Sponsored by The Tire Rack
Old 05-12-2006, 12:04 PM   #1
sladha
My Ride: '15 M4|'14 X5
will these ACS wheels fit an '01 330Ci?
Will the following AC Schnitzer Type III wheels fit my 330Ci (prefacelift)?
FRONTS.
245/35/19 fronts. 8.5 X 19 offset ET15
REARS
265/30/19 Rears. 9.5 X 19 offset ET21.5
or will fender(s) need to be rolled? I have m3 FRONT fenders, but stock 330Ci rear fenders.
thanks.
sL
'01 TiAg 330Ci - Modded
'12 ActiveHybrid7
sladha is offline   Reply With Quote
Old 05-12-2006, 10:45 PM   #2
hosagod
My Ride: Facelift Ci
You won't be able to accomodate the rears with 330Ci fenders,even with rolling.
hosagod is offline   Reply With Quote
Old 05-12-2006, 11:45 PM   #3
sladha
is it because of the offset, rim size, or tire size???
'12 ActiveHybrid7
Old 05-13-2006, 01:19 AM   #4
hosagod
The offset, tire size and rim size are OK.
Old 05-13-2006, 01:45 AM   #5
sladha
VERY helpful , thanks buddy
'12 ActiveHybrid7
Old 05-13-2006, 02:53 AM   #6
hosagod
Your welcome...for 330Ci the offset can be anywhere from 35 to 45, just incase you wanted to know...
Old 05-13-2006, 09:25 AM   #7
sladha
'12 ActiveHybrid7
Old 05-16-2006, 09:05 AM   #8
sladha
i've been told that i could get the rears to fit if i run 235/35/19 tires (with the ET 21.5 offset rims)? i know u mentioned the offset is the issue, so is what i'm being told misleading? thanks
'12 ActiveHybrid7
Old 05-16-2006, 11:07 AM   #9
SkipII
My Ride: 2001 330 Ci
Not a good match
235 is too stretched for a 9.5 rim.
I hope you got these wheels dirt cheap or free. They really don't fit your car -- offset needs to be 40-45 as Hosagod said.
SkipII is offline   Reply With Quote
Old 05-16-2006, 11:16 AM   #10
sladha
thanks - to both of you. i have not bought the wheels yet, and was about to spend a lot of $$$ on them, but this info. has saved me from doing so. btw, what do u mean by "too stretched"??
sL
'12 ActiveHybrid7
Old 05-16-2006, 11:50 AM   #11
Jeff43
next mod: recaro child seat
My Ride: smells like surf wax
sL
a 9.5" wide rim is too wide for only a 235 tire...the sides of the rim will be exposed (and vulnerable to damage) and the tire will look too narrow for the rim.
Jeff43 is offline   Reply With Quote
Old 05-16-2006, 02:26 PM   #12
sladha
good to know thx
'12 ActiveHybrid7
