Sponsored by The Tire Rack
Old 05-29-2006, 06:49 PM   #1
jeremysmith1967
a.k.a. Norton
My Ride: 00 328ci & 67 stang
Send a message via AIM to jeremysmith1967
tire size for staggard 19s
i am about to buy some 19" rims and i was wondering what the recommended tire size is for a 19x9.5. i know that 19x8.5 is 235/35/r19 but what would be the best for the rear? any help is appreciated.
jeremysmith1967 is offline   Reply With Quote
Old 05-29-2006, 09:08 PM   #2
hosagod
My Ride: Facelift Ci
245/35/19 if you like a thin tire (stretched look) or 265/30/19 if you like a nice, wide tire.
The 265 is best for the rear because the front is 235 and so that gives you perfect staggered fitments.
hosagod is offline   Reply With Quote
Old 05-29-2006, 10:22 PM   #3
Funfgang
My Ride: 07 s8,04 gt3
ide go 225/45, 255/45
Funfgang is offline   Reply With Quote
Old 05-29-2006, 10:46 PM   #4
TitanSilber ZHP
TitanSilber ZHP's Avatar
My Ride: 08 E90 335i
Send a message via AIM to TitanSilber ZHP Send a message via Yahoo to TitanSilber ZHP
what!?!?
| Andrew | M Technik | BMW Performance | 3M | V1 | LUX 5.0 | Bilstein PSS9 | Precision-Sport |
FS: Camera Mount:http://forum.e46fanatics.com/showthread.php?t=694858
TitanSilber ZHP is offline   Reply With Quote
Old 05-29-2006, 10:48 PM   #5
jeremysmith1967
a.k.a. Norton
i was thinkin the same thing.
Old 05-29-2006, 11:16 PM   #6
bluecougar
A bimmer chick moderator :)
bluecougar's Avatar
My Ride: MB & LR3
goodluck fitting 255 in front
||Just another ///M Female Driver||Sold: E46 328ci||E92 335i||E60 M5||
bluecougar is offline   Reply With Quote
Old 05-30-2006, 11:16 AM   #7
GIO_21
My Ride: Active HKS Blown
Send a message via AIM to GIO_21
255 in the front is to big go with 235 or 225 in the front n the rear has a lot of options to choose from....i myself am still deciding what to put on the rear wheel, with the same setup u have
GIO_21 is offline   Reply With Quote
Old 05-30-2006, 11:51 AM   #8
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Front 19" is normally 235/35R19. 225/35R19 will also fit. Rear is typically 245/35R19, 255/30R19, or 265/30R19. Keep in mind that in some cases these sizes may need some fender lip rolling and/or more negative camber.
http://www.tirerack.com/a.jsp?a=BN4&...ires/index.jsp
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 05-30-2006, 12:36 PM   #9
Funfgang
uhh ya...whats the problem with 225/35 in front and 255/30 in rear...
Old 05-30-2006, 01:27 PM   #10
bluecougar
bluecougar's Avatar
My Ride: MB & LR3
nothing
Old 12-24-2006, 12:43 PM   #11
Coupe E36
My Ride: E36 325is/E46 330ci
so what tire size did you end up going for the rears ??? i have a problem. .ahha.. i did 265 on stock suspension and rubbing was only when tehre was heavy load in rear, now i have dropped it with H&R springs and now it rubs everywhere.. I am not sure if its only Fender Rubbing, hopefully that is the case and if so i can just get the fenders rolled ?? if not then i might have to go and downgrade to 255's
Coupe E36 is offline   Reply With Quote
Old 12-24-2006, 01:25 PM   #12
SkipII
My Ride: 2001 330 Ci
Offset
Offset, offset, offset....offset
SkipII is offline   Reply With Quote
Old 12-24-2006, 02:24 PM   #13
NYSpeedRacer
My Ride: Straight Pipes
If I was looking for a stagger setup for my 330I what would be the optium offset if I intend to run 235/34 Front and 265/30 Rear?
TiAG l 2001 l 330I
Freeflow Headers l Mandrel Bent Straight Pipes l Eisenmann
Tein SuperStreet Coilovers w/ EDFC
Hartge Classic 19x9 Front 19x9.5 Rear l Michelin Pilot Sport 2
UUC SwayBarbarians l UUC EVO III SSK w/ DSSR
TMS Rear Adjustable Camber Arms l TMS Rear Shock Mounts
TMS Rear Shock Tower Plates l TMS Trailing Arm Limiter
NYSpeedRacer is offline   Reply With Quote
Old 12-26-2006, 03:10 PM   #14
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
for our staggerred VB3 CSL reps, we most commonly use 235 front and 265 rears.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 12-27-2006, 02:08 AM   #15
D0n Raja
My Ride: 330ci 04
if you have 255 or 265 how does it affect the driving of your car?
D0n Raja is offline   Reply With Quote
Old 12-27-2006, 02:13 AM   #16
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
i have 235 in front and 265 in the rear
Timeless Motor Group
Old 12-27-2006, 09:57 AM   #17
Art Bimmer
My Ride: 2004 E46 Coupe
what's your off set? wheel size & what type of lowering kit?
I'm getting closer
Art Bimmer is offline   Reply With Quote
Old 01-03-2007, 12:58 AM   #18
xmltok
My Ride: 2014 Carrera 4S
Send a message via AIM to xmltok
what offset is ok for 265? I will have a 40mm offset (bbs ch 19x9.5) with H&R cupkit
xmltok is offline   Reply With Quote
Old 01-03-2007, 11:14 AM   #19
Art Bimmer
After a lot of searching... and before purchasing wheels and tires, I asked my son which wheel size he'd like the best, 19's or 18's (He's 14) He asked me, what type of driving do you like? Pretty simple question. I like city driving! I like drifting around street corners at nite, changing 4 lanes of traffic to make a exit, whipping a u turn with a quickness Love that sh!t think I'm gonna do 18's 18X8.5f 18x9.5R. Why 19's? 18's for go, 19's for show, right? and driving is more the going in a straight line
