#1 |
UUC swaybar noise driving me nuts
I have done everything I know to do to eliminate this creaking/torquing noise from my UUC swaybars. The noise only occurs when the front wheels go over a bump at different times, e.g. when turning into a driveway.).
I have shot greaswe into the sway bar link fittings, taken off the red bushings on the bar itself and lubed them. The bars are not hitting either the axle nor the upper control arm. And, yes, I have checked for subframe damage. The stock sway bars never required all this care and feeding. Is there something about these UUCs that I'm missing? thanks. |
#2 |
My Ride: '05 330ci 6MT
Sounds like you have the Gen III's like I do. I don't have any noises from the front at all. The rears have a very faint metallic sound from the end links, nothing the sound system can't remedy.
From what you said, you did everything right on the installation. Could it be something else? The shield up front perhaps? I remember there were alot of screws holding it on, maybe it's loose?
Jeff
#3 | |
One thing that I did was that between the bar and the bushing, I wrapped some teflon tape before I lubed the bushings. That's a trick that many have used. Worked a year at a time under moderate use here in the northeast. - e46myway |
#4 |
Been there,done that
Thanks for the responses.
First, no this is not a metallic sound. It is a very pronounced groaning/creaking noise that only occurs when the front wheels go over a bump at different times. I even put the rear wheels up on rhino ramps and jack up one side of the front and heard the noise. Cannot tell where it is coming from but it is as if something is gripping and then letting go under torque. I have found some old posts where others were having the same problem, even though they did not install new sway bars. I have used teflon tape. All the contacts points are well-lubed. This has me baffled... |
#5 | |
, SKIPII you might try this. I have not had any such problems from day one. Here's a pic of the Teflon tape wrap:
#6 | |
Done that, too
I wonder if i have the bushing bracket torqued too tight? |
#7 |
Scaring me guys I justed order these
#8 |
Lemony Fresh
The amount of noise a bad front swaybar endlink can make is frightening. I suggest you jack up and support the front of the car and have a friend turn the steering wheel while you listen for noises. Putting a hand on the front endlinks while doing this may also help you find the culprit.
Mod the driver first. Participate in your local BMWCCA driving school. Have you joined BMWCCA yet?
My Track Schedule The solution to the lack of headroom in the X6 ![]() |
#9 | |
Wrong end
#10 |
My Ride: M3 & 323Ci (sold)
If it's the rear..are you sure it's the swaybar? It may be your rear shock mounts. Seeing how the rear shocks are moving also as one side goes up and down, these are connected to the rear shock mounts and a clunking noise is a great way to describe that problem. Give them a check and let us know. It's easy to misdiagnose a problem in the suspension as it's connected to so many other parts. Add that your somewhat new swaybars would accentuate loads on the RSM.
The only other thing that comes to mind is make sure you tighten your bolts to the bottom shock and the swaybars as the car is unsuspended. Like you said, on ramps like it would sit/settle-in when on the ground. Otherwise you maybe pre-loading the suspension and it's mounts causing it to bind when fully extended/compressed. If you tighten them up as it's hanging on jackstands or a lift, it locks them in at the wrong geometry. But my money is on the RSM.
![]() ![]() OEM CSL WHEELS - OEM CSL BRAKES - OEM AUTOFOLD MIRRORS - CSL TRUNK - CSL DIFFUSER - AA SPORT TUNE - AA PULLEYS - BILSTEIN PSS9s - AUTOSOLUTIONS SSK CF CSL RACE LIP - NAVI HU - BMW PERFORMANCE CF STRUT BAR - BMW GROUP-N MTRMTS - UUC SS BRAKELINES, TRANS MOUNTS, RTABs - 4.10 BMW M-SPORT DIFF |
#11 | |
Worth a try
This noise started right after I installed the sway bars, which is why I started there. |
#12 | |
Lemony Fresh
#13 | |
Nope
#14 | |
#15 | |
Lemony Fresh
After re-reading your first post in this thread, I still think you should check the front endlinks. Undercar sounds can be deceptive so what you think might be coming from in back might actually be up front.
#16 |
sounds like your control arm bushings are done
#17 |
Sigh...
I appreciate all the responses, but they seem off the mark.
Here again are the facts: The noise is from the rear -- no doubt. The sway bar is not hitting anything. It is a creaking/groaning nolse that omly occurs when the car body torques, such as going over a bump at an angle. It is not control arm bushings. That is a clunk, not a graon/creak. (Plus I replaced them a few months agp. Yes, I did the entire install with the car on ramps. In fact, if I leave the car on ramps and jack up one front side, I hear the creak/groan. Yes, I used Teflon tape. I am unclear about the RSM idea -- is this a shock mount that is integral with the body or just the removable washer and bushing that comes with a shock? If the latter, unlikely culprit -- my Konis are only two years old. |
#18 | |
Understand RSM better
Thanks for your patience. i did a little homework and realize now what you mean -- the RSMs are serviceable items. I will upgrade to Meyle and give them a try. I talked with UUC and they said I should have lubricated the OUTSIDE of the red bushings, not just the inside where it makes contact with the sway bar. I doubt that's it, but I'm trying anything. |
#19 |
My Ride: E46, E36, E30, E320
Perhaps try aftermarket adjustable rear sway links to properly load the aftermarket sway bar.
#20 | |
I have the exact same problem. It drives me nuts too! Thought I was the only one. Any other sway bars you can recommend? I bought mine last year...
![]() 2004 330i ZHP (me) 2006 X3 (wife) 2004 325xi (sold) 2001 325i (passed on to DavidJay) MY DIY write-ups MY Garage (all the mods) |
