Sponsored by BAVSOUND
Closed Thread
Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 5.00 average.
Old 07-01-2007, 02:33 PM   #961
tom @ eas
european auto source
tom @ eas's Avatar
My Ride: e92 S/C M3
Originally Posted by itsmike View Post
Any way to get it to continue scrolling from the current playlist?
No, this is default by DICE.
tom @ eas is offline
Old 07-01-2007, 02:33 PM   #962
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Originally Posted by rasbeam View Post
All fuses are intact. Does it matter that I have 05 325Ci, premium sound package with DSP. Also i didnt get the 6CD Changer for the trunk. Also all the switches on the box are set to the off position. Also I plugged in the wire to the ipod jack not the aux jack. Everything is wired as your directions stated. What did I do wrong. My bus. cd has the mode button which I pressed twice already? What should i do?
The 3-series was never offered with DSP. Let's try reinitializing the device next:
1. Disconnect iPod from cable
2. Remove battery cables, negative first
3. Touch battery cable terminals together (away from battery) for +5 seconds, a small spark is normal as this is stored power draining from the system.
4. Allow cables to remain disconnected for about 5-7 minutes
5. Reconnect battery cables onto battery, negative last.
6. Reboot iPod by pressing on MENU and CENTER buttons for +5 seconds and then reconnecting to the DICE cable after the reboot process is completed.
Let me know if these steps correct the problem.
Old 07-01-2007, 03:05 PM   #963
rasbeam
My Ride: 05' BMW 325Ci
Send a message via AIM to rasbeam Send a message via Yahoo to rasbeam
Still Stuck
Still at the same spot. What else can I try. I mean not even my 80Gig Video Ipod is recoginizing that is plugged in. Or am I able to bring up the AUX for the DiCE to be recognized?
rasbeam is offline
Old 07-01-2007, 03:10 PM   #964
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Does the DICE appear as a mode when the MODE or CD button is pressed?
Old 07-01-2007, 03:12 PM   #965
rasbeam
Nope. I mean its not even like it is been installed. When I hit the mode it just goes between the radio station and the cd player, thats in dash
rasbeam is offline
Old 07-01-2007, 03:17 PM   #966
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
With a multimeter, check for +12V at the middle wire from the 3-pin connector in your BMW with the key in the ON position. If good, check the brown wire at the 12-pin connector of the DICE harness
Also - verify if you are using the correct 3-pin connector. The correct connector (BMW side) has the brown wire in the #1 position, not the middle.
Old 07-01-2007, 03:21 PM   #967
rasbeam
Good and Good...Everything seems to have power. What should I do now?
rasbeam is offline
Old 07-01-2007, 03:27 PM   #968
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
There may be a problem with the module, contact me directly via email with your full name and we'll make arrangements to have it replaced.
Old 07-01-2007, 03:33 PM   #969
rasbeam
Email Sent. Thanks Tom for all your help. Look forward to get this working
rasbeam is offline
Old 07-01-2007, 11:51 PM   #970
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Originally Posted by jfmiii View Post
i have an 05 M3 and have had a DICE installed for about 3 months. it has worked great. recently though, I have been hearing a feedback/hissing sound when music is playing (it's VERY noticeable when there is a pause in the music or if it is a live recording, when the audience is only there and the music hasnt started). It sounds absolutely horrible; worse than a cassette adapter! has anyone had this problem. thanks in advance!
Has anything changed within your system in the last 3 months?
Old 07-03-2007, 11:19 PM   #971
Miko_10
My Ride: 330i 5 Spd
what's the difference between the DICE and the BMW kit?
FS(PM me if interested, MID Atlantic Area, 22307 zip)
- 2 M68 fronts w/ winter tires, local pick up preferred,
- OEM Pre face Sedan Clears.
Miko_10 is offline
Old 07-04-2007, 02:27 PM   #972
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
The BMW kit and DICE have the same core functions (steering wheel/radio control), iPod charging and direct iPod connection), the DICE goes a bit further in features:
- Text display on your radio or navigation display
- unlimited Playlists (BMW kit is limited to only 5)
- ability to browse by song, album or Playlist
- Full control of iPod's Clickwheel (BMW kit locks out the wheel)
- Retains display on iPod (BMW kit places a logo in place)
- Integrated AUX input
- All iPod features are still functional (highest rated songs, play count, on-the-go playlists, etc)
- Easy installation, no vehicle rewiring required
DICE simply offers more features for the same amount of money.
Old 07-05-2007, 07:35 AM   #973
Miko_10
My Ride: 330i 5 Spd
Thanks Tom. I'll be ordering one soon.
Miko_10 is offline
Old 07-05-2007, 10:20 AM   #974
rsitnick
My Ride: 2009 328i x-Drive
DICE w/ Factory Aux
Hi,
I have a 2004 325xi with Business Radio and Factory AUX connector installed.
Seems the DICE and the HD radio kits also have AUX inputs.
How will this affect (if at all) the factory connection?
Do I get secondary AUX ports as well?
Thanks!
--Ron Sitnick
Sterling, VA USA
2009 BMW 328i x-Drive
1979 Fiat Spider 2000
http://community.webshots.com/user/fiatz79
rsitnick is offline
Old 07-05-2007, 10:47 AM   #975
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Originally Posted by rsitnick View Post
Hi,
Thanks!
Ron,
If you have factory BMW AUX, this will remain active.
Old 07-05-2007, 11:32 AM   #976
FrankC
My Ride: BMW 330 xi 2003
DICE - Engine Noise - Problem Solved - Thanks Dice
Originally Posted by tom @ eas View Post
I would try a Ground Loop Isolator (GLI) since these are relatively inexpensive and can be purchased locally, some BMWs are more sensitive to engine noise than others. Here is a link to the version we offer on the website:
12 Amp Power Noise Filter
http://www.europeanautosource.com/pr...roducts_id=309
Let me know if you have any further questions.
I reported my problem with engine noise, etc. to Dice and they sent me a replacement module at no cost - I plugged it in and it works as advertised. SWEEEET!!! Thanks Dice and Thanks Tom for all your work on this board - knock wood I won't be back looking at it again any time soon though
FrankC is offline
Old 07-06-2007, 12:30 AM   #977
fraylo
My Ride: -
Tom, scanned through this thread, looks like you've been very helpful, so thanks.
I just installed my dice ipod integration kit in my 2002 330Ci. I have the latest firmware installed on my iPod and everything seems to be working great.
However: when I change playlists, the playlist ALWAYS starts on the same song every time, and goes through the playlist the exact same way. shuffle is enabled on my ipod.
so for example, let's say I've got 3 playlists full of songs. Starting playlist 1 will begin playlist 1 sequence. if i switch to playlist 2, it will begin the playlist 2 sequence. switching back to playlist 1, start the exact same sequence as before (all songs in the same order), rather than reshuffling the songs (as I would expect if I clicked "play" on the playlist on the actual ipod).
Does this make sense? Is this just how the dice works? I'm pretty sure this happens even after turning off the car and turning it back on again in a few hours.
If this is how it acts, it seems like I will never get a shuffle on my playlists unless I manually shuffle it on the ipod somehow, or re-sync my ipod, since the playlists just go through in the same order again.
fraylo is offline
Old 07-06-2007, 02:26 AM   #978
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Give me a call from your BMW tomorrow morning and lets run down some tests in real time.
Old 07-06-2007, 12:54 PM   #979
yves
My Ride: E46 touring
hello ,can you tell me in detail what you just did ,i seem to have the same problem ,please help me out here !!!
thanks!!!!!!!!!!!!
yves is offline
Old 07-06-2007, 01:38 PM   #980
yves
no sound
Originally Posted by camfather View Post
I just installed mine and had NO SOUND but everything else was working. Turns out the lil white plug on the radio kit has pin 1 mislabled. Flipped the plug over and all is working fine now. It's ashame that plug fits both ways, cost me 3 hours in troubleshooting...
can you tell me please what color pin sould match what number?
i think i'm having the same problem,my connector is plugged the right way ,numbers on connector correspond to numbers on HU
yves is offline
Closed Thread
Rate This Thread
