Thread Tools Search this Thread Rating: Thread Rating: 52 votes, 4.92 average. Display Modes
Old 06-09-2006, 01:29 PM   #21
SMTraxx
My Ride: M3
this helped my problem with the "hard to open door" issue and it did work for me. go buy a can of WHITE LITHIUM GREASE and spray liberally on the door latch and where it connects to the door.
i got this from watching a show on car maintenance on the speed channel. the can is like 4 bucks from autozone and now i can open my doors with one finger!
hope this helps!
sorry, but im kinda new to posting, so i dont know how to post pics yet. If you dont know what im talking about, just look at Smoof15's pic in the 1st post. spay in the opening you see in the pic (you dont need to remove the cover or anything, its open) and where it "connects" to (the hook like thingie).
SMTraxx is offline   Reply With Quote
Old 06-09-2006, 01:42 PM   #22
Imola.ZHP
My Ride: Imola ZHP
Ima try to do this when I get home...
I have no issues, but when I showed my mom my new-to-me car, she had to use both hands to pull on the door handle, to get it opened...
Its also awkward for women to understand you have to pull up slightly, my Titan had these big chrome handles that pulled straight out. Everyone thinks the BMW is the same way, but its not...
-- '03 330i ZHP
-- Marcus
Imola.ZHP is offline   Reply With Quote
Old 06-09-2006, 02:14 PM   #23
46_coupe
My Ride: is lame
yeah this problem is not isolated to BMWs, my lexus is the same way (same type of handle as well)....my ex gf couldn't even open the damn door when we used to be ready to go home i'd be starting up the car playing with my ipod and she'd be knockin on the glass like it was locked ...low and behold I walk around the car and open the door like i have the magic touch or something
"As soon as you're born, you start dying, so you might as well have a good time" - Cake
46_coupe is offline   Reply With Quote
Old 06-09-2006, 04:58 PM   #24
rneily
My Ride: 2001 Ti. Silver M3
I too just looked this up in the TIS and tried to tighten the allen screw in the door. It should be noted that acording to the TIS that you shouldnt tighten to more than 5 Newton Meters, which isn't much.
Regardless, on my doors, it didnt seme to help much. My next step is to try some lithium grease on them, hopefully that will make things a little easier.
rneily is offline   Reply With Quote
Old 06-12-2006, 06:59 PM   #25
supark
My Ride: E60 M5, 69 02
yeah - I tried again on mine and still no improvement. I started to feel the bolt starting to stretch, so i decided to leave it be and will just grease things up when I get a chance.
supark is offline   Reply With Quote
Old 06-12-2006, 11:23 PM   #26
rneily
I'm in the same boat. I tried to tighten the bolts again just to make sure, and I even loosened them as someone else in this thread mentioned.
Futhermore I even greased the lock mechanisum in the door with lithium grease... My doors are still hard to open.
Either my doors are not that bad (I have nothing to compare them to) or I'm not doing something right..
Old 06-14-2006, 03:06 PM   #27
guest1017
Banned
guest1017's Avatar
My Ride: M3
Send a message via AIM to guest1017
going to try this now! thanks
guest1017 is offline   Reply With Quote
Old 06-15-2006, 02:14 AM   #28
vanCOUPEr
My Ride: 01 330Ci
Bentley says....
with the door open, use a screwdriver to flip the door latch to the closed position. Pull on the outside door handle. If the latch unlocks, then no adjustment is necessary. If the latch does not pop open, LOOSEN the adjustment screw and then retighten. Simply tightening the bolt without loosening it first will not do anything (unless it may have been loose in the first place). Note that the right side door has a LEFT hand thread on the adjustment screw (clockwise to loosen, counterclockwise to tighten).
I guess loosening/retightening resets something and it worked like a charm for me. Bentley also says that if this does not work, you must replace the door lock.
vanCOUPEr is offline   Reply With Quote
Old 06-23-2006, 03:53 AM   #29
timmay77
Burns Rubber(s)
timmay77's Avatar
My Ride: My Wifey
I can't even explain how happy I am right now. My 10 yr old had the HARDEST time opening my door until I read this thread. She had to pull on it with all of her body weight! I adjusted that bolt, and VWALAH!! Like another person posted, I can open it with my pinky!! Thanks a million!!
timmay77 is offline   Reply With Quote
Old 06-23-2006, 11:37 AM   #30
BMW343hp
My Ride: E46M3 and E36M3
great info. will try this tomorrow
many thanks
BMW343hp is offline   Reply With Quote
Old 06-23-2006, 01:33 PM   #31
RUA
My Ride: 320CI
Send a message via MSN to RUA
when RELAXING the adjustment screw I must later return it to tighten?
RUA is offline   Reply With Quote
Old 08-01-2006, 10:18 PM   #32
buddyclubinteg
My Ride: hates pot holes...
OMG! when i read this the other night, i was sorta skeptical about doing this since i've tried using the grease on the locking mechanism. For almost 2 years, ive had this horrible door opening problem and was on the verge of allowing the dealership to rob me and repairing the problem until today. Today after work, i went home and opened my trusty toolbox and tried the adjusting the the door clockwise on my driver side door, and BAM! Problem was solved! I still cant believe it! thanx alot to smoof15
buddyclubinteg is offline   Reply With Quote
Old 08-01-2006, 10:29 PM   #33
iamapato01
My Ride: bmw
I just sprayed wd40 in the latch and it turned to butter
iamapato01 is offline   Reply With Quote
Old 08-03-2006, 12:36 AM   #34
FutureMD32
My Ride: 2004 M3
Praise jesus! the door is fixed! hip hip hoorayy!
Golly jee i'm elated.
It was so embarrasing having to tug hard on that door.
Thanks to all!
2008 CLK63 Black
2006 CLS55 AMG
2004 BMW M3
1998 Nissan S14 240sx, powered by RB26
1990 Nissan S13 240sx, 630 whp SR20DET
1995 Subaru Legacy, EJ20R, 410 whp
Soon to have 2011 Ford Mustang 5.0
FutureMD32 is offline   Reply With Quote
Old 08-03-2006, 12:57 AM   #35
Commander FAT
Network Analyst
My Ride: 2002 330Ci
You sure it's a 5/32" allen wrench? Have you tried using a metric wrench?
Because the B isn't for bling.
Commander FAT is offline   Reply With Quote
Old 08-04-2006, 11:33 AM   #36
Pmack325Ci
My Ride: 330i ZHP
Man, wish I would have ran across this thread a couple days ago. Just checked my car into BMW for this exact problem. Oh well, I will know for next time and it's covered under warranty for now
Pmack325Ci is offline   Reply With Quote
Old 08-05-2006, 08:24 PM   #37
MichelleJD
My Ride: 2000 BMW 328Ci
Didn't work for me either. Guess I need a new door lock
2000 328Ci - Siena Rot/Sand - OEM M styling, "Emmy."
1986 Porsche 951 - Black/Champagne - a mod or two, "Anita."
MichelleJD is offline   Reply With Quote
Old 08-05-2006, 08:29 PM   #38
OrangeCountyDav
My Ride: 2000 323ci
My 2000 323ci has such heavy doors, being a coupe and all. They open easy enough, but sometimes when someone parks incredibly close, you can't get it past the point where it holds itself open. It sucks crawling into your car hah.
Car is sold.
OrangeCountyDav is offline   Reply With Quote
Old 08-06-2006, 10:19 AM   #39
law1saw1
My Ride: 2000 323CI
Thanks too all, Door was getting hard for me to get in in it let alone the girlfriend and valets. I just tried clockwise first and it only helped a little. I loosened screw as mentioned earlier and the tightened it as much as I could and it is much better. Not perfect. Thought of trying again but will leave sleeping dog lie for now.
law1saw1 is offline   Reply With Quote
Old 08-08-2006, 12:00 AM   #40
Lucino305
My Ride: 99 328i
we are talking about the actual door handle correct? or is it the locking system
Lucino305 is offline   Reply With Quote
