The Showroom
Old 06-26-2006, 11:28 AM   #1
LAFENGAS
www.thielstudios.com
LAFENGAS's Avatar
My Ride: 330ci
Send a message via AIM to LAFENGAS
Arrow DIY Project: Front Bumper Fabrication, version 3.0 (CSL)
Okay...so my last bumper was an ///M3 bumper that I hacked up to fit my car and molded the ACS lip to it, ect. Anyway..after a year and half of abuse the ACS lip cracked pretty badly and other flaws that bother me. Bottom line, it was time for a change.
I liked the CSL bumper, but didn't care for the single duct and CSL V2's do nothing for me. so i decided to modify the CSL bumper to my liking.
Everything posted within this single post was done friday evening and saturday. I still have minor work to do, but this was the majority of my concerns.
1st. The Splitters were very weak looking. Holding them up to the light i could see right through them! Worried that I would crack them if i hit anything, now was as good a time as any to reinforce them:
So...i dipped into my ballistics kevlar supply (this isn't the aesthetic stuff)
Reinforced the backside of the splitters. The 'pointed' frontmost section has 7 layers of kevlar which is thicker than standard issued army helmets. It's not pretty stuff, but it works!
LAFENGAS is offline   Reply With Quote
Old 06-26-2006, 11:28 AM   #2
LAFENGAS
LAFENGAS's Avatar
My Ride: 330ci
Next I started taking measurements for the duct so i could make an accurate mold and posistion it correctly. It's not simply just cutting a hole out. To do it correctly, the duct is angled slightly and has a taper to it.
I found a large yogurt container had a near pefect size. Taking my depth measurements i transfered them to the yogurt container to get the proper sizing and angle.
I then took an uncut yogurt container and poured plaster in to allow it to solidify an make a good sturdy mold. I used my vacuum bagging system to force the Carbon Fiber tightly around the yogurt container. If i didn't reinforce it, it would just colapse under the pressure. (this obviously wouldn't make a great mold)
This pic is fresh from the vacuum bag. There are several layers ontop of the carbon fiber. This process removes a lot of excess epoxy so you have a higher CF to Epoxy ratio which gives you a stronger lighter (not that it matters much for this) part. But i had to make sure the CF was pressed firmly against the mold to get a nice smooth shape on the inside of the new duct
Once all the garbage has been removed and the yogurt container pulled from the CF this is what it looks like:
Now I cut the CF to shape using the template i made earlier out of the other yogurt container. Putting the CF duct in the appoximate place on the bumper, i used more CF to build a flange around the duct. Doing this gives a more rigid part, more as well as surface area to bond the part to the bumper.
Now to cut the hole. I put a piece of paper over the OEM duct and traced it. Flipping the paper over gave me the mirror image i needed to be able to a hole in the proper shape and location on the opposite side.
Using a high strength 2-part epoxy to bond it in place. I left the hole slightly undersized so i would have material to play with once the duct was in a permanent location:
After some sanding and rounding the edges to match the otherside. notice the hole isn't a circle, but oblong. Not an easy hole to match and place correctly:
And the duct complete:
Still have more fabricating to do on other areas of the bumper, but I was happy that I got the process down well enough to complete in a short time. Started it Friday early evening and the duct was completed as shown on saturday, the next day.
I have more work to do and will update this as it's completed.
enjoy.
Old 06-26-2006, 11:33 AM   #3
eddiee46
My Ride: e46
wow, great amount of details....
subscribed...
a member of ....
eddiee46 is offline   Reply With Quote
Old 06-26-2006, 11:38 AM   #4
3TARD
My Ride: 2000 323Ci JET BLACK
You are the king of custom fabrication on this board; excellent work
3TARD is offline   Reply With Quote
Old 06-26-2006, 11:44 AM   #5
S4izzle
Banned
My Ride: Audi S4midable
S4izzle is offline   Reply With Quote
Old 06-26-2006, 11:50 AM   #6
///OSS
///OSS's Avatar
My Ride: "The.. 325CI"
Send a message via AIM to ///OSS Send a message via MSN to ///OSS
super sick I cant wait to see the final... looks like your living up to that PS buddy...lol
Im glad, its gonna be the sh it
///OSS is offline   Reply With Quote
Old 06-26-2006, 12:21 PM   #7
aznazasin
My Ride: Gets B!tches
Send a message via AIM to aznazasin
DAMN so basically you accomplished all that within 24 hours.....thats some insane custom work....cant wait to see the result
aznazasin is offline   Reply With Quote
Old 06-26-2006, 12:39 PM   #8
Two Outtakes
My Ride: is on 20" DPE's
great work! cant wait to see the final result
RETIRED EP Sedan
Two Outtakes is offline   Reply With Quote
Old 06-26-2006, 12:40 PM   #9
Choson1
Owner
My Ride: Keepin' it Real
mad skillz man
Choson1 is offline   Reply With Quote
Old 06-26-2006, 12:55 PM   #10
jre.328i
My Ride: 99 BMW 328i
ur crazy... i have never though in that, u might hae a lot of xtra time
jre.328i is offline   Reply With Quote
Old 06-26-2006, 01:00 PM   #11
iLLM3
iLLM3's Avatar
My Ride: Boosted M3 + G35
Send a message via AIM to iLLM3
Agreed, i love seeing your threads, your so creative with custom work, that looks GOOD too! Question, is the original CSL hole open with mesh behind it? Why did you just leave it open with mesh on the otherside if so?
Martin
RUF R-GT2
07 E60 M5
01 996TT RWD/Stage 2+ turbo SOLD!!
03 G35 Nismo Daily
02 500+ HP SC M3 SOLD
www.e46psi.com
iLLM3 is offline   Reply With Quote
Old 06-26-2006, 01:01 PM   #12
LAFENGAS
LAFENGAS's Avatar
My Ride: 330ci
I must say, Luis talked/PS'd me into wanting to do a modified CSL bumper. Props to Luis. Now if you happen to charm the ladies like you charm me....
Old 06-26-2006, 01:04 PM   #13
iLLM3
iLLM3's Avatar
Lu is the man!
RUF R-GT2
07 E60 M5
03 G35 Nismo Daily
www.e46psi.com
Old 06-26-2006, 01:05 PM   #14
BreakMyWallet
My Ride: B6 A4/ Mini Cooper S
DIY king
BreakMyWallet is offline   Reply With Quote
Old 06-26-2006, 01:08 PM   #15
m3racing
My Ride: c230
Send a message via AIM to m3racing
crazy skills. where did you buy the CF epoxy resin and the vacuum bag. I have Cf leying around but cant use it...
Cuong- PS3- AUKTANE6
m3racing is offline   Reply With Quote
Old 06-26-2006, 01:17 PM   #16
LAFENGAS
LAFENGAS's Avatar
My Ride: 330ci
U.S. Composites
Old 06-26-2006, 01:51 PM   #17
MCD007
Im The Man
My Ride: 325ci
Send a message via AIM to MCD007
so when are you and mite46 gonna build a custom car again?
MCD007 is offline   Reply With Quote
Old 06-26-2006, 02:51 PM   #18
GunMoto
My Ride: EG8 | E46 | W211
Send a message via AIM to GunMoto
Impressive work!
GunMoto is offline   Reply With Quote
Old 06-26-2006, 03:13 PM   #19
iiimbpiii
My Ride: 07 SLK55, 08 R32
Send a message via AIM to iiimbpiii
That looks crazy... good luck with everything its going to to look!
07 SLK55: RENNtech CF airbox with Green Filters, Eurocharged/LET dyno tune, HEMs, CJs custom exhaust, Eisenmann quad P-car tips, Sprinbooster, H&R Springs, 19" Modular-Concept custom wheels, Euroteck CF front lip, Euroteck CF rear Spoiler, SL antenna, Clear reflectors, painted emblems... Soon to come: Looking into a TT setup!
iiimbpiii is offline   Reply With Quote
Old 06-26-2006, 03:16 PM   #20
fckupayme
My Ride: Razor Scooter on 20s
DIY king does it again... very nice work. the hole looks very well planned and executed. cant wait to see it on ur car
fckupayme is offline   Reply With Quote
