#1 |
DDE ballast burned out, need help??
i wash my car yesterday, driving it around i notice a strong burning smell but i didnt know where it was coming from. this morning i realized that my passenger dde's were out, open the hood and found that the ballast must of got wet and burned out.
now, can i get the ballast seperatly or are the dde's on that side perhaps are damage also and need replacement??? |
#2 |
Same issue here.... Need one ballast! Drivers side DDE's out after washing.
#3 | |
Banned
#4 |
I had the same issue and went to Bavarian where I bought them and they gave me a new one with the exchange of the old one.
Good Luck Guys! |
#5 |
Makes sure to check all of your connections because I had a simialr problem and one my wires had just gotten wet then i re wired them and now they work fine the ballast wasn't damages at all.
#6 |
your ballast is def burnt out if you got it wet...go on ebay and search CCFL, buy the ccfl light tubes for $.99 ($7.00 shipped) and they will send you a ballast that illuminates dde's!!! have replaced mine 3x with these before i finally got sensical and waterproofed them...have predator chromiums btw...
#7 |
If you bought the predator chromiums, you can email Nick to see if you can buy one from him. You'll probably have to pay for it.
#8 | |
Still a fanatic...
#9 |
Mod Squad
My Ride: Motorsport III
^I believe the warranty is if the product becomes/is defective, not if a ballast gets wet (user error, should have ensured it would stay dry).
You think BMW would replace your radio after you poured water in it?
#10 | |
Banned
Oh yea, I hear it's a nightmare to cash in on the warranty with them as well. There was a member less than a month ago complaining about it. |
#11 | |
![]() "A fanatic is one who can't change his mind and won't change the subject." - Sir Winston Churchill |
#12 | |
Mod Squad
As far as water proof ballasts go I'm not sure about the Preds. Doesn't Jim Powell have a display with one of his ballasts floating in water? Now that's just plain cool.
#13 | |
Still a fanatic...
#14 | |
Banned
#15 | ||
Still a fanatic...
#16 | |
Car Junky
My Ride: has a torn subframe
The water resistant ballasts are actually on the cheaper ebay kits for some reason. They've been dipping the PC board in a silicon sealant and covering that with heatshrink (later replaced with palstic) for a couple years now. Usually if you wrap the entire region in heat shrink and some generous amounts of electrical tape you won't see water instrusion onto the balalst, but its good to keep it dry anyway. The water proof ballasts Jim has are for the heated raptors. FWIW. |
#17 | |
Banned
![]() BTW, if mine ever break, I'm holing you and Ken personally responsible! |
#18 | |
Car Junky
If yours ever break you can hold Hans responsible Its straight, I have a spare ballast for yours/Adarshes because he thought he had a dead one. |
#19 | |
Mod Squad
#20 | |
Car Junky
I the retailer gives very detailed install instructions that specifically say to install the ballasts in specific locations, and they become damaged in those locations due to water intrusion, would it not be caused by the instructions of the vender? I replaced a TON of ballasts when I was selling the Leistung kits and found that out of all of the failures, maybe 3 weren't water related. It was my fault because the instructions wree initially unclear on where to put the ballasts. Inside the headlights is ideal, but the E46 headlights are very tight for space. There used to be a good DIY with the location shown where the ballasts were kept inside the headlights, but they've now been taken down. |
