Sponsored by BAVSOUND
Old 10-25-2002, 04:47 AM   #1
topaze46
Xpracer
My Ride: Barebone 3IIV
Does anyone knos the speaker size for E46 325Ci ??
Does anyone knos the rear deck speaker size for E46 325Ci ?? TIA~!!!
topaze46 is offline   Reply With Quote
Old 10-25-2002, 07:40 AM   #2
Blade929
My Ride: ///M
Send a message via MSN to Blade929
I believe the stock ones are 5.25 but I had a professional install and with a little bit of work I have 6.50. I have MB Quarts. I've heard it's easier to install Quarts and focals because of the way they mount to the oem mounting points.
Blade929 is offline   Reply With Quote
Old 10-25-2002, 04:20 PM   #3
bender
hammer talks like this
My Ride: 2006 Honda insight
Send a message via AIM to bender
rear 6.50. front depends on what brand speaker you go with. i used 5.25 MB quart Q series in the front.... what nobody yells and sets off alarms anymore when someone doesnt post in the "correct" section anymore? losing your touch!
bender is offline   Reply With Quote
Old 10-25-2002, 04:37 PM   #4
guest1016
fanatical
My Ride: .
Send a message via AIM to guest1016
here we go again........
stock size, i believe is what he is asking, is 160mm front & rear, which losely translates to a 6" speaker. Most 6.5 will fit depending upon the degree of modification you want to make to your car. 5.25 a little on the smallish side, 6" is perfect.
guest1016 is offline   Reply With Quote
Old 10-25-2002, 04:38 PM   #5
flacoy2k
My Ride: 2002 M3
go to http://www.crutchfield.com click on "car audio & video". Put in the year, make and model of your car and they will show you which speaker will fit on your car. Crutchfield is expensive but you can use them for reference and they buy the equiptment some where else.
flacoy2k is offline   Reply With Quote
Old 10-25-2002, 10:24 PM   #6
topaze46
Xpracer
Thumbs Up
Thanks guys, I will go for DLS components for both front and rear.
Old 10-25-2002, 10:28 PM   #7
topaze46
Xpracer
I did check it out at crucchfield.com, but they dun have the data for my car tho, anyways thanks alot~!!
