Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 04-18-2006, 06:11 PM   #1
Kain
My Ride: E39 M5...sold!
Question for those who use their 5.1/6.1/7.1 setups for 2.0 audio
Do you use the subwoofer for 2-channel audio like that from a CD?
Kain is offline   Reply With Quote
Old 04-18-2006, 06:15 PM   #2
deletedpenguin
deletedpenguin's Avatar
My Ride: is gone!
Send a message via Skype™ to deletedpenguin
Yes, however I set my crossover to 120Hz rather than 80.
Stefan | American by birth, Swedish by heritage, Australian by choice.
My current photo galleries.
deletedpenguin is offline   Reply With Quote
Old 04-18-2006, 06:48 PM   #3
Kain
How low do music tracks from CDs usually go?
Old 04-18-2006, 07:36 PM   #4
M_Thrizzle
My Ride: '01 M3 Coupe
It depends on the material but it can go LOW, like down to 20 Hz for some.
If you have tower speakers with a big woofer, you may want to use it w/out the sub. I have Paradigm Studio 20's, which are 2-way bookshelves, so I use the sub all the time. Really, you need to listen to some music with and without the sub and determine which one you like better.
You will get more bass from the sub than w/ your main speakers.
2001 Jet Black ///M3 6MT rolling on 19" BBS CH's | PSS-9 suspension | UUC Swaybars | K&N CAI | Cold Weather Pkg | Pwr Seats | HK Audio | Homelink | DIY rear parcel shelf rattle bolt fix
RIP: 2004 G35 coupe 6MT | Diamond Graphite | OEM Brembo's | Z-tube, K&N, Plenum Spacer, Stillen Sway Bars
M_Thrizzle is offline   Reply With Quote
Old 04-18-2006, 07:42 PM   #5
Kain
Where does the bass normally "hang around" for Rap and Metal/Rock music?
Old 04-18-2006, 10:07 PM   #6
baller99
My Ride: My whip
With most receievers you can't output to the subwoofer for 2 channel cd audio, so this isn't an issue as the subwoofer is only wired to accept an lfe channel (the .1 in 5.1).
Unless of course you wire your sub using speaker wire and pass through the main l/r signals through the sub and to the main speakers. Of course in that case, you wouldn't get lfe audio in movies.
baller99 is offline   Reply With Quote
Old 04-18-2006, 10:24 PM   #7
Kain
Yes you can through bass managment i.e. crossover settings and speaker settings of "small" or "large."
Old 04-18-2006, 10:30 PM   #8
baller99
My Ride: My whip
It depends on the receiever...
Old 04-18-2006, 11:13 PM   #9
Mike325i
My Ride: 2001 325i
Send a message via AIM to Mike325i Send a message via Yahoo to Mike325i
I am not sure about all recievers, but my sub is always on with my denon. Maybe it has to do with the bass management. I have all my speakers set to small. Having a good sub properly calibrated helps a great deal. My sub does a great job blending in with my speakers, if it were not for the huge tube in ther corner one would think the sound was only coming from my speakers...
Mike325i is offline   Reply With Quote
Old 04-19-2006, 04:22 PM   #10
M_Thrizzle
This is not the case with any decent receiver made within the last 3-5 years. Your receiver menu will allow you to have the sub on or not.
I personally like playing music with DPL II soundfield as it sounds more ambient.
Do you have an SVS? Which one and how do you like it?
