How to clean MAF - NEED HELP!! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 06-07-2006, 01:34 PM   #1
B1MM3R
My Ride: AW/IR M3
Question How to clean MAF - NEED HELP!!
I did a search but wasn't able to find a DIY on cleaning the MAF. I've heard that cleaning it makes a world of a difference in older Ms so want to give it a try.
More detailed the better and pics would be great. Thanks in advance !
B1MM3R is offline   Reply With Quote
Old 06-07-2006, 01:40 PM   #2
cimbali
My Ride: 323i
http://www.louv.tv/cars/m5/MAF/
cimbali is offline   Reply With Quote
Old 06-07-2006, 03:50 PM   #3
325myAZ
My Ride: 2001 325i
Some people shy away from using q-tips on the sensor and instead prefer using electrical contact cleaner. Make sure that it is "plastic safe". It dries almost instantly and leaves no residue. Just make sure that the force of the spray doesn't damage the sensor wires, by keeping it at a safe distance. (6 - 8" or so)
http://www.crcindustries.com/catalog...sers/02016.jpg
325myAZ is offline   Reply With Quote
Old 06-08-2006, 03:07 AM   #4
332ic
My Ride: W211 E55 AMG
All you got to do is this http://www.crcindustries.com/files/M...0FINAL%202.pdf and spary the crap out of it then let it dry. I have done cleaning AFM with this many times.
http://www.shop.com/op/aprod-p357627...ver?sourceid=3
332ic is offline   Reply With Quote
Old 06-08-2006, 06:46 AM   #5
Ivegotissues666
My Ride: 88' BMW E30 SETA
Send a message via AIM to Ivegotissues666
If it's not giving you problems then I honestly would just leave it alone. Not worth possibly damaging it.
Jared
Ivegotissues666 is offline   Reply With Quote
Old 06-08-2006, 09:58 AM   #6
B1MM3R
My Ride: AW/IR M3
So do I spray the sensor itself (the one pictured below)
and the mesh end (pictured below)?
Or is it just one or the other? I'm not sure which part needs the cleaning. And the only thing I need is the CRC Mass Air Flow Sensor Cleaner and let it air dry after spraying? No wiping or cleaning? Just spray?
Also, is it really necessary to lubricate it as it says in the DIY? Thanks !
Old 06-08-2006, 08:11 PM   #7
325myAZ
My Ride: 2001 325i
Look at the picture that says: "Gently swab sensors with Q-Tips"
This is where you want to spray. No swabbing required. Less risk of damaging the wires.
The CRC product will dry almost instantly and leave no residue.
Spray it a couple of times, and from different angles.
Follow the air flow path, then go against the air flow path.
You can spray the "mesh" with the CRC product, or you can clean that part as indicated. The mesh isn't an expensive and fragile component. The sensor is! If you want, you can skip cleaning the mesh part.
The vaseline is probably used for a couple of reasons... to assist in reassembly and sealing. I'd follow the directions, just use it sparingly.
Old 06-09-2006, 09:32 AM   #8
B1MM3R
My Ride: AW/IR M3
Thanks! I'll try it out this weekend.
Old 08-17-2006, 12:10 PM   #9
M3LTDOWN
M3LTDOWN's Avatar
My Ride: Range Rover on 22's
Send a message via AIM to M3LTDOWN Send a message via MSN to M3LTDOWN
Sorry to bring this one back to life...but where can I buy this CRC cleaner???
M3LTDOWN is offline   Reply With Quote
Old 08-17-2006, 12:22 PM   #10
markusmark
My Ride: 2001330Ci
Pep Boys
markusmark is offline   Reply With Quote
Old 08-17-2006, 01:43 PM   #11
M3LTDOWN
M3LTDOWN's Avatar
Originally Posted by markusmark View Post
Pep Boys
Thank you.
Old 01-27-2007, 05:36 PM   #12
Jon325iT
My Ride: 2002 325iT
Just cleaned my MAF sensor with the dedicated spray only (no q tips). Haven't really driven around to see if there is any difference. Has anyone noticed a difference with cleaning?
Jon325iT is offline   Reply With Quote
Old 01-27-2007, 07:55 PM   #13
Jon325iT
My Ride: 2002 325iT
Shizit! While I was inside my wife got in the car to move it. I hadn't hooked the MAF back up again. The service engine soon light obviously came on. I hooked it up and the light is still on. Will SES light auto reset after a little driving or do I need to get it reset?
Old 01-28-2007, 06:29 AM   #14
phelix
My Ride: 328i
Make sure you use a cleaner that doesn't contain a lubricant as that will leave a residue behind.
phelix is offline   Reply With Quote
Old 01-28-2007, 01:42 PM   #15
r6vr6
My Ride: 2002 ///M3
Should go away after a few key cycles. Could try pulling the fuse for the engine control module or disconnecting the battery too.
r6vr6 is offline   Reply With Quote
Old 01-29-2007, 10:42 AM   #16
Jon325iT
My Ride: 2002 325iT
Yep, it went away on it's own.
The car does seem to be running better in subtle way. I drove around the olympic mountains yesterday and I got 2 more miles per gallon than I usually average. Anecdotal evidence at best but cleaning the MAF sensor is a quick and easy thing to do.
Old 02-17-2007, 10:41 AM   #17
Marten
My Ride: 323i Convertible -00
I cleaned my Maf today with the crc maf cleaning spray, and I cant say I feel any difference from before. But at least its clean as a babys bottom now=)
The fuelfilter swap I did yesterday did=))
Marten is offline   Reply With Quote
Old 02-18-2007, 09:24 PM   #18
2005_330xi_BMW
My Ride: 330xi
ditto. Noticed no change, but at least I know my stuff is clean.
2005_330xi_BMW is offline   Reply With Quote
Old 04-01-2008, 09:55 AM   #19
bradley01
My Ride: '02 330xi
Can you remove that plastic mesh screen for more improved air flow? Or does it hurt the MAF if you do that?
'02 330xi
Springfield, IL
bradley01 is offline   Reply With Quote
Old 04-02-2008, 11:10 PM   #20
bmw_chuzo
My Ride: HPF M3
Send a message via MSN to bmw_chuzo
^ it hurts the maf and your performance..
bmw_chuzo is offline   Reply With Quote
