Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > California
California
Northern California Southern California
Thread Tools Search this Thread Rating: Thread Rating: 10 votes, 3.70 average.
Old 02-02-2010, 08:33 PM   #1621
wilcax
My Ride: 04 Coupe
i just did my oil change this sunday and i checked how much oil came out. it was only missing about 3/4 of a quart. i change my oil when the cluster tells me to, so i say about 10-12k miles. i do not leak engine oil, so i figure it must be burning a little bit. i'm at 99,100 miles as of today. also i switched over to mobil 1, we'll see how it goes with different oil.
damn issac seems like your check engine light pops up often!
-Wilson
19in. CSL's-H&R race-CSL carbon fiber trunk
wilcax is offline   Reply With Quote
Old 02-02-2010, 11:13 PM   #1622
issacsierra06
My Ride: bmw 325i
yes it sure does... keeps on going on and off..... terry checked it out and came out as thermostat code. thoought by changing radiator and hoses might help
READ BEFORE YOU BUY
issacsierra06 is offline   Reply With Quote
Old 02-03-2010, 01:30 AM   #1623
wilcax
My Ride: 04 Coupe
the thermostats in our cars are computer controlled. its really easy to change it out! you should have replaced it when you did the hoses, might aswell do the water pump too if you havent done that yet.
-Wilson
Old 02-03-2010, 02:15 AM   #1624
issacsierra06
My Ride: bmw 325i
35,xxx miles ago had dealer replace water pupm and thermosat, 20,xxx miles ago i replaced thermostat that would be 3 in three years
READ BEFORE YOU BUY
Old 02-03-2010, 03:05 AM   #1625
wilcax
My Ride: 04 Coupe
damn issac that sucks! i have only replaced mine once.
-Wilson
Old 02-03-2010, 10:17 PM   #1626
thomasstudios
My Ride: Platinum 330Ci
Wilcax is 100% correct. The thermostats are de-energized open and energized closed. Meaning that if or whenever there is a thermostat failure, it will remain open to prevent overheating your motor.
When our engines start, the computer commands the thermostat to close. This will allow the engine to warm up to a certain value. Once the coolant reaches a certain temperature, the water temperature sensor sends that signal to the computer. The computer will then remove power from the thermostat, allowing it to open and send the coolant through the engine block.
Basically, what's happening is your thermostat isn't closing and your engine is working extra hard to try warming up, therefor will run too lean on both banks, giving you the lean codes.
A temporary remedy for this is on your first start of the morning, turn your temperature knob down (till you see three blue dots.) This will keep the heater valve closed. When the temperature knob is high(three red dots), the coolant that is trying to get warm is taking longer because it's running through your heater core to heat the cabin. Keeping the temp knob on cool until the engine warms up will increase your warmup time.
Mods: 19" ST-11's, AC Schnitzer Full Body Kit, Eibach Springs, AC Schnitzer Exhaust, Predator Chromium Angel Eyes, Eclipse Double Din, Tinted LED's.
thomasstudios is offline   Reply With Quote
Old 02-03-2010, 11:43 PM   #1627
wilcax
My Ride: 04 Coupe
i wonder if its just the coolant temp sensor?
-Wilson
Old 02-04-2010, 12:22 AM   #1628
issacsierra06
My Ride: bmw 325i
replaced that not to long ago but when i see terry this weekend i will scan my car again to make sure it is thermostat.( i just cleaned and sprayed my air filter so it might be a dirty maf sensor)
READ BEFORE YOU BUY
Old 02-04-2010, 01:06 AM   #1629
wilcax
My Ride: 04 Coupe
you have a k&n drop in filter? i still use the stock ones i get from the stealer... same goes for my oil filter.
-Wilson
Old 02-04-2010, 01:08 AM   #1630
xJustin
My Ride: '04 330ci
Send a message via AIM to xJustin
anyone in here able to instal headers?
xJustin is offline   Reply With Quote
Old 02-04-2010, 01:16 AM   #1631
wilcax
My Ride: 04 Coupe
i could but i haven't installed them on an e46 before... what kind of headers do you have?
-Wilson
Old 02-04-2010, 01:18 AM   #1632
xJustin
My Ride: '04 330ci
just ebay
Old 02-04-2010, 01:19 AM   #1633
wilcax
My Ride: 04 Coupe
what part of killa cali are you in?
-Wilson
Old 02-04-2010, 01:24 AM   #1634
xJustin
My Ride: '04 330ci
pleasanton. east bay
Old 02-04-2010, 01:30 AM   #1635
wilcax
My Ride: 04 Coupe
i'm too far south to lend a hand... ask in the bay area thread
-Wilson
Old 02-04-2010, 02:55 AM   #1636
issacsierra06
My Ride: bmw 325i
CAI w/ k&n filter ( i try not to use to much oil when recharging) im gonna buy peake scan tool when i get paid though
READ BEFORE YOU BUY
Old 02-05-2010, 01:32 PM   #1637
Richneerd
My Ride: Abarth
Good luck! and damn the infamous E39 seat twist just happened to me. Who wants to do a DIY project with me? haha
Richneerd is offline   Reply With Quote
Old 02-05-2010, 09:32 PM   #1638
issacsierra06
My Ride: bmw 325i
what is that?
READ BEFORE YOU BUY
Old 02-06-2010, 08:40 PM   #1639
issacsierra06
My Ride: bmw 325i
got my thermostat today from weber.... damn they're pricey.
READ BEFORE YOU BUY
Old 02-07-2010, 05:38 PM   #1640
thomasstudios
Should have read wiring first. I recall you saying that you changed at least 2 already.
Rate This Thread
