is the most commonly used solvent for removal of Cyanoacrylates. These glues were not called super for nothing. I would mask all of the surrounding paint off with Blue painters tape and plastic. Open the Hood and prop open so that the roundell is sitting level. Carefully place some acetone around the edge of the roundel so it will get under and start softening the glue. You may want to place a towel under the hood to catch any acetone that may pass through the two holes. Now I would take defboys advice and try working the dental floss under it little by little. It is definitely going to be some work. If the acetone gets on the paint remove it immediatly. It may take a while of adding small amounts of acetone and working with the floss.
Next time use some silicone or 3M double sided tape.
I have removed these types of glues many times from paint but never from under an roundel. I have never used the floss with acetone but it makes sense that it would work.
Good Luck and let me know how it turns out.
Brett @ OCD
OCDGarage is offline   Reply With Quote
Old 04-15-2006, 08:54 AM   #7
OCDGarage
Past Site Sponsor
OCDGarage's Avatar
Old 04-15-2006, 04:02 PM   #8
nevin
My Ride: 08 AA m3
sweet, thanks for the info. Sounds like it's going to take me hours. i'll let you know how it goes.
I suck at speling!
Old 04-15-2006, 05:19 PM   #9
deafboy
My Ride: 2000 323Ci
Now hopefully you will learn not to use superglue on you car
