Thread Tools Search this Thread Rating: Thread Rating: 33 votes, 4.85 average. Display Modes
Old 09-10-2008, 09:58 AM   #21
TKC
My Ride: 330cic & R6
Send a message via AIM to TKC
Nice write up and pics! Thanks!
EUROPROJEKTZ - Director, NorCal Chapter
TKC is offline   Reply With Quote
Old 09-10-2008, 11:24 AM   #22
hummer
My Ride: 2001 330CI
Nice but why does the filter have to come off? Didn't need to do this on mine.
Old 08-27-2009, 06:40 PM   #23
Kingnog
My Ride: 1999 323i *sport*
Thanks for the amazing guide! My check engine light came on while I was driving home from work. I pulled into the nearest Autozone, and they read a code for a Camshaft Intake Sensor Malfunction. After that, my car would not stay on (instead of idling it would turn off) and during my 1/4-mile drive home, my car felt like it had 50 horsepower.
I changed it without removing my oil filter canister, the only difficult part was getting an allen wrench that fit.
lll
Kingnog is offline   Reply With Quote
Old 11-11-2009, 05:25 PM   #24
shellddy
My Ride: 2003 325XI
Thanks for write up especially the pics. Took me about 45 min. only because I had trouble finding the right size wrench to take off the vanos solenoid. Ended up breaking it with a large crescent wrench but had to finish with a channel lock to have enough room to turn it. Took off the airbox. Disconnected the tube above the vanos. Took off just the top and filter of the oil canister, didn't remove the whole thing. You just need enough room to get a ratchet with 5mm hex in there. Much easier than wrestling with an allen wrench. I tried, it sucked. The clips on the solenoid and the bottom end of the sensor were really easy to take off (just push the curved section of the little metal clip and pull you don't need to pull the metal clips out). Tied a shoestring to the old sensor when I pulled it out and pulled the new one back down the same way. e46fanatics is the best website ever!
shellddy is offline   Reply With Quote
Old 05-13-2010, 09:18 PM   #25
Ryd
My Ride: 2001 330xi SP
What is this mysterious tube?
Hi All,
I was working to replace the CPS on my '01 330xi, and the "tube in Step 2" started cracking. I'm going to need a replacement, but I'm not sure what to ask for.
Does anybody know what this is, or better yet, have a part number for it?
Thanks,
Ryd
Ryd is offline   Reply With Quote
Old 05-23-2010, 10:24 AM   #26
ManVan
My Ride: 2001 BMW 325i
Hello will this bad sensor make you service engine soon , came on ?
ManVan is offline   Reply With Quote
Old 06-06-2010, 07:59 PM   #27
leeroy74
My Ride: 2002 3251
Yeah just did this. This was an intermittent problem my car would stall every time I came to a stop or as soon as I decelerated. Started to get dangerous! I bought the part from autohauz for 70 bucks works like a charm.
leeroy74 is offline   Reply With Quote
Old 08-17-2010, 01:19 AM   #28
LaCuRa
My Ride: 2001 325i
just found this thread, and my car has the exact same symptons, it actually even turned off on me while driving, thank god it wasnt at high speed or on a highway, my mechanic plugged in the computer and the computer read the Cam Inlet Sensor, i am going to BMW tomorrow morning to buy the sensor along with a new valve cover gasket, hope fully it wont cost me an arm and a leg, nice write up and pics, thanks
LaCuRa is offline   Reply With Quote
Old 08-17-2010, 01:21 AM   #29
EMPORIOO
My Ride: 330ci, 335i
good work man.,
EMPORIOO is offline   Reply With Quote
Old 08-27-2010, 06:00 PM   #30
nihad05
My Ride: E92 335i
is there more than one camshaft position sensor? an a side and a b side?
nihad05 is offline   Reply With Quote
Old 08-27-2010, 06:17 PM   #31
genuity
My Ride: 2001 330iS
Yes, there is more than one camshaft position sensor. This DIY is for the intake side. There is also an exhaust camshaft position sensor.
genuity is offline   Reply With Quote
Old 08-27-2010, 06:19 PM   #32
nihad05
My Ride: E92 335i
if been searching for a DIY for the exhaust side one, thats B right? any idea where i can find a diy? or just a picture of its location? thanks
Old 08-27-2010, 06:24 PM   #33
genuity
My Ride: 2001 330iS
http://forum.e46fanatics.com/showthread.php?t=492544
Old 08-28-2010, 07:21 PM   #34
stapler12345
My Ride: Mineral White F30
damn i just paid 65$ @ an indy for this
Originally Posted by Penguin Koolaid View Post
I've never heard of a woman wanting more than she actually deserved. Never.
stapler12345 is offline   Reply With Quote
Old 01-26-2011, 08:37 PM   #35
QUEDRO
My Ride: 2001 325i ZSP
What part is "the pipe" in Step 2
Whats that pipe that we need to disconnect in step 2.
I broke mine since it's old.
I doubt it's PCV. On diagram looks different.
QUEDRO is offline   Reply With Quote
Old 03-01-2011, 09:40 PM   #36
haurelio
My Ride: 2001 bmw 325i
i just did this on the weekend. it took me less than 20 minutes. and you don't have to unplug that pipe. just move it a little to the side..
Old 03-07-2011, 01:05 AM   #37
vsyucla
My Ride: 3251
That pipe/hose connects to the oil seperator aka crankcase valve (CCV). There are 4 other hoses that connect to this oil seperator that often crack over time and from heat.
There are several threads that talked about oil seperator DIY.
vsyucla is offline   Reply With Quote
Old 07-26-2011, 06:57 PM   #38
Awesomo
My Ride: BMW 323ci
Where is the best price I can find the Camshaft Intake Sensor for sale?
BAVAuto is about 120.
Awesomo is offline   Reply With Quote
Old 07-26-2011, 07:01 PM   #39
stapler12345
most likely amazon or autohausAZ
Old 08-01-2011, 04:06 PM   #40
The_Taylor
My Ride: BMW 325i
I will be performing this repair this weekend. I truly appreciate those that take the time to post these DIY guides.
What really sucks is that I replaced the VANOS seals this weekend (easy task in my opinion) and replacing this sensor would have been much easier at that time.
Live and learn....
The_Taylor is offline   Reply With Quote
