Old 04-26-2006, 09:37 PM   #1
hifidk
My Ride: 2001 330ci
Tire pressure for Auto X
Yes, this is another thread about the tire pressure.
I searched but I couldn't get answer that I wanted.
Anyways, I have csl replica wheels w/ size 235/35/19 and 245/35/19.
What kind of tire pressure should I have before going to auto X.
This person recommended me to put 4-5 extra psi for that day.
So, what kind of tire pressure do you guys have on autox day?
Oh, and also, how bad is it to have 19 inch wheels at autox?
Thanks in advance!
hifidk is offline   Reply With Quote
Old 04-27-2006, 02:01 AM   #2
vaio76109
My Ride: Race Cars
Start off around 40 or 42 hot. Pressures probably rise 5psi from cold, so say start at 35-37 cold.
vaio76109 is offline   Reply With Quote
Old 04-27-2006, 03:00 AM   #3
hifidk
My Ride: 2001 330ci
Thanks!
Old 04-27-2006, 02:05 PM   #4
leej323
leej323's Avatar
My Ride: '00 323i
Google "unsprung weight". I would stick with 17's for autoX.
leej323 is offline   Reply With Quote
Old 04-27-2006, 06:17 PM   #5
Bim Growl
Banned
Bim Growl's Avatar
My Ride: E86 3.2
When I had street tires, I would start with 36 front, 38 rear, and adjust accordingly. Your tires won't heat up that quickly at auto-x, so you should defintely start with 4-5 psi extra from what you run on the street normally.
Good Luck!!! Have Fun!!!
Bim Growl is offline   Reply With Quote
Old 04-27-2006, 06:18 PM   #6
hifidk
My Ride: 2001 330ci
I would too if I have my stock wheels
Old 04-27-2006, 06:19 PM   #7
hifidk
My Ride: 2001 330ci
Thanks for the comment!
Old 04-29-2006, 05:24 PM   #8
robweenerpi
My Ride: GMC Seirra(Tow Rig)
Most tires have a wear indicator on the shoulder. It's helpful to use it as an indicator for baseline pressure. It'll look like a carrot or an arrow generally. Put enough pressure in the front tires to just keep the wear off that mark. Then adjust the rear pressure to balance the car. You should also mark your sidewalls with shoe polish or chalk to see exactly how much the sidewall is rolling.
robweenerpi is offline   Reply With Quote
Old 04-29-2006, 06:24 PM   #9
hifidk
My Ride: 2001 330ci
I had a auto X today and couldn't use your tips.
However, great tips! I will use them for next event. Thanks!
