Old 01-02-2013, 12:09 PM   #1
fred0k
My Ride: 2000 328
doors locked..help please
2000 328 coupe..Both frt doors are locked and woulhn't unlock or open from the inside or outside.I have the remote and still won.t unlock..I have had to pull on the drivers handle a few times to get it to open in the past.So I'm guessing the Latch actuator has gone bad...But now I can't get the door open to replace it..I have pulled the frt seat and have the door panel off and pushed and pulled on all the rods/cable ect that i can fine but still can't see a way of releasing the door latch..help
fred0k is offline   Reply With Quote
Old 01-02-2013, 12:14 PM   #2
jerseyzillest
My Ride: 325 CI
You have a coupe climb through the trunk.
Photobucket
^Taken with iPhone^
:rofl:
jerseyzillest is online now   Reply With Quote
Old 01-02-2013, 12:38 PM   #3
fred0k
My Ride: 2000 328
I did..Thats how I got the window down to remove the seat and the door panel..But I still can't find a way to release the door latch to get the door open...
Old 01-04-2013, 01:22 PM   #4
dirty vert
My Ride: 2001 330ci
Your GM5 module is acting up... Two relays and a few hours of leisure time. There isn't a release for the door unless it is unlocked- in which the current supplied to the locking actuator (inside your door) doesn't have-- so it will not release. I have a vert, and went through this recently. Once you have it unlocked, do not lock it again or you get the same outcome.... (search GM5 module)
fyi, our cars "lock" down the door handles in 15-20 minutes of inactivity... I had to climb over the rear windows into my backseat....and then had to climb over my door to get out.. PIA!!!
dirty vert is offline   Reply With Quote
