Sponsored by BAVSOUND
Old 05-11-2006, 03:49 PM   #1
Adenosinebambam
Adenosinebambam's Avatar
My Ride: My Ride
DIY PAC SWI-PS steering wheel ctrl
Here is a little DIY for all of you who have an AVIC N-1/2 and miss your steering wheel controls. I bought a SWI-PS by PAC. This allows you to program your controls. This unit will work on all Pioneer and Sony stereos with wired remote inputs. (You will have to check the page for an actual list) You will have to excuse my digital cam.. for whatever reason all the pics are blurry..
1. I started by taking the panel down from under the dash on the drivers side so I could get to the wires that run up to the steering wheel. There is a pretty thick bundle that obviously goes into the steering column. Just cut the tape holdig them together and fish around in there for a thin wire, white and red with yellow dots. This will apply to most 3 series BMWs 00-05, with a few that actually use a white and grey with yellow dots.
2. Pull your AVIC back outta that mounting hole.. I know it was hard to get in there in the first place but tough luck. (This is assuming you installed it yourself, If you didnít, you need to pull the trim off the dash, pop your heating controls out and remove the cables, unscrew the stereo from in place etc.) I ran the yellow wire along where I ran the wires to my amp, down the left hand side of the dash to the drivers foot pedals. If you shine a flashlight at your pedals, you can see the light below, aim your wire there! I bundled the wires you donít need together, as you only use the red, black, and yellow. Keep the red and black at the top, and once you run the yellow wire get down where you already exposed that red/white/yellow dot wire. Cut the wire in half, and connect the yellow wire to the wire that is goin UP to the steering wheel. Insulate the other piece of wire.
3. Connect the red to the 12+ ignition. I used wire taps into the wires I already used for the stereo. Same with the neg. ground.
4. Connect the jack into the connection for the wired remote on the AVIC head unit. Now tuck everything away nicely. Keep the SWI-PS module sticking out, you will need the button to program.
5. Get programming! The directions included are pretty straight forward. I memorized the steps and it still took me a couple of tries to get it right, it is just that the button programming only gives you about 5 seconds between buttons, and if you get flustered you have to start over. (Not a big deal). I programmed my volume up.down, mute as the RSC button, track up.down, and the little phone button is my source.
6. Tuck the module away. I put all of my wires in the upper left corner with the harness and the module fitting nicely. Put your trim on and go for a drive!
I love it.. I can shift while I change channels again! It took me only about 30 minutes with taking the pics.
All of my FS items may be listed on other forums as well. Thanks.
~Tom
Adenosinebambam is offline   Reply With Quote
Old 03-03-2007, 04:42 AM   #2
RichieE46
My Ride: E46
Sorry for bringing up a old thread but didnt want to start a new one.
I did the same thing as u...used the R/T button to program for source.
The problem is when I put the key in to turn to "on" position, the headunit changes source constantly every 2 seconds. Its not until I push the R/T button, that it stops and acts normally. How do I stop this?
RichieE46 is offline   Reply With Quote
Old 03-04-2007, 01:27 AM   #3
RichieE46
My Ride: E46
Well nm I figured out the problem after more research...to those that find this thread...
R/T button sends a test signal 2 or 3 times when u turn it to the ON position...so its better that you NOT program the R/T button unless you want to deal with the problem.
Old 03-05-2007, 09:48 AM   #4
Adenosinebambam
My Ride: My Ride
?? I never had this problem.. Maybe it it something with the newer cars.
~Tom
Old 03-05-2007, 12:28 PM   #5
ca1242
My Ride: 2003 330i
All the old and new cars I have done do the same thing with the R/T button.
Old 05-27-2007, 12:32 PM   #6
gazfatha323i
E46 Spartan
My Ride: 04 CB/IR M3
Send a message via AIM to gazfatha323i
DId you have avic-n1 or N2
I have n1 and wondering if its compatiable
Carbon Black / IR ///M
gazfatha323i is offline   Reply With Quote
Old 05-27-2007, 06:03 PM   #7
ca1242
My Ride: 2003 330i
Yes, but you do need to have the pioneer remote for programming. I believe you have to buy it separately for around $30.
You are probably better off getting an SWI-PS model. No remote required, no infrared eye to mount. Plugs directly into the pioneers.
Old 05-28-2007, 10:41 AM   #8
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I must REALLY suck at this. I have the Eclipse version...still can't get it right. I must be retarded. I've spent at least 4 hours on it.
One more try...then I'm trashing it.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 05-28-2007, 01:23 PM   #9
BreakMyWallet
My Ride: B6 A4/ Mini Cooper S
nice diy
BreakMyWallet is offline   Reply With Quote
Old 05-28-2007, 05:31 PM   #10
jammykam
My Ride: 2003 330Ci Step Vert
Excellent DIY
Just found out about this product a few weeks back from another member so may install one myself.
Cheers
///Kam
jammykam is offline   Reply With Quote
Old 05-28-2007, 09:31 PM   #11
ca1242
My Ride: 2003 330i
I've never had any problems with it. Let me know if you need help.
Old 05-29-2007, 05:32 AM   #12
bigjae1976
bigjae1976's Avatar
I got it right and then I had to disconnect the battery for some reason. I always forget about the R/T button too.
Old 05-29-2007, 06:59 AM   #13
ca1242
My Ride: 2003 330i
...well, there is a way to make the R/T button work. Involves minor rewiring at the steering wheel button harness and adding a resistor. If you are interested, I have diagrams.
Old 08-03-2007, 04:43 PM   #14
BreakMyWallet
wait so you only use 3 wires? red/black/yellow? is that just for pioneer?
Old 08-03-2007, 05:36 PM   #15
amunoz27e
My Ride: 325ci
On an excellent DIY to use. Now I know which wire to cut exactly.
Bilstein PSS10 Coilovers | Highline Tuning Catback Exhaust | Double Din Audio | Lots of Carbon Fiber Interior/Engine Bay | 19x8,19x9.5 Wheels | RIP - Reiger Body Kit .
amunoz27e is offline   Reply With Quote
Old 08-04-2007, 10:21 AM   #16
HalcyonTwilight
My Ride: '03 M3, '99 323i
I'm trying to get this installed for my N3 but the installer is telling me that it's not compatible... is this true? Please help, urgent need of help! thanks if anyone can chime in a timely manner...!
HalcyonTwilight is offline   Reply With Quote
Old 08-04-2007, 10:21 AM   #17
ca1242
My Ride: 2003 330i
Not compatible to the car or to the N3?
Old 08-04-2007, 10:46 AM   #18
HalcyonTwilight
The N3... the PAC adapter has what looks like a headphone type adapter, but there aren't any ports to plug it into (all to small)... did I get the wrong one somehow? It does say PAC-SWIPS on it. Thanks if you can help, typing this from my phome right now!
Old 08-04-2007, 11:20 AM   #19
SamXp
My Ride: 2011 WRX
Send a message via ICQ to SamXp
N3 is indeed listed as compatible with the SWI-PS...
http://www.pac-audio.com/swi-compati...acture=pioneer
I'd call PAC and ask them what's up. You sure you don't see a 1/8" jack in the back for a wired remote?
SamXp is offline   Reply With Quote
Old 08-20-2007, 11:18 AM   #20
GarrettF
needs a new sig...
GarrettF's Avatar
My Ride: '02 330Ci
Send a message via AIM to GarrettF
BUMP
I called PAC and they said my car has some wire in it that doesnt let the PAC work I think it is called a "5volt swc wire" it is the wire for the cellular phone... can anyone confirm this or is there a workaround? my car is an 02
[LEFT]
CAR IS GONE
GarrettF is offline   Reply With Quote
