Thread Tools Search this Thread Rating: Thread Rating: 33 votes, 4.85 average. Display Modes
Old 04-20-2006, 01:42 AM   #1
RichieE46
My Ride: E46
DIY: Camshaft Intake Sensor ULTIMATE GUIDE *PICS*
First off, I wanted to make this guide as a compilation of what is available on the board. I used Scott's (Pigeon) and DriftinSequence's guides to help me install this.
I am copy pasting their work here and adding a little of my additions to make this "ultimate" guide.
From this thread made by DriftinSequence: http://forum.e46fanatics.com/showthr...amshaft+sensor
SYMPTOMS
Here are some of the things to notice to see if your intake camshaft sensor or possibly your intake camshaft sensor is going out.
1) your car doesn't feel like it has much power.
*now depending on the car and the severity of the sensor, some cars
would not have that much of a noticable decrease in power while
others do.
2) your car has stalled on acceleration or deceleration. how hard you accelerate or decelerate does not matter, usually under 40mph this would happen.
3) your car does not want to start the first time, or, the car hesitates for a bit and then starts. when i say hesitate, i don't mean to say that the battery is weak and thus your starter motor doesn't have the "kick" to turn your car over. I mean that you have full "kick" of the starter motor but the car won't turn on.
>>>>> these are some of the common errors I found and some have personally experienced. Since this is a big problem as it seems on the E46's, I thought I would share my experiences into helping you guys since you helped me on this very issue.
NOTE: these are the most common noticable problems. No check engine light or other dashlights have been turned on. Do not attempt to arbitrarily change the intake camshaft sensor without checking fault codes first!
part runs about $110 plus you need to get a new o-ring which is $1. Stick with OEM since I don't think many other places would have it
DIY INSTALL GUIDE
Mostly copied from Pigeon's guide:
TOOLS:
-32mm open-ended wrench to remove/replace the VANOS solenoid
-5mm Allen head socket
-Blue loctite - the factory put it on the bolt holding the sensor for a reason...
PARTS:
-Camshaft Position Sensor (Intake) - Approx - $120
-Replacement O-ring
Here's how to do it:
NOTE: I did the install after a 45min drive to the dealer so the engine was hot, I recommend waiting for the engine to be completely cool but I was impatient.
1.) Remove the airbox (2 10mm bolts after the cover's removed)
2.)Disconnect the tube above the sensor and the VANOS solenoid by squeezing both sides of the connector and pulling straight out (I think this is the PCV recirculation but I'm not sure)
3.) Disconnect the VANOS solenoid electrical connector by squeezing the wire clip and pulling the connector off
4.) Remove the canister holding the oil filter, 2 bolts, which gives you more room to take out the VANOS solenoid and to run the new wire for the CPS.
5.)Remove the VANOS solenoid with the 32mm wrench. Oil will come out, have rags ready
RichieE46 is offline   Reply With Quote
Old 04-20-2006, 01:42 AM   #2
RichieE46
My Ride: E46
6.)Trace the CPS wire to the connector way underneath the intake, disconnect it and plug in new CPS
7.) Run the new sensor's wire the same way the old one ran
8.) Remove the camshaft position sensor hold down bolt with the 5mm Allen socket. A standard Allen wrench will also do.
9.) Pull the CPS out - give it a twist to help it out. Make sure you clean out where the gasket goes as mine was pretty cruddy there. Get a new gasket with the new CPS, it's a buck and worth it to avoid a potential oil leak
10.) Put the new gasket on the sensor, lube it with a couple drops of clean
oil and install the sensor
11.) Reinstall the 5mm Allen bolt with a drop of blue Loctite. I used a microfiber towel to cover the surrounding area to prevent burns.
12.) Put everything else back where it came from
Total time, if you have everything you need at hand, maybe 45 minutes.
-Richard
Props to Pigeon and DriftinSequence, hope you guys are ok with me posting your stuff
Old 04-20-2006, 09:00 AM   #3
Ivegotissues666
My Ride: 88' BMW E30 SETA
Send a message via AIM to Ivegotissues666
Excellent Write Up Seems like more people are doing well documented write ups lately
Jared
Ivegotissues666 is offline   Reply With Quote
Old 05-01-2006, 06:34 PM   #4
Ivan Thomson
My Ride: 320ci
excellent now i know exactly what i'm doing.cheers mate
Ivan,
Scotland
Ivan Thomson is offline   Reply With Quote
Old 05-01-2006, 09:51 PM   #5
Pigeon
My Ride: 02 ///M3 & 06 750Li
Thanks for the credit, but your writeup is more comprehensive and the pics are worth 10,000 words. Great job!
Scott
Pigeon is offline   Reply With Quote
Old 05-11-2006, 12:52 AM   #6
Helmetboy
My Ride: 330Ci
Hate to bring old threads back from the dead, but this helped me so much when changing mine. Just wanted to thank everyone involved in doing this, and maybe it can help someone else out in the future
Helmetboy is offline   Reply With Quote
Old 05-12-2006, 11:55 AM   #7
ebiz
My Ride: 2001 330xi
Dang, excellent writeup, thanks for taking the time. Nice looking engine bay too.
ebiz is offline   Reply With Quote
Old 05-18-2006, 06:01 PM   #8
driftinsequence
My Ride: waiting to be modded
Send a message via AIM to driftinsequence
hey, that DIY write up was mine, wheres the bibliography for credit here, ha
driftinsequence is offline   Reply With Quote
Old 05-20-2006, 06:18 PM   #9
N_Corso
My Ride: 2001 325ci
Awesome...Thanks...
New Jersey, USA
N_Corso is offline   Reply With Quote
Old 05-21-2006, 06:46 PM   #10
Demon Eyes Kyo
My Ride: 2001 330i
I just changed my Intake CPS yesterday and had a hard time following other people's DIY here cuz there were no pics! I wish I found your DIY as the PICS really help alot! I did a search for "P0340" and did not find a lot. Now I searched for "Camshaft Position Sensor" and found this most excellent thread. Oh well, now I know how to do it.
Demon Eyes Kyo is offline   Reply With Quote
Old 05-21-2006, 07:30 PM   #11
Seraph
My Ride: 323ci
Nice I wish I would have had this a couple of months ago.
Seraph is offline   Reply With Quote
Old 05-23-2006, 11:28 PM   #12
kshyk1
My Ride: 2001 325ci
i am having the same problem starting, can i change mine without checking for codes.....or is this a bad idea?
kshyk1 is offline   Reply With Quote
Old 05-24-2006, 01:09 AM   #13
dirsh
Hawaii 3.0
dirsh's Avatar
My Ride: sanbyaku sanjuu
excellent write-up
so can the sensor be bad and there not be a CEL?
Hello dirsh it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
dirsh is offline   Reply With Quote
Old 05-24-2006, 01:16 AM   #14
driftinsequence
thanks for using my writeup rich, and actually letting people know its mine
Old 05-26-2006, 09:50 PM   #15
kshyk1
My Ride: 2001 325ci
just changed mine...difficulty with connector my hands are too fat i guess....but this dyi was fantastic....oh i also lost both harness clips...thanks for the dyi.....very imformative
Old 05-27-2006, 04:38 PM   #16
thestimp
My Ride: 99 323i in the ICU.
Send a message via AIM to thestimp
i like that red.
thestimp is offline   Reply With Quote
Old 04-28-2008, 08:55 AM   #17
Green_Shine
My Ride: Back seat riding
2 years later....I'm doing this DIY. BavAuto has the part for $54.00 now.
Green_Shine is offline   Reply With Quote
Old 05-23-2008, 03:06 PM   #18
nuwde
My Ride: 2001 330Ci
just got my part from tischer. came with an O-ring 1 quick question...
the blue threadlock says parts will not separate unless sheared.
is that going to be a problem?? thanks!
nuwde is offline   Reply With Quote
Old 08-09-2008, 12:42 PM   #19
sidefly
My Ride: 335i Coupe
Just did this today. Thanks for the pics and advice!
SIDEFLY
sidefly is offline   Reply With Quote
Old 09-10-2008, 10:52 AM   #20
ragout
My Ride: 2002 325xit
This worked out great for me. Thanks.
ragout is offline   Reply With Quote
