Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 41 votes, 5.00 average. Display Modes
Old 06-14-2006, 01:43 AM   #1
tom @ eas
european auto source
tom @ eas's Avatar
My Ride: e92 S/C M3
[eas] *** DIY TUTORIAL - DICE iPod integration kit in e46 Coupe ***
In this DIY, we are going to install a DICE iPod integration kit into a 2005 330Ci with Business CD and rear fold down seats. The vehicle was ordered without a CD Changer.
First, the DICE iPod kit comes with 3 major pieces:
- 4m Trunk interface cable
- DICE iPod integration module
- iPod Dock connector cable
We are going to focus more on the install aspects rather than operation to keep the post length to a minimum. This is a typical glovebox installation, which allows a clean stealth install with no drilling any damage to the vehicle.
Items needed:
DICE iPod Integration Kit for BMW
http://www.europeanautosource.com/pr...roducts_id=268
- Phillips screwdriver
- trim removal tool or similiar device
Let's begin!
1. The needed connections will be in the trunk/boot area.
2. The driver's side rear taillight house will need to be removed. This will unclip or unscrew depending on your specific model year.
3. Access the fuse panel in the glovebox by turning the nylong retaining clips inward 90 degrees until the panel drops down. Remove fuses #7 & #41 to cut power to the radio/navigation tuner. e46 radios will not need a radio code when connected.
4. Remove inner taillight housing and taillight plug.
5. Image of taillight with housing removed.
6. Remove expansion rivet with a trim removal tool or similiar device. There are (2) rivets that will need to be removed to gain access to the wiring.
7. Location of 2nd expansion rivet, this will need to be removed.
8. Move trunk lining out of the way.
9. Locate CD Changer wiring harness. This will be located behind the factory amplifer touching the inner wall of the fender. This will have the needed 3-pin and 6-pin connectors.
10. CD Changer wiring located, wrapped in cloth sheath.
tom @ eas is offline   Reply With Quote
Old 06-14-2006, 01:45 AM   #2
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
[eas] *** DIY TUTORIAL - DICE iPod integration kit in e46 Coupe *** (cont.)
11. Unwrap cloth sheath to expose needed 3-pin and 6-pin CD Changer connectors.
12. Connect 6-pin connector to DICE harness, this is keyed to only go in one direction.
13. Connect remaining 3-pin connector, verify connections are snug. Also note that the connector on the left side (BMW side) has the brown wire in the #1 position on the outside. This verifies this is the correct connector as there may be multiple 3-pin connectors in the vehicle.
14. Unravel trunk cable, and prepare to run to cabin area.
15. Fold down rear seats (if equipped) and run trunk interface cable underneath trunk liner towards back seat area.
16. Cable entering cabin area, next to driver's side rear seat hinge. Position cable towards bottom corner next to the bolster.
17. Remove bottom portion of seat by lifting on bottom cushion and push aside. Seat does not need to be removed from vehicle, but it may simplify the job.
18. Pull slightly on rear seat bolster and tuck the trunk harness cable away from view.
19. Angle with seat bolster pulled back with wiring tucked in.
20. Push seat bolster back into position to conceal wiring.
Old 06-14-2006, 01:46 AM   #3
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
21. Prepare to route wiring underneath rear seat to passenger side of vehicle.
22. Cable being routed to passenger side, clearing seatbelts.
23. Trunk harness on passenger side, preparing to place bottom seat cushion back into place.
24. Seat cushion reinstalled with trunk cable completely hidden.
25. With a trim removal tool or similiar device, pop nylon retaining clip from door sill.
26. Route trunk cable underneath the retaining clip and pop back into place.
27. Trunk cable in place, preparing to route underneath door sill to glovebox.
28. Tuck trunk interface wire underneath door sill by tucking it underneath with your fingers. Don't remove the sill as the retaining clips are very delicate, especially with older models. You will feel a small channel wher the wire can be pushed into. Repeat tucking the cable until you reach the passenger side kickpanel.
29. Trunk harness at passenger side kickpanel, ready to route to glovebox. Note plenty of slack left in harness.
30. Alternate shot of harness at kick panel.
Old 06-14-2006, 01:46 AM   #4
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
31. Time to remove the glovebox, remove bottom phillips screw.
32. Open glovebox to prepare for removal.
33. With your trim removal tool or similar device, remove the plastic pin holding the glovebox dampener strut on left side.
34. Repeat process on right side of glovebox.
35. Remove glovebox door retaining hinges. There are (2) screws.
36. Repeat process on left side.
37. Remove glovebox door and place in a safe area.
38. Remove remaining screws. Staring with step #31, there are a total of (10) screws holding the glovebox door and plastics on. Note that the screws in steps #34 & #35 are shorter than the other screws, these should be set aside.
39. Last screw for removal (#10)
40. Remove glovebox frame and set on floor of vehicle.
Old 06-14-2006, 01:49 AM   #5
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
41. Route trunk harness up kickpanel to very top.
42. There is a pre existing hole in the glovebox, the iPod cable is a perfect canidate for this position. Route the iPod cable through the inside of the glovebox frame and prepare for connection to the DICE module.
43. Connect trunk interface module and iPod Dock connector cable to DICE module. Verify DIP switches are set to the "OFF" position. If you would like to utilize the AUX connection on the module, this would be a great time to connect your interface cable (available seperately).
We also have these on the site:
eas 3.5mm male/female AUX extension cord
http://www.europeanautosource.com/pr...roducts_id=312
44. Connect dock connector to ipod and you're complete!
45. Activate text as outlined in the user's manual
Installation is now complete!
Note: Your iPod must be updated to the minimum firmware requirements in order to be compatible with the DICE
iPod kit.
Supported iPods and Firmwares
IPOD
- 3G: Must have minimum firmware version 2.3. Does not support Albums/Chapters. FF/RW Does not work from radio
- 4G: Must have minimum firmware version 3.1.1
- 4G Photo/Color: Must have minimum firmware version 1.2.1
- 5G Video: Must have minimum firmware version 1.1.1
- nano: Must have minimum firmware version 1.1.1
- mini: Must have minimum firmware version 1.4.1
Updated iPod firmware can be found at Apple's website: http://www.apple.com/ipod/download/
Helpful resources:
DICE owner's manual: http://support.diceelectronics.com/f...al_rev_B01.pdf
Have fun!
Old 06-14-2006, 07:34 AM   #6
jechin
My Ride: 328i
Thanks for the install instructions. With the IPOD in the glove box, can you close the glovebox door?
jechin is offline   Reply With Quote
Old 06-14-2006, 10:33 AM   #7
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Of course, going this route keeps every as factory-lke as possible with no drilling or cutting needed.
Old 06-14-2006, 12:35 PM   #8
curious_george
My Ride: '02 325i ZSP
Tom - I did not see from your instructions where you intended for the DICE module to be kept. Is there a reccomended location for it?
Where does one get a trim removal tool? I assume that the BMW trim attachments are not the one-use type. I have seen those in other cars, meaning you had better by all new clips if you want stuff to go back together and be rattle-free.
curious_george is offline   Reply With Quote
Old 06-14-2006, 12:58 PM   #9
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Anywhere behind the glovebox is fine. Location is not important.
This is a simple trim removal tool that can be purchased @ Home Depot, for about $8.
Old 06-14-2006, 10:59 PM   #10
lonnie_20
My Ride: 2001 Dinan 330ci
Send a message via Yahoo to lonnie_20
As a long time Icelink user....what is the difference b/n the icelink and dice?
lonnie_20 is offline   Reply With Quote
Old 06-15-2006, 01:52 PM   #11
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
This is a question we get asked often, we have a comparison of the two kits on our site:
http://www.europeanautosource.com/ipod_matrix.php
Old 07-21-2006, 12:18 PM   #12
sm02463
My Ride: 2001 330Ci
I just got back from the BMW Dealer for an Inspection II service..., anyways, now my DICE module doesn't seem to be recognized. When I hit CD it no longer goes to CD1-01 display normally for the CD changer.
I'm not sure what they did but I'm thinking they reset something. I tried simply pulling the fuses (7,41) and waiting a minute and putting them back but that did nothing.
Do you know what I need to do?
sm02463 is offline   Reply With Quote
Old 07-21-2006, 12:29 PM   #13
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
It could have been they even disconnected it. Check the connections in the trunk to be sure.
Old 07-21-2006, 01:07 PM   #14
sm02463
My Ride: 2001 330Ci
No, they didn't touch the connection. But I disconnected and reconnected the cable at the DICE module and now it works again...
Old 07-21-2006, 01:21 PM   #15
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Awesome - let me know if you should need additional assistance.
Old 07-31-2006, 12:43 AM   #16
bmdubalicious
My Ride: 03 325i
In the actual install guide from DICE, it doesnt mention removing the fuses during the install then putting them back at the end. Will you give these directions and also will you give directions for routing it to the center console? This is for the people who will install my DICE because i do not feel confident enough to work on it myself
bmdubalicious is offline   Reply With Quote
Old 07-31-2006, 12:47 AM   #17
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Take your pick: http://www.europeanautosource.com/su...nter/index.php
The installation instructions from DICE are very basic - follow the instructions on our knowledgebase.
Old 07-31-2006, 01:00 AM   #18
bmdubalicious
My Ride: 03 325i
thanks alot
Old 07-31-2006, 01:02 AM   #19
bmdubalicious
My Ride: 03 325i
also, when i get this will i be able to get the text to display on my radio with both the switches set to off. Is there a mode where you just set it to random and have it go through the entire library on my ipod?
Old 07-31-2006, 12:15 PM   #20
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Yes, kepe the DIP swtiches set to off, text will be on your Business CD display. As for the Shuffle command, You can just select Shuffle on the iPod to randomize your songs within the playlist.
