Miscellaneous
Old 05-02-2006, 05:46 PM   #1
toze
My Ride: 330 CI
Tippman A-5 Response Trigger Paintball Gun with Accessories & Upgrades
This Paintball Gun was used only 4 times. I have always cleaned it after every use and itís in excellent condition.
It has all top of the line upgrades that makes this marker retail over $600 with upgrades.
Iím asking only $350!!!!!!!!
Description of the A-5
The All New Tippmann A-5 is a high performance paintball marker with the patented Cyclone Feed System. The Cyclone Feed System Links the Feeder Sprocket to the Air System. The Faster you shoot, the faster the Tippmann A-5 feeds. Pull the Trigger 15 times a second, and the Tippmann A-5 feeds 15 balls per second. The Tippmann A-5 is also easy to clean and maintain with its no tool field strip feature. Innovative technology, maximum firepower, unsurpassed accuracy and Tippmann durability are the core foundations of the all new Tippmann A-5.
Specs:
∑ .68 caliber
∑ Tippmann A5 Barrel
∑ semi-automatic
∑ 150+ Magazine Capacity
∑ Better Accuracy & Greater Distance
∑ Effective Range 150+ Feet
∑ 15+ BPS
∑ 3.5 lbs
∑ Cyclone Ammo Hopper
∑ Allen Wrenches
Upgrades:
∑ A-5 Response Trigger
∑ Double Trigger by Dead On
∑ PMI PURE ENERGY HPA /NITRO 48 3000 TANK
∑ Dye Boomstick 12 Inch Barrel
∑ Dead On A-5 Front Grip Black
∑ A-5 GRIP ADAPTER BLOCK BY DEAD ON
∑ DROP FORWARD PRO STYLE SERIES BY DEAD ON
∑ PMI Pure Energy In-Line Regulator
Extras:
JT Pro-Flex Mask with Upgraded tinted Thermal lens means NO FOG
Summary: The Tippmann A5 is one of the meanest paintball guns that the recreational player can purchase. The A-5 lives up to Tippmannís reputation for reliability, while still offering one of the highest rates of fire and accuracy for mid-priced recreational markers. The cyclone feeding system, which force-feeds paintballs from the hopper into the chamber, is a valuable and quality mechanism that comes standard on the A-5. Ball-breaks in the hopper are virtually unheard of, and misfires due to misfeeds are equally rare. The A-5 also features easy field stripping, which is one area that Tippmann was known to be weak in before. This marker is ideal for the recreational paintballer, but may be too bulky to be useful to tournament players.
Tippmann Response Trigger kit increases your trigger speed by resetting the trigger and sear with excess gas during firing. This gas is used to operate a cylinder behind the trigger to do the resetting. The pressure of your finger on the trigger pulls it back to fire the next shot. The speed is determined by the amount of flow through the knurled adjuster on the side. The upper limit on the rate of fire is set by this adjuster
PICS:
toze is offline   Reply With Quote
