Welcome to the E46Fanatics forums. E46Fanatics is the premiere website for BMW 3 series owners around the world with interactive forums, a geographical enthusiast directory, photo galleries, and technical information for BMW enthusiasts. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
#1 |
My Ride: 2002 325i (w/sport)
DIY: Sedan Rear Bumper Removal/Installation (as requested)
Looking around for this DIY for my own use, I noticed a few people were also on the hunt for what turned out to be a VERY simple "project". So I thought I'd post it up with pics for those of us with a sedan, since the removal is slightly different from the coupe...
Tools needed: - Torx T50 socket with ratchet tool or other (preferrably 5 inches or longer) - Flathead screwdriver (a butter knife will work too!) - 5/16th socket tool (any wrench will do, but will be a pain) - safety glasses! (you'll thank me for this one when you're on your back under the bumper!) 1. Locate the two circular openings underneath the rear bumper (see picture); there you will be able to access the two long bolts that hold the bumper in place. ![]() 2. Use the torx T50 to unscrew and remove these two bolts. Here it will be MUCH simpler if what you are using is a ratchet set (maybe with an extension)... that way, it gives you leverage to pry it loose, because you'll see how hard it is to get that sucker to turn at first! 3. Use the 5/16th socket to remove the screw on the bottom front of the bumper, right at the wheel well (see picture below). Then repeat on the other side. ![]() 4. Hard part over with, get your flathead/butter knife and very carefully pry apart the side front lip of the bumper away from its holder (right at the wheel well). The idea is to push the little black clip downwards and towards the car. (see picture). Repeat on both sides. ![]() 5. Carefully slide the bumper back and away from the vehicle (easier with a friend) and remember to place it on a soft surface, as to prevent damage to the finish! That's it for removal! You'll notice that to re-install the bumper, the only hard step is to slide the sides of the bumper onto the black tracks on either side of the quarter panel (see pictures of bumper and tracks below.) Again, here it might be simpler with a friend, each of you at one side, guiding the bumper onto the 3-track holder. Once that's done with, don't forget to snap the front lip back into place, and re-install the four screws from underneath! ![]() ![]() So contrary to the coupe bumper, there is no need to remove the black trim to access the bolts in our case... the whole thing shouldn't take more than 10 minutes. Any questions? Good! |
#2 |
Excellent Write Up!
This is definately going to come in handy for most people as a reference. Jared
#3 |
I wonder if the front bumper is similar?
#4 |
Thanks Jared!
#5 |
How hard can you pull to remove the main 2 bumper bolts?? I tried to remove mine a while ago..and they were almost seized tight... any suggestions .. 3-1 oil ??
#6 | |
To be honest with you, I had the same problem, but I didn't bother using any oils/greasers. I first started out trying with a straight screwdriver socket T50 and soon realized that was stupid! ![]() Anyways, what finally worked was a ratchet using a T50 socket; that way, you're using all your strength to pull/push rather than to turn! (the longer the ratchet, the easier it will be obviously) Don't be afraid of stripping these bolts BTW, you'll screw up your T50 WAY before these bolts would even budge if that were the case! Kamshaft
Favorite Movie Quote: "The greatest trick the devil ever pulled was convincing the world he doesn't exist." (Usual Suspects) |
#7 |
good work!
No, no, there is no climate change, it just getting hotter and hotter....and hotter. Yeah, right!?!!? |
#8 |
My Ride: 2004 325i Sport Pack
Did anyone bother to ask Kamshaft why he had to remove his bumper???
2004 BMW 325i Titanium Silver, 5 Speed, Xenons Sport Package, Sunroof, Heated Seats Mods: Bimmian silver gauge rings; Full ULO clear kit; SSK Denison Ice->Link; Chrome windows mouldings; Intake |
#9 |
![]() Edit - oops, double post
2004 BMW 325i Titanium Silver, 5 Speed, Xenons Sport Package, Sunroof, Heated Seats Mods: Bimmian silver gauge rings; Full ULO clear kit; SSK Denison Ice->Link; Chrome windows mouldings; Intake Last edited by BimmerDom; 04-19-2006 at 08:04 PM. |
#10 | |
#11 |
ED is no laughing matter
#12 |
Thanks for the write-up, as it will come in handy for the future.
OT question for you. How do you get the red arrows in your pictures? |
#13 | |
#14 |
Hey, i tried to removing my 2006 330ci zhp bumper and there seemed to be a lot of work in it. I went 1/2 way and it was too much and i had to reinstall it. Am i doing it wrong. Can someone help me? There seemed to be series of lugs (difficult to get to) on he inner bumper after the diffuser is removed. Thanks
#15 |
Banned User
awesome DIY!
#16 |
Hey guys, I needed to remove my rear bumper on my 2001 325i and I don't see the two holes to remove the big screws, or the two on the bottom-sides. Any suggestions? I can't find 2001 rear bumper removal anywhere.
Thanks |
#17 |
Just remember that the bumper only has the holes for to introduce the ratchet to the screws. I you could take a pic of the bottom of your bumper we could help you better. Have you read the DIYs at the tech section? If your car has an aftermarket rear valance or something extra that may be the reason your bumpers looks different, but I doubt it.
No, no, there is no climate change, it just getting hotter and hotter....and hotter. Yeah, right!?!!? Last edited by adrian320; 06-13-2008 at 11:35 AM. Reason: added more text. |
#18 |
My Ride: 2002 320i Sedan
Figures, can't find a DIY for this anywhere, and a guy from my own damn city writes one!! Thanks Kamshaft! Can't wait to try this!
Bart |
#19 |
excellent DIY, except when trying to "CAREFULLY" pry the bumper, you have to be VERY CAREFUL ! i broke the part on the bumper that holds the front in place, but then i noticed in a previous repair job the garage put some strong adhesive to keep it in place.
I guess i am not the only one not being careful ... |
#20 |
My Ride: 03 320Diesel Tractor
Additional info: If the black plastic slider is broken, here's my DIY to replace it without removing the whole bumper:
http://forum.e46fanatics.com/showthr...802&highlight=
![]() I don't have a solution, but I admire the problem. |
