Thread Tools Search this Thread Rating: Thread Rating: 30 votes, 4.90 average. Display Modes
Old 06-27-2010, 05:47 AM   #61
blarf
My Ride: 323i, 325iT, 540iT
Originally Posted by Daemonix View Post
I've removed my plastic under engine guard probably 4 years ago. Tired of removing the thing all the time to work on the undercarriage. No issues thus far. It's a piece of plastic.
Originally Posted by officer140 View Post
The dealership never put my underguard back after some warranty work was done. Months later, I did my oil level sensor and saw the underguard missing - WTF! Needless to say I don't go to the dealership - warranty or not! No damage to my undercarriage in years! Like someone said - it's just a piece of plastic.
The plastic splash shield is not a structural component... and is not fastened with hefty TTY bolts. The metal plate behind it is.
Class of '03 and '07 ftl.
Originally Posted by howie View Post
do you park near poodles?
blarf is offline   Reply With Quote
Old 08-09-2010, 03:12 PM   #62
Tede46ci
My Ride: 2001 325ci
Originally Posted by 2K5 325i View Post
from the past...
My oil light comes on for like 15 seconds, and then goes off. Usually after the drive, and I've turned off the ignition.
That, and my coolant level light is coming on for 10 seconds at a time in the middle of every other drive.
I dunno what is wrong with my car!
-Chris
Same problem with my car.. Wer can I order the parts for great price? Like if I change the coolant expansion tank along with hose,water pump?? Thanks in advance
Tede46ci is offline   Reply With Quote
Old 08-09-2010, 03:18 PM   #63
dryan81
My Ride: .
getbmwparts.com
Tischer is grrreat ! (said like Tony the Tiger)
dryan81 is offline   Reply With Quote
Old 02-04-2011, 01:41 PM   #64
E46randal328
My Ride: bmw328i
www.*************** sells this and many other bmw parts that commonly fail at extremely low prices, i buy everything from them, except when its less than 10$ at the the bmw dealer.
E46randal328 is offline   Reply With Quote
Old 02-04-2011, 07:33 PM   #65
Sansho
My Ride: 2001 325i
Well this is certainly a valuable post.
Sansho is offline   Reply With Quote
Old 07-22-2011, 02:27 PM   #66
JG330i
My Ride: '03 330i ZHP
Awesome find, will be doing this soon!
JG330i is offline   Reply With Quote
Old 10-23-2011, 04:17 PM   #67
yenghead
My Ride: 325i Msport
All you guys who post answers to the many questions we have are just GREAT. Thanks 2 you all...
yenghead is offline   Reply With Quote
Old 01-03-2012, 06:57 PM   #68
jookdoree
My Ride: 2005 330ci Coupe e46
yup this seem to be a very common issue... I had mine replaced last year... and guess what the light came on gain! I'm just going to wait till i get my oil change to have it replaced since it requires emptying the oil.
Thanks~!
jookdoree is offline   Reply With Quote
Old 01-03-2012, 07:10 PM   #69
bmwTuner1
My Ride: Bmw, 330ci
Im having the same issue with my oil light. Its too bad I just replaced my oil 400 mi ago but Ill def be taking care of this on the next oil change. Good thread
Photobucket
bmwTuner1 is offline   Reply With Quote
Old 03-24-2012, 12:29 AM   #70
littlegti
My Ride: 2002 330ci conv
I have this problem as well, but it only happens on like every 10th trip. I kinda like it because it reminds me to check my oil level regularly - as long as the light goes out quickly.
littlegti is offline   Reply With Quote
Old 04-09-2012, 07:56 PM   #71
Guram1993
My Ride: 325ci
http://www.oembimmerparts.com/catalo...40/4402069.htm
95$
Guram1993 is offline   Reply With Quote
Old 04-09-2012, 08:01 PM   #72
Guram1993
My Ride: 325ci
http://www.ecstuning.com/BMW-E46-325...rch/Oil_Level/
41$
Old 05-19-2012, 09:51 AM   #73
longtran1
My Ride: 2001 BMW 325CI
Thanks! This really helps.
longtran1 is offline   Reply With Quote
Old 05-19-2012, 09:54 AM   #74
longtran1
I bought my oil level sensor on ebay for $30.
http://www.ebay.com/itm/160773706558...witem=&vxp=mtr
Old 06-18-2012, 06:06 PM   #75
steveybrown
My Ride: 325i
Just curious, has anyone ever tried removing and cleaning the oil level sensor rather than just replacing it. I've heard from a friend he ran sea foam in his oil and it fixed the reading on his oil level sensor. I was thinking about removing and cleaning the sensor with some break cleaner or something like to see what would happen
steveybrown is offline   Reply With Quote
Old 06-19-2012, 08:53 AM   #76
longtran1
It's probably a good try. When replaced my oil level sensor it seemed very dirty with buildup on the dip.
Old 08-16-2012, 12:30 PM   #77
glass330
My Ride: 323ci to 01 330i
Just bought one for $23 on ebay
glass330 is offline   Reply With Quote
Old 08-16-2012, 01:05 PM   #78
pawelgawel
My Ride: 330CI
get ready to spend more :p
When replacing any sensors on these cars you NEED to use OE or OEM. BMW or Hella for this oil level sensor. Hella makes them for BMW.
Others will leak and will stop reading within weeks. Especially ebay crap. This has been discussed planty of times.
Sent from my SGH-I727R using Bimmer App
pawelgawel is offline   Reply With Quote
Old 08-16-2012, 02:51 PM   #79
haurelio
My Ride: 2001 bmw 325i
listen to this guy. return it if haven't changed that part yet, and get a hella sensor.
Old 08-17-2012, 09:22 AM   #80
steveybrown
My Ride: 325i
Why would you not use original equipment
Why would you even go to all that effort of replacing the part with a cheap 3rd party knowing its not going to be as good and probably going to end up doing it again on you're next oil change when you could do it right the first time for only a little more money. I'm saving for the part right now as this is next on my list of DIY
Projects still left to complete
Coils and o2 sensors
wheel bearing
Control arm bushings
Oil pan gasket
New working remote key
