Sponsored by BAVSOUND
Old 07-03-2006, 12:38 PM   #1
highlander
My Ride: 318ci
16:9 M3 monitor help in E46
hi all, i have purchased myself an M3 tv/satnav etc... 16:9 monitor for my e46 318ci on an 'X' plate 2000.
as standard there is a business model radio cassette, and a 6cd boot changer, i have removed the trim, and unscrewed the radio, pulled the radio away from the dash and found a 17pin connector block on the back, but on my tv monitor, i have a white block and a blue block.....hmmm, this is where i am stuck, is there a connection block/harness that will convert this for me.
i am not bothered about the satnav side of things, all i want is the tv to work, the radio to work, and for it to control my boot changer and whatever it does.
thanks in advance.
highlander is offline   Reply With Quote
Old 07-03-2006, 01:48 PM   #2
highlander
My Ride: 318ci
anyone any ideas, or know of a site that will make/supply a harness for this?
Old 07-03-2006, 03:22 PM   #3
Technic
My Ride: 2015 320i
thanks in advance.
You need a new harness, a Nav computer and a tuner... you have to have all those components to make that screen just to turn on.
Do a search for all the part numbers required and installation...
Technic is offline   Reply With Quote
Old 07-03-2006, 03:54 PM   #4
highlander
My Ride: 318ci
cheers m8, at least now i know where to start.
thanks again.
Old 05-31-2007, 06:36 AM   #5
honest_al
My Ride: 318ci
wow, just bringing this post out of the past LOL
ok, finally got round to fitting it yesterday with a mate of mine.
we fitted the screen, wired the harness down the side of floor and into boot.
fitted the DVD mk4 nav unit, fitted the BM54 tuner and fitted a gps antenna into the rear shelf.
then a couple of problems.
what are the pinouts for the cd changer so it can be used on screen, i have a block on my harness with 5 wires, (2 for telephone and 3 for cd) and the white 10 pin block on original harness for cd.
i need to somehow connect these together, so i can get sound from cd's.
next problem was when i turned on ignition, it said no cd/dvd in nav unit, (good job we have nzb sites, i found v29.1 software and a map disc,) installed these discs and now i have satnav.
how do i get the tv to work, as i can't see a function for it, but when i bought it off ebay it said tv on the advert.
any help really appreciated.
honest_al is offline   Reply With Quote
Old 05-31-2007, 06:37 AM   #6
honest_al
My Ride: 318ci
ooops, forgot to say, i am highlander, i lost my details so i re-registered.
thanks again.
Old 05-31-2007, 11:28 AM   #7
gkoutsis
My Ride: 04 330 Cabrio
You should have 2 plugs leaving the cd changer and going to the BM54 tuner.
If not, you need to be creative and modify your old cd changer loom.
Let us know what you have. Maybe a couple of pictures will help.
George
gkoutsis is offline   Reply With Quote
Old 05-31-2007, 11:45 AM   #8
Technic
My Ride: 2015 320i
This should help you with that CD Changer wiring problem:
You will need that socket, I don't remember the P/N but it is in this forum somewhere...
Old 05-31-2007, 01:28 PM   #9
honest_al
My Ride: 318ci
thanks guys, i now have sound from my cd changer.
only thing now is how do i get my tv to work, or do i need something else?
thanks in advance, and thanks again for the reply's
Old 06-01-2007, 08:00 AM   #10
RichardP
My Ride: M5
The TV should just work if it's connected up correctly. It anounces its self on the bus so the option should appear on the main menu.
RichardP is offline   Reply With Quote
Old 06-02-2007, 08:33 AM   #11
honest_al
My Ride: 318ci
on my screen i have 4 options, one in each corner.
computer
gps-navigation
set
monitor off
no other options
i have the bm54 tuner, is this right
Old 06-02-2007, 09:46 AM   #12
mharv
My Ride: 318 ci sport convert
The tv tuner has it's own seperate harness, which you can buy from the $tealer in the UK, it consists of two small wires for audio which are inserted into the BM54 radio plug, the main harness about 5 foot long has one male and female blue plugs, which are connected to the navigation unit blue plug and the other end of the harness has one white and one blue connector plugs for the TV Tuner....
You do NEED the oem tv antenna rear bumper kit to provide the signal...
mharv is offline   Reply With Quote
Old 06-02-2007, 12:36 PM   #13
honest_al
My Ride: 318ci
thanks mharv, do you have a pic or link of the oem tv antenna rear bumper kit?
i have bought a harness loom that goes from front of car tv/monitor screen and then into rear bm54 and mk4 dvd nav unit, or is this a different lead?
thanks again to all who have helped.
Old 06-03-2007, 04:58 AM   #14
mharv
The oem TV Function retro fit kit is a complete kit including the tv antenna for the rear bumper... there are two different tv rear bumper antenna's ie one for the sport model and other for SE and standard versions of E46
have different part numbers.... check out www.realoem.com and enter last seven digits of VIN chassis number for your car... or if you have ETK disc you can find the parts list for all parts from the retro fit kit number... either for analogue or analogue/hybrid digital... to get the part number for the rear bumper tv antenna and associated wiring that goes directly to the tv module
and the tv harness loom...
I do have
Old 06-03-2007, 05:04 AM   #15
mharv
http://www.mharv.plus.com/BMW%20TV%20Installation.pdf
http://www.mharv.plus.com/51%2012%20...r%20bumper.pdf
this might explain the procedure far better...
PM me if you need any further help...
Old 06-03-2007, 10:28 AM   #16
honest_al
My Ride: 318ci
@ mharv, you have been a great help thanks.
looks like i need to spend MORE money and get a video module and aerial and more stuff *sulks*
nothing is ever simple.
Old 05-16-2008, 09:05 AM   #17
honest_al
My Ride: 318ci
just like to thank mharv again for helping me out on phone other day, great asset to this forum.
i am now 2 wires short of my installation.
i have the full set up, just bought the bumper aerials and the tv tuner and wiring loom, and all i now need is the 2 wires that connect th eaerials to the tv tuner, i believe the part number are 0144099 0144100, but my stealer won't give me a price on em as i cannot be specific, and cos i never bought the rest of stuff from them.
i have found this guide: http://www.bmwmotorsports.org/pdf/BM...stallation.pdf
and the 2 wires i need are parts B and C on page 5.
many thanks in advance if anyone could point me in right direction to where i can buy these.
Old 05-16-2008, 03:07 PM   #18
mharv
You need the following cables:
Retrofit Cable Set Antenna Line TV1 #61 12 0 144 099
Retrofit Cable Set Antenna Line TV2 # 61 12 0144 100
Old 05-21-2008, 02:28 PM   #19
honest_al
My Ride: 318ci
just bought these leads from BMW Stockport branch and set me back 49 for the 2 leads inc vat.
so hopefully before weekend i will have my tv retrofitted (once i take rear bumper off to fit aerials.
thanks again to mharv for helping me out with this.
