Sponsored by BAVSOUND
Closed Thread
Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 5.00 average.
Old 04-01-2007, 05:36 AM   #801
kyle e46
My Ride: 325xi
question, i have a ton of extra slack of cable left over, where do you guys normally leave it?
kyle e46 is offline
Old 04-01-2007, 10:25 PM   #802
tom @ eas
european auto source
tom @ eas's Avatar
My Ride: e92 S/C M3
Originally Posted by Nait Sirhc View Post
Quick question... sometimes when I fire the car up, the radio display says "PAUSE". What's the easiest way to unpause it? It usually requires me to skip forward a track, and then backwards.
How long was the vehicle shut down for? also I need your iPod Generation and firmware version.
tom @ eas is offline
Old 04-02-2007, 09:24 PM   #803
Nait Sirhc
My Ride: 92 GSX, 01 330i
Usually 30 minutes to an hour. It's an iPod nano, 2nd gen, running 1.11
Nait Sirhc is offline
Old 04-02-2007, 10:00 PM   #804
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Simply bundle up the slack and tuck away.
Old 04-02-2007, 10:02 PM   #805
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
A 2nd Gen nano should be running firmware version 1.1.2, update your iPod using iTunes or this install document: http://docs.info.apple.com/article.html?artnum=60944
Let me know if you have any further questions.
Old 04-04-2007, 08:29 PM   #806
CBDZ
My Ride: 323i Touring
Here are the details...
2000 323i Touring.
Buisness CD Player
30 GB Video Ipod
HD Dice
Now the Issues...
If I shut down the car while in Ipod mode, and come back after a few hours, like from morning until lunch time, the Ipod begins playing at the beging of the track library...1st song...in the 1st album...of the first artist.
Everything seems to work ok, but it is annoying that I can't listen at the same place that I left off.
If I shut down for only a few moments...like run in the store to pickup a pizza, I gain have gone back to the first song in the library, but the text display gets stuck on the last track that I was listening to when I shut down.
If I shut down while in HD Radio mode, and come back, I again am put back at the begining of the frequecy range.
Also, I am having issues programming the radio presets.
I have not tried the usually suggested steps of pulling fuses, resetting the ipod, or pulling fuses.
I first want to know if this type of operation could be considered normal because I have a older Blaupank H.U.?
CBDZ is offline
Old 04-05-2007, 12:39 AM   #807
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
This has nothing to do with the radio. What firmware version is on the iPod?
Old 04-06-2007, 01:17 AM   #808
CBDZ
I was under the impression that the older head units had Pause and shut-down issues.
The Firm-ware version on the Ipod is 1.2.1.
I guess I should go ahead and try to disconnect the battery, and all the other stuff in your standard reply that I have read at least 100 times onthis tread.
CBDZ is offline
Old 04-06-2007, 01:21 AM   #809
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
The 99-01 Blaupunkt radios do not pause the iPod without changing the source first, but that isn't what was in your original post. Try resetting the battery first, if you should continue to have trouble - give me a call from your BMW and we'll run down some steps in real-time.
Old 04-10-2007, 06:28 PM   #810
jacobchemical
My Ride: 2005 330xi
Problem with DICE
Hey Tom,
I bought a dice ipod adapter from EAS and installed it this past weekend in my 2005 330xi with navigation. I followed the instructions from website and it is not working. I recheck all my connections and took out fuses and still the same problem. I am able to switch to cd changer and change tracks on navi but no sound and ipod doesnt seem affected. Also the ipod does not charge. Another thing is when i connect the ipod the navigation switches to the Speed dial screen and displays" DICE ELECT"
Please help. I am very frustrated.
jacobchemical is offline
Old 04-10-2007, 06:35 PM   #811
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Originally Posted by jacobchemical View Post
Hey Tom,
No need to be fustrated, we're here to help. You simply need to disconnect and reboot the iPod by pressing the MENU and CENTER buttons for +5 seconds, then reconnecting after Clickwheel operation returns.
Afterwards, you should see text display on the radio display.
Old 04-10-2007, 07:31 PM   #812
jacobchemical
My Ride: 2005 330xi
Hey Tom
Thanks for quick reply. I just rebooted ipod and still same problem. The ipod works fine. I can scroll thru and pick songs etc even when connected to the dice device. However it doesnt charge when connected, there is no text display or sound. The only thing that happens when I connect ipod and switch to CD1 is that the screen goes to Speed dial and says " Dice elect" The ipod remains fully functional at that time but no charging, no sound or text display
Old 04-10-2007, 07:38 PM   #813
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Hey Tom
Is this a standard DICE or HD DICE?
Old 04-10-2007, 07:47 PM   #814
jacobchemical
My Ride: 2005 330xi
Standard trunk interface which i ran to glove box
Old 04-11-2007, 12:18 AM   #815
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Recheck the DIP switches on the module, they both need to be in the OFF position.
Old 04-11-2007, 01:10 AM   #816
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Originally Posted by markandersonus View Post
Hi Tom
Where do I find a qualified technician who knows about DICE equipment? I'm not going to waste my money at a BMW dealership
(BTW - it's two units not 3. If you want to send me a 3rd one, feel free)
Regards
Mark
I can't recommend anyone I've worked with personally in the Chicagoland area, however I can offer to test your current module in hand on our bench and my own BMW to see if the same behavior is present.
This will determine if the DICE or there is something else going on in your BMW.
Old 04-11-2007, 11:08 AM   #817
boomr
My Ride: 05 M3 vert
detailed instructions
Tom, I got the detailed instruction that you sent to me the other day, extremely helpful, thank you. Also went back and installed it last night, much easier the 2nd go around, knowing where the wiring goes.
Great service and great product. In fact, I was so happy with the way everything sounded, I didn't even listen to my normal talk show this morning during my morning commute (1.5 hour drive), thanks again for the great service.
Mike
boomr is offline
Old 04-11-2007, 11:29 AM   #818
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Mike
Thanks for the feedback. Keep in mind that most talk programs are in podcast format now, you can still download your shows and place them on the iPod for later.
Old 04-11-2007, 12:01 PM   #819
jacobchemical
My Ride: 2005 330xi
I have checked all my connection, and both of the DIP switches are off. Still same problem. I think the device is defective. Is there anyway to test it to determine if it is the device or connection problem?
Old 04-11-2007, 04:09 PM   #820
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
The DICE coming up as a selection and the message would indicate the kit is running properly, just not reading the iPod properly. First thing would be a full reset of both the iPod and the DICE:
1. Disconnect iPod from cable
2. Remove battery cables, negative first
3. Touch battery cable terminals together (away from battery) for +5 seconds, a small spark is normal as this is stored power draining from the system.
4. Allow cables to remain disconnected for about 5-7 minutes
5. Reconnect battery cables onto battery, negative last.
6. Reboot iPod by pressing on MENU and CENTER buttons for +5 seconds and then reconnecting to the DICE cable after the reboot process is completed.
Let me know if these steps correct the problem, if not - we'll make the necessary steps for product replacement under warranty
Closed Thread
Rate This Thread
