Old 05-02-2006, 02:35 AM   #1
Castel101
My Ride: E92 335i, E46 323i
Rattling sound under the car while decelerating, help!
Hi guys,
I have a 2000 323i. I have a rattling sound from under the car. It occurs while decelerating at about 1700 rpm. I'm worried that it might be the Catalytic converter since it's so expensive, or maybe resonators? Any body has any ideas? Thanks!
Castel101 is offline   Reply With Quote
Old 05-02-2006, 11:34 AM   #2
Castel101
Any body? Any opinions?
Old 05-02-2006, 11:37 AM   #3
GarrettF
needs a new sig...
GarrettF's Avatar
My Ride: '02 330Ci
Send a message via AIM to GarrettF
probably a rusted out heat shield, either take it off or replace it it really doens t matter. it is no big deal
[LEFT]
CAR IS GONE
GarrettF is offline   Reply With Quote
Old 05-02-2006, 11:41 AM   #4
speedypm
My Ride: 2004 BMW 325i
I had a similar issue with my '04 325i and upon inspection the dealership indicated it was a loose bearing in my fuel pump. They replaced the fuel pump and the rattling stopped. Not sure if this is the same scenario but hope this helps.
speedypm is offline   Reply With Quote
Old 05-02-2006, 11:41 AM   #5
bimmerbum46
My Ride: sweet pair of Vans
Send a message via AIM to bimmerbum46
it means you cars going to explode!!!!, jk prolly a loose resonator bolt or something, put it up on a lift and check it out
bimmerbum46 is offline   Reply With Quote
Old 05-02-2006, 11:43 AM   #6
Tenchi
Just a Brand-wh0re Elitist
Tenchi's Avatar
My Ride: 330i, 535i
Send a message via AIM to Tenchi
what about the exhaust flap. that rattles when decelerating.
Stay away from FedEx if you want your packages delivered in one piece.
Tenchi is offline   Reply With Quote
Old 05-02-2006, 11:51 AM   #7
sladha
My Ride: '15 M4|'14 X5
In my case the bolts securing the exhaust bracket needed to be replaced as they were rusted. it was loose and caused the rattle.
check this out - i have attached a picuture from BMW service about what needed to be replaced somewhere on the first page:
http://forum.e46fanatics.com/showthr...light=rattling
this may also prove helpful:
http://forum.e46fanatics.com/showthr...ghlight=rattle
No more rattle.
sL
'01 TiAg 330Ci - Modded
'12 ActiveHybrid7
sladha is offline   Reply With Quote
Old 05-02-2006, 03:36 PM   #8
Castel101
Wow guys, thanks for all the replies! The reason I thought it was the catalytic converter was because I had another car that had the same issue and I didn't know BMWs have the cat at the headers which makes it soooo expensive to repair.
But this really makes me feel much better cuz it shouldn't be a big deal. I'll have it checked on the lift then. Thanks!
Old 05-02-2006, 03:40 PM   #9
Castel101
Wow. GarretF, I just had to say it. With that body kit and the rims your car looks awesome man.
Old 05-02-2006, 04:53 PM   #10
GarrettF
needs a new sig...
GarrettF's Avatar
My Ride: '02 330Ci
thank you
[LEFT]
CAR IS GONE
